zuhandenheit Samba Member
Posted: Thu Feb 19, 2009 9:50 pm Post subject: |
ALSO, I think my problem could be the voltage regulator, could I replace just that?
Here, by the way, is what's happening: Voltage drops down below 12v, seemingly at random.
When I increase the current draw (lights or heater blower) usually the power drops below 12v, then sometimes back up to 12, occasionally higher (13-14), and then down again after awhile.
Sometimes it seems fine for while (over 13v) and then suddenly the power drops to under 12.
Belt is new and seems fine. Battery is new.
The alt light does not come on, so i guess the alt is always making *some* power. I've seen it come on before (when i had accidentally disconnected something) so i know that it works. |
Luckypabst Samba Member
Joined: January 29, 2006 Posts: 96 Location: Lone Pine, CA
Posted: Thu Feb 19, 2009 10:06 pm Post subject: |
What I've found is that there are only two alternators available for the early diesels - one is a Bosch and one is a Motorola. Both have a long offset pulley and the mounting ears are situated at 180 degrees from one another and are unique to the diesels (Rabbit and Van).
I was on the phone with my generator shop owning friend just yesterday in hopes that there's been any progress on the high amperage front. He said to scab on a GM or Ford alternator because there are no off the shelf options for upgrades.
For replacement - the generator shop friend always shrugs off my requests for him to rebuild my Motorola alternators, saying that certain parts are getting hard to find. He did pull off the shelf a new "hecho in Yugoslavia" Motorola knock-off for my Rabbit that he gave me for free. I had Napa trade me for one of their remans when the bearings gave up in my van alt. Both alternators seem to work fine with the Yugoslav alt acting a little weaker at idle, judging by the flickering pilot light.
So I guess what I'm trying to say is that there isn't much available for upgrades out there.
Chris _________________ '82 TD Westy
'81 NA Caddy |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10123 Location: Where?
Posted: Thu Feb 19, 2009 10:25 pm Post subject: |
You can fit the WBX 90 amp alt if you make a longer curved adjustment arm for the alt bracket.
Andrew _________________ I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site. |
austinado16 Samba Member
Posted: Fri Feb 20, 2009 12:12 am Post subject: Re: Diesel alternator |
First a question: How do you know what the voltage output is? Are you testing right at the battery, or at the alternator, or do you have a gauge.
If the ground for the engine is clean and shiny at both ends, and bolted up tight, and the same for the battery ground, and battery postive, and you're still getting low voltage, then yes, you can probably fix yours.
The Bosch unit has a voltage regulator/brush pack assembly on the back. Simply remove the 2 screws, and pull it off. When you do, look to see if 1) the brushes are low or worn uneven 2) the ground contact with the alternator body and the bent metal tab inside are hazed/corroded over. If they are, clean them shiny and reinstall and see if that cures it. But the regulator is available new from places like www.autohausaz.com
The motorola unit has a flush voltage regulator, that's just an aluminum square housing. Remove the 2 screws, lift it out, and then carefully unplug the 2 spade connectors. Then remove the 2 screws that hold the brush pack. If the brushes are low, or worn uneven, they can be replaced. Simply go to your local hardware store and find their drawer of carbon brushes. Buy 2 that are as close as possible to your brushes, bring them him and sand them down (lay sand paper on a flat surface and then rub the brushes on the sand paper until they are the shape of your old brushes) until they fit. Then solder their pig-tails into the brush holder.
Bearings are available for both alternators and they are cheap.....or pick the seal off them, clean them out, repack them, and pop the seal back in.
Can't imagine why you'd need more than a 65am alternator on a diesel vanagon that has no ignition system and no computer to power. All you're doing running down the road is holding the magnetic fuel injection pump solenoid pin up. _________________ 4 little pistons hammering themselves silly
__________________________________________
1970 Austin America
1966 Mercedes 250SE Coupe (sunroof & 4 on the floor)
1981 Volkswagen Rabbit Diesel LX P/u
1986 Kawasaki Ninja 600R
1990 GMC 1/2ton 4x4 Suburban
1995 Audi A6 Quattro Avant |
Posted: Fri Feb 20, 2009 7:19 am Post subject: |
I would also mention that you should actually be seeing better than 14v at the battery with accessories on and revved to 2,000 rpms or so. Often, there are enough voltage drops due to age/corrosion that the battery sees a whole lot less, leading to harder starting. There is an adjustable voltage regulator available for the bosch unit for the same price as the non-adjustable one which lets you dial in the output voltage. If purchasing a new regulator, I'd always choose the adjustable one.
