Sebring exhausts for 356?
Hebster52
Hebster52 is offline
PostPosted: Mon Feb 16, 2009 4:07 am    Post subject: Sebring exhausts for 356? Reply with quote
Wondering how the "collector" (exhaust tip) is designed inside?
Maybe like this?
~Kris~
"The Hebster52" my Hebmuller replica build
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
Hebster52
PostPosted: Fri Feb 27, 2009 12:14 am    Post subject: Reply with quote
No one seems to know?
I guess I have to see what's the outcome myself then. Wink
This is how I've built it so far.
~Kris~
The 912ST
The KidVRod project
TC/TeamEvil
TC/TeamEvil is offline
PostPosted: Fri Feb 27, 2009 10:53 am    Post subject: Reply with quote
That's probably gonna be pretty loud as it's configured right now. The inside of mine has two baffle plates rather than a straight through mesh option. Maybe a small disk inserted within the mesh "tube" sections would work. Something to chop up the exhaust flow and divert it to the other exit in some fashion. In on the left, hit the disk, chopped up a bit as it flows around the disk and exits through both of the holes, same for the right side. Just stagger the positioning of the plates, or bend them "V" shaped or ?.
Maybe that kinda thing? Maybe not. Either way, I LOVE your craftsmanship ! ! ! ! ! !
Although, if you're building resonators as opposed to mufflers, those are comin' out GREAT and tuned resonators might be just what's needed.
TC
Hebster52
PostPosted: Fri Feb 27, 2009 11:25 am    Post subject: Reply with quote
Not sure what the difference between muffler and resonator is? Mine will be filled with fiber around the perforated pipes and flow straight through as in this example:
I have talked to some 356 owners that have this type of exhausts and their have been like this.
~Kris~
The 912ST
The KidVRod project
TC/TeamEvil
PostPosted: Fri Feb 27, 2009 1:23 pm    Post subject: Reply with quote
Home made glass packs!
Cool.
Hebster52
PostPosted: Mon Mar 02, 2009 3:24 am    Post subject: Reply with quote
Yes, maybe that's what they should be called. Very Happy
~Kris~
The 912ST
The KidVRod project
swanlakers
swanlakers is offline
PostPosted: Mon Mar 02, 2009 5:28 pm    Post subject: Reply with quote
Does anyone have pictures of the inside of a sebring exhaust? I have searched the net with no luck
But here is a pic of the outside from Mr Okrassa
https://www.thesamba.com/vw/archives/lit/56ghia/cover.jpg
Hebster52
PostPosted: Fri Mar 06, 2009 12:07 am    Post subject: Reply with quote
Cool vintage exhaust! That one is for the 550 spyder isn't it?
~Kris~
The 912ST
The KidVRod project
swanlakers
PostPosted: Sat Mar 07, 2009 3:51 pm    Post subject: Reply with quote
well, it might be for the 550, but here are some more pics to consider:
Hebster52
PostPosted: Tue Mar 17, 2009 2:48 am    Post subject: Reply with quote
Some inspiration. Cool
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Fri Mar 20, 2009 12:09 am    Post subject: Reply with quote
Finally got myself out to the garage again with new welding gas. Cool
As I was out pretty late I didn't take the time to finish off all welds but had to leave them as in the pictures. You start to see the finished product though. Wink
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Mon Mar 30, 2009 3:23 pm    Post subject: Reply with quote
Going real slow right now..
Got myself to the garage tonight though and got some work done.
Started fitting the upper halves of the mufflers and also made the final exhaust tip. Not yet welded them though
~Kris~
The 912ST
The KidVRod project
Niklas the Swede
Niklas the Swede is offline
PostPosted: Thu Apr 02, 2009 12:24 pm    Post subject: Reply with quote
Looking perfect Hebster! Keep up the good work.
VWXTC4FREE
VWXTC4FREE is offline
PostPosted: Thu Apr 02, 2009 11:21 pm    Post subject: Reply with quote
LOOKIN GOOD Cool
A freind of mine did a custom one for his '57 356 outlaw.He used something like steel wool for the packing in the mufflers.
" I'm a motovational speaker ....and I LIVE IN A VAN DOWN BY THE RIVER!!"
Simple Transport III AUG 21 2010 :
http://www.thesamba.com/vw/forum/viewtopic.php?t=391461
http://www.myspace.com/warwagens
Hebster52
PostPosted: Thu Apr 02, 2009 11:37 pm    Post subject: Reply with quote
Thanks. Cool
I bought glassfiber wool for Bike mufflers. Tested to expose some of it directly to a seam I welded and it didn't burn or anything so it will be good for these mufflers too. Wink
~Kris~
The 912ST
The KidVRod project
atomman1
atomman1 is offline
PostPosted: Fri Apr 03, 2009 12:29 am    Post subject: Reply with quote
looking goood dude Cool
Just about to get some flanges water cut so i can make one for my 912,
will get some pic's up when i get started
bt
bt is offline
PostPosted: Fri Apr 03, 2009 8:37 am    Post subject: Reply with quote
Thats Badass!!!
Is weight going to be a problem? It looks very light but is that going to cause a fulcrum point?
Hebster52
PostPosted: Fri Apr 03, 2009 11:09 am    Post subject: Reply with quote
It is pretty lightweight.
What's a fulcrum point..?? Laughing
~Kris~
The 912ST
The KidVRod project
bt
bt is offline
PostPosted: Fri Apr 03, 2009 7:10 pm    Post subject: Reply with quote
Will it need another mounting point to keep the weight off the heads?
Hebster52
PostPosted: Fri Apr 03, 2009 11:54 pm    Post subject: Reply with quote
Not sure if it does need any mountingpoint..
The ones posted above dont seem to have any either and those look even longer/heavier?
I've thought about making one support that bolts to the rear enginemount when that is bolted to the case.
~Kris~
The 912ST
The KidVRod project
