Door Buzzer Works!
1979westie
1979westie is offline
PostPosted: Fri Mar 27, 2009 8:08 pm    Post subject: Door Buzzer Works! Reply with quote
Ever since I have owned this bus, the door buzzer has not worked. Actually, the PO removed it, as most bus owners seem to do because, well, it sounds like a dying cricket in a tin can. But I pulled a unit off the parts bus I had last year and finally hooked it up. I'm delighted. For now.
I'm sure in two weeks I'll be ready to rip it out and smash it with a framing hammer. Laughing
Your car may do 0-60 in under 5 seconds, but can it sleep 4 and cook a meal?
1979 Deluxe Campmobile (quickly rusting away)
33K miles when bought, now at 61K
Proud Member #2 SBS (Stock Bus Society)
TrollFromDownBelow
TrollFromDownBelow is offline
PostPosted: Fri Mar 27, 2009 8:21 pm    Post subject: Reply with quote
naaa. you don't want to pull it off! I bought my '76 westy about 4 years ago and was actually a little delighted that it worked.... to me it's a badge of courage! Although, I would describe the sound as a cricket who OD'd on steriods and is dying in a tin can Wink
1976 Westy (aka Tripod)
2.0 liter FI solid lifters
212k miles
busdaddy
busdaddy is offline
PostPosted: Fri Mar 27, 2009 8:30 pm    Post subject: Reply with quote
Congratulations!
Give it time, you'll tire of it soon enough Smile
Слава Україні!
josh
josh is offline
PostPosted: Fri Mar 27, 2009 8:58 pm    Post subject: Reply with quote
I bought a bus once that had a working door buzzer. It was gone in about a week. I hated the sound of that F#^%$ thing.
I wouldn't be surprised if the buzzers from '80s and '90s water cooled VWs could be substituted. They very annoying rather than extremely grating. I never missed having a door buzzer enough to find out though.
modok wrote:
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold
VDubTech
VDubTech is offline
PostPosted: Fri Mar 27, 2009 9:14 pm    Post subject: Reply with quote
The buzzers on my '74 and '79 both work, never bothered me. I guess I just don't spend a whole lot of time with the door open and the keys in the ignition.
Mike C
Mike C is offline
PostPosted: Fri Mar 27, 2009 9:20 pm    Post subject: Reply with quote
The buzzer on my '70 works. I think it's pretty neat. Brings back memories of the old bus my folks had in the 70s.
type2sam
type2sam is offline
PostPosted: Sat Mar 28, 2009 1:43 am    Post subject: Reply with quote
I replaced the original door buzzer in my '73 with the door chime relay from an '89 VW Fox. Plugged right in. Somewhat more pleasant than the dying cricket.
Ombit
Ombit is offline
PostPosted: Sat Mar 28, 2009 2:59 am    Post subject: Reply with quote
Door Buzzer? Mine doesn't have it. What's it for - to alert you to the door being open when setting off??
Where are the mechanics of it, I'd like to have a look and see if any of it remains.
Ombit
1973 VW Deluxe Bus 1700E Automatic
Ernie - The only Automatic Bay in Cyprus
VWBusrepairman
VWBusrepairman is offline
PostPosted: Sat Mar 28, 2009 4:52 am    Post subject: Reply with quote
I had an '89 Fox! The chimes sound like an icecream truck song or something.
Is the Door Buzzer located in the fuse panel? I may try to get mine working as well, so I can spend some time with VDubtech having the key in the ignition and the door open just to hear the sound.
type2sam
type2sam is offline
PostPosted: Sat Mar 28, 2009 6:13 pm    Post subject: Reply with quote
Ice Cream Truck song is a good way to describe it. 3 separate ascending notes, then repeat.
It is #12 in the fuse panel. Here is a diagram from the Fox Bentley...
Here's a close-up of the relay...
And here is a pic of it installed - notice how the end has a grille and a speaker. Pretty easy to identify.
When the IAC engineer was out last year and put the key in the ignition for the test drive, the look on his face was priceless.
Krautski
Krautski is offline
PostPosted: Sat Mar 28, 2009 7:57 pm    Post subject: Reply with quote
Mine works. Then again, everything except the gas heater is in working order.
The previous owner took pretty good care of it, for all the electrical shit to be working. Smile
fusername
fusername is offline
PostPosted: Sat Mar 28, 2009 8:07 pm    Post subject: Reply with quote
I;m sorry but have you ever heard a vanagon door buzzer?
DOO BOO BEE
DOO BOO BEE
DOO BOO BEE
you just want to stab it in teh face 3 rounds in. sooo horrible.
soo who wants to buy mine? i carry it around in my electrical bag, to test for power like a test light, only so much more annoying, and I can hear it from farther away.
[email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote:
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine!
1979westie
PostPosted: Sun Mar 29, 2009 2:50 pm    Post subject: Reply with quote
I've got the doo-boo-bee triple note chime in my 91 GTI. I think I'll leave it there and stick with the dying cricket for the bus. I'd like to open one up to see what the mechanism inside looks like. Ratwell must have a pic somewhere...
vw76westy
vw76westy is offline
PostPosted: Sun Mar 29, 2009 6:46 pm    Post subject: Reply with quote
ok so now we know where to find one on a jetta
but where is it, in the bay
does it it use the same sensor button on the door
that is used for the lights to work
i want to say mine worked when i first got the bus
but that was a long time ago
(haha maybe i ripped it out then & just dont remember)
White99z
White99z is offline
PostPosted: Sun Mar 29, 2009 10:48 pm    Post subject: Reply with quote
Wow... theres a door buzzer?!? Glad mine doesn't have it!
Emeritusx
Emeritusx is offline
PostPosted: Mon Mar 30, 2009 7:51 pm    Post subject: Reply with quote
It tells you your key is in the switch so there is a circuit there and yes your dome light ground switch makes it buzz. I pulled mine, 'stgawdawful cacophony.
82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠
jamesdagg
jamesdagg is offline
PostPosted: Mon Mar 30, 2009 8:01 pm    Post subject: Reply with quote
What you are missing is the great feature that if you put a male spade connector on the yellow switched wire from your stereo and plug it into the buzzer socket #85 from the ignition switch you will have an accessory position.
You can listen to the stereo with the engine off as long as you leave the key in the ignition. As soon as you pull it out, stereo goes off.
It's pretty easy to convert the buzzer to buzz if you forget the headlights on as well.
In fact you can do both.
Note though if you have a big high amp stereo use this wire to trigger a relay as it's a low amp circuit.
jim
'72 FI Westy
'71 Super rear inside defrost vents no longer available
vw76westy
PostPosted: Tue Mar 31, 2009 12:29 am    Post subject: Reply with quote
since we are talking about the wiring
i put a interior dome light in the kick panel
& i want it to turn on when the door is open
but i cant figure out how without running wires all the way to the dome light
that light will turn on when the door is open
can you help me there
i tried hooking up directly to the button on the door but it did not work
Emeritusx
PostPosted: Tue Mar 31, 2009 9:09 am    Post subject: Reply with quote
go from +12 to a fuse (or from a fuse) to the bulb to the switch on the door (It makes ground)
vwwestyman
vwwestyman is offline
PostPosted: Tue Mar 31, 2009 12:42 pm    Post subject: Reply with quote
jim
I've done that trick on more than one VW.
I could be wrong, but I don't think you'd need to relay it for just a CD player. I think that they draw all their power for running, playing, etc through the same source as the memory (usually the red wire). I think the keyed wire (usually yellow) is simply a trigger to turn on with the key, sort of a relay wire in itself.