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10460 Location: Orbiting San Diego
Posted: Fri Feb 20, 2009 8:46 am Post subject: Re: Diesel alternator |
There are various choices. This is where I would shop for a stock replacement.
http://www.autohausaz.com/search/product.aspx?sid=...Alternator
The AL25X is the most common STOCK diesel vanagon alternator, Bosch version 65 amp.
Many times rebuilt alternators do not come with the pulley and fan. These parts can't be swapped from Bosch to Motorola so be careful. My advice is to avoid the Motorola though they work fine.
UPGRADE?
You can use a very common Bosch 90 amp to replace the 65 amp stock one. The pulley and fan will move over from Bosch 65 to Bosch 90. The adjusting bracket will now be too short as will the belt. Use the same belt as the waterpump for both alt and waterpump with a 90 amp. The alternator wiring will need modification and UPGRADE for the additional amps. The best choice of the 90 amp alternators is the AL33X as it has the W lead for the diesel tach if you need it or want it in the future. AL27X is the same 90 amp but without the tach.
Mark
Posted: Fri Feb 20, 2009 6:19 pm Post subject: |
Thanks for the responses! I'd planned to wait to post again until I've had a chance to try austinado's suggestion to check the brushes, but I haven't yet.
A few points:
I have a four led voltmeter on my cigarette lighter splitter. This gives me some idea of the voltage. I've also put a multimeter on the little power plug (Euro cig. lighter plug) next to the steering column for more accurate readings.
I have not checked the power directly at the battery or the alternator. But the erratic variability definitely suggests to me that it has something to do with the voltage regulator. The connections seem fairly clean. Some time ago, I added an extra, big ground wire from the battery to the chassis.
I have not noticed that bumps or motion effects the problem at all. I've tried messing with the wires while the engine is running, which had no effect.
Also--this is not a completely new problem. I noticed some time ago that occasionally the power would drop to around 12v, seemingly for no reason at all, and then return to around 14.
It became much worse after I accidentally ran down my battery (i left an inverter on for a few days without running the van), and then worse yet during a recent long trip.
It's a westy and I have a stereo with a 200w amp, and I have a 300w inverter, which i often use to power my laptop. I'd like to add a second battery at some point, and my headlights are slightly upgraded. So the extra power of a 90amp alt might be useful for me.
I do plan to replace the 1.6 with a td, and so if I can get by for awhile with this alternator (per austin's suggestions), it would be nice to not buy a new one. Of course, I guess I could just transfer it over . . .
Thanks again for the helpful replies. I'll pull off my alternator and look at it tonight or tomorrow. |
Posted: Fri Feb 20, 2009 7:09 pm Post subject: |
Ok, I pulled off the voltage regulator just now. Here's what I saw:
Posted: Sat Feb 21, 2009 12:17 am Post subject: |
First of all, the way your testing voltage isn't accurate. It's like those LED air/fuel ratio sensors.......as soon as someone installs one they start fixating on those LED's and complaining that their fuel/air mixture isn't right.
If you want to know what your alternator is really producing, check the back of the alternator, and check again at the battery. If you find there's a big voltage drop, replace the B+ wire from the alternator to the battery positive, with a larger diameter 4 gauge wire that you have made up at NAPA. Same advice goes for the battery and engine ground cables. Run 2 gauge cables and you'll notice faster cold cranking, faster cold starts, better charging, better glow plug action.
Regarding that voltage regulator, the brushes are getting low, but they are worn evenly, so that's good. As I suggested, clean the corrosion of the metal grounding contacts you see there on it , and the metal "tang" you see just inside the back of the alternator. Put it back together. But consider ordering a new regulator. (you have a bosch unit, by the way) _________________ 4 little pistons hammering themselves silly
1970 Austin America
hentairobsan Samba Member
Posted: Tue Sep 14, 2010 8:44 am Post subject: 65 into 90 rebuild |
| A buddy of mine suggested just having the 65 amp rebuilt into a 90 amp since it is the same size interior. That way you just reuse your alternator housing and bypass the bracket problem altogether. same old alternator shell that fits but 90 amps of new juice |
