To keep Single Master Cylinder or upgrade to Dual?
What Master Cylinder for 1960 Bus would you use?
Keep it stock single master cylinder
17%
 17%  [ 7 ]
Upgrade to dual master cylinder
82%
 82%  [ 33 ]
Total Votes : 40
amishman
amishman is offline
PostPosted: Fri Feb 20, 2009 12:53 pm    Post subject: To keep Single Master Cylinder or upgrade to Dual? Reply with quote
Starting to plot my brake work on my 1960 Single Cab that has sat for 6 years now. Already have the hoses, will be buying some wheel cylinders as I am not sure my old ones are up to snuff, and figure I will also replace my Master Cylinder as again, it has sat 6 years or so. Not really sure it is a good idea to try and keep all the old cylinders and figure just replace them all to make sure I have good brakes.
Anyway, since these old buses have single master cylinder, I have been thinking of making it even more save and upgrade to a dual master cylinder.
So, just seeking opinions, if you owned a vintage 1960 bus, would you keep it stock and replace with a like single or do you prefer to play more on the safe side and upgrade to a dual?
Thanks,
TJ
tj (the Amishman)
Come visit my web site!
http://www.vwhippie.com
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Fri Feb 20, 2009 12:54 pm    Post subject: Reply with quote
For the extra margin of safety, I think it is worthwhile, especially if you're looking at rebuilding the system anyway.
crofty
Judas of the North
crofty is offline
PostPosted: Fri Feb 20, 2009 1:01 pm    Post subject: Reply with quote
Dual circuit brakes are definitely safer for a daily driver. You'll be fine with the stock one though. Wink
HamburgerBrad wrote:
dstefun
dstefun is offline
PostPosted: Fri Feb 20, 2009 1:03 pm    Post subject: Reply with quote
Unless you're shooting for a 100 point concours restoration, I'd always go for the added safety. It's simple, it's quick, and it's not expensive.
The dual upgrade is explained in detail here:
http://www.type2.com/library/brakes/dualmas.htm
http://www.aircooledtech.com/dual_MC_upgrade/
splitsick
splitsick is offline
PostPosted: Fri Feb 20, 2009 4:45 pm    Post subject: Reply with quote
x2
Atlantic
Atlantic is offline
PostPosted: Fri Feb 20, 2009 4:49 pm    Post subject: Reply with quote
man, my breaks give me so much trouble. Should have done the upgrade right at the beginning when the first problem occurred.
I guess an other advantage besides the safety is that if you work on either of the brakes only the front or the back brakes have to be bled accordingly.
azenlunatic
azenlunatic is offline
PostPosted: Fri Feb 20, 2009 5:20 pm    Post subject: Reply with quote
Upgrades are good!
On my 67 , though, I am headed back to a single-circuit master cylinder. I think they are ok if you routinely check for leaks, keep the shoes adjusted, etc.
And there's that thing about the 67-only master cylinder costing a shade over two hundred bucks... Confused
Good luck on whichever route you choose!
-Rob
microbus
microbus is offline
PostPosted: Fri Feb 20, 2009 5:28 pm    Post subject: Reply with quote
X3
Darsh Import/ Dubsport Inc... my own VW Parts and Repair shop.
Automotive Service Technician
Mowser
Mowser is offline
PostPosted: Fri Feb 20, 2009 6:17 pm    Post subject: Reply with quote
azenlunatic wrote:
Upgrades are good!
-Rob
I just sold my '67 and shortly before I sold it I replaced the Master Cylinder. I looked at doing a conversion but by the time the dust settled it was damn near the same price as buying a new German '67 MC. Going back to a single circuit seems just wrong. Why not do the conversion to the newer dual circuit if you are going that route.
As for the upgrade, yes definitely go to a dual circuit. Safety is something you should Never short yourself on.
azenlunatic
PostPosted: Fri Feb 20, 2009 6:42 pm    Post subject: Reply with quote
Ok here's the 67 only mc: http://wolfsburgwest.com/cart/DetailsList.cfm?ID=211611011Q
I paid about forty bucks for a 66-down mc/reservoir combo from a local parts guy that just wanted rid of it ("don't see too many of you bus folks anymore"), so I lucked out there Smile
Procedure to do the retrofit: http://web.archive.org/web/19980110135148/type2.com/sermons/liturgy/66_to_67.html
(Thanks Mr. Hoover)
To each their own. My e-brake is well-adjusted Laughing
Sorry for hijacking your thread.
