accelerator tube question
PghGhia
PghGhia is offline
PostPosted: Thu Mar 12, 2009 2:02 pm    Post subject: accelerator tube question Reply with quote
I installed an accelator cable yesterday complete with new flex tube and hard tube that fits through the fan shroud.
While the flex tube has a boot where it mates to the exit tube from the tunnel, is there a boot where the flex tube meets the hard tube from the shroud? And the hard tube seems to hold in place by a grommet on the motor side of the shroud?
Am I missing any peices or is this the way it is to be? It would seem the hard tube can work its way along the cable towards the carb and the joint between it and the flex tube would open up.
thanks!
69 Jim
69 Jim is offline
PostPosted: Thu Mar 12, 2009 2:23 pm    Post subject: Reply with quote
I install a fuel line size hoseclamp behind the fanshroud on the rigid tube, it seems to work well for me. Good luck.
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Thu Mar 12, 2009 4:07 pm    Post subject: Reply with quote
The hose clamp deal works good, I've never had any problems with doing it that way.
-Andy
redrum71
redrum71 is offline
PostPosted: Thu Mar 12, 2009 4:43 pm    Post subject: Reply with quote
Ditto, I had that problem and did the hose clamp trick about a year ago, no problems since
VW Logo 72 FAT chick Blue Bug
VW Logo 71 baywindow Red Bay Bus -
VW Logo 67 Baja Green Bug
Cusser
Cusser is offline
PostPosted: Thu Mar 12, 2009 5:07 pm    Post subject: Reply with quote
Yeah, me too. For over 25 years.
PghGhia
PghGhia is offline
PostPosted: Thu Mar 12, 2009 7:49 pm    Post subject: Reply with quote
thanks for the replies guys and thanks for the pic glutamodo - I'll do the same!
DrDarby
DrDarby is offline
PostPosted: Thu Mar 12, 2009 8:07 pm    Post subject: Reply with quote
Indeed, that hose clamp is a must have part.
Midwest Autosavers, Inc. Crystal Lake, IL
The Android
PostPosted: Fri Mar 13, 2009 1:08 pm    Post subject: Reply with quote
One more tip, get a 1/4" nutdriver (or whatever the fastener size is on there, usually it's 1/4 for small hose clamps) to tighten the hose clamp. Works a lot better than a screwdriver because you're working blind in there and a nutdriver won't slip off.
-Andy
VOLKSCARTER71
VOLKSCARTER71 is offline
PostPosted: Fri Mar 13, 2009 1:44 pm    Post subject: Reply with quote
my hose clamp is still holding strong for 6 years... yay
__________________
71 Beetle Std (Everyday Driver! 1600cc Hydraulic Valves Single port 32 PICT Carb woohoo!)