-Rob
Mowser
Mowser is offline
PostPosted: Fri Feb 20, 2009 7:33 pm    Post subject: Reply with quote
I wouldn't consider it a hijack. You've added useful information to anyone looking to do brake re and re's. This is the retro fit I was referring to.
CIP adapter plate for use of a '71 + master cylinder.
http://www.cip1.ca/ProductDetails.asp?ProductCode=ACC-C20-4100
German '71 + master cylinder
http://www.cip1.ca/ProductDetails.asp?ProductCode=C24-211-611-021-AAGR
plus a resevior
http://www.cip1.ca/ProductDetails.asp?ProductCode=VWC-211-611-313-J
Grand total is 303.07 Cdn. Yes I know there are less expensive ways to do it but these are all off the shelf items. New German '67 only master cylinder I saw yesterday on Ronnie's Website.
http://www.bustoration.com/Master-Cylinder-dual-circuit-Type-2-1967_p_467.html
$225.00 US
Culito
11010101
Culito is offline
PostPosted: Fri Feb 20, 2009 9:21 pm    Post subject: Reply with quote
I got the brazilian MC and it has never given me a problem or even the slightest leak. I think it was like 22 bucks.
Edit: Wow, and the adapter kit was only around 50 bucks when I bought it a few years ago!
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
Mikee
Samba A.D.D. Boy
Mikee is offline
PostPosted: Sat Feb 21, 2009 12:52 am    Post subject: Reply with quote
after i lost brakes going down grants pass, I suggest the upgrade, if you arn't going 100% stock
localboymark wrote:
One man's "patina" is another man's cancer.
bugnut68 wrote:
I would have kicked the guy right in the dick, balls, ass and face and destroyed his weed. Hippies suck.
Clara Premium Member
Clara is offline
PostPosted: Sat Feb 21, 2009 10:19 am    Post subject: Reply with quote
I've never bothered with the dual circuit conversion.
I did lose my hydraulic brakes completely once. This was back in the eighties, before I knew that rubber brake hoses existed. One blew on HWY 101 between Crescent City and Eureka. The brakes got hot and stinky coming down a mountain, I think the hose stuck and the pistion stayed. The wheel cylinder was warped. I knew something was wrong before that trip, but I didn't know about hoses, they weren't in the Idiot Book and the Bentley hadn't come out yet.
I did have the hand brake. You can also downshift to help slow down in case of emergency.
I have not had any issues when the brakes are in order.
I'm not saying dual is a bad thing, but I haven't done it. The question in the poll was "What would you do?"
Mikee's brakes were not in order when he had a failure. He knew that.
It was not out of the blue that something blew.
So if you are the kind of person who will fix them 'after the trip', ya go dual circuit.
VolksFire
VolksFire is offline
PostPosted: Wed Apr 01, 2009 11:53 pm    Post subject: Reply with quote
i replaced the master cyl on my 60 dd panel bus a year and a half ago. i went with the stock single circuit one. no complaints.
Jahnai Pearson - VW Restoration Technician
Current ownership (always changing):
60 Double Door Panel
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
79 Dasher Wagon
82 Quantum Coupe
96 Golf GL
CoastalAirCooledVW
CoastalAirCooledVW is offline
PostPosted: Wed Jul 10, 2013 12:07 am    Post subject: Reply with quote
Out of curiosity and the bashing of brazilian parts....how is that MC doing today?
1966 Velvet Green Standard
Culito
11010101
Culito is offline
PostPosted: Wed Jul 10, 2013 9:05 am    Post subject: Reply with quote
No issues...
'62 bug
johnnypan wrote:
CoastalAirCooledVW
PostPosted: Wed Jul 10, 2013 10:33 am    Post subject: Reply with quote
No issues...
I knew that they couldnt be as bad as everyone says...
