Spark Plug choices
Page: 1, 2, 3  Next
55veedub
55veedub is offline
PostPosted: Sun Apr 05, 2009 2:10 pm    Post subject: Spark Plug choices Reply with quote
What would be good plugs to run in a stock 1970 beetle engine?
are there some that have found to be better than BOSCH? Champion?
If there are better plugs to run, what are they and what nunber? does anyone know of a chart with the different manufacturer cross-references?
thanks
CoastalDefender
CoastalDefender is offline
PostPosted: Sun Apr 05, 2009 2:26 pm    Post subject: Reply with quote
I hear Bosch Platinum +4 are the best there is.
http://www.boschautoparts.com/Products/SparkPlugs/Platinum4.htm
Last edited by CoastalDefender on Sun Apr 05, 2009 2:28 pm; edited 1 time in total
SkrapMetal
Samba Hornblaster
SkrapMetal is offline
Bosch copper W8AC or NGK B5HS.
oo9less since 2007
-72 Ghia-
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Apr 05, 2009 2:27 pm    Post subject: Reply with quote
I've been using NGK for the past 10 years and have been happy with them.
First off you know which which heads you have of if they use 1/2" or 3/4" reach plugs?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Mr. 010
Glenn is offline
PostPosted: Sun Apr 05, 2009 2:28 pm    Post subject: Reply with quote
You're assuming they are not 3/4" reach heads. If they were 3/4" then W8CC or B5ES would be the plugs to get.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
CoastalDefender
Dumb question time-
How would one go about discovering which they had?
Mr. 010
Glenn is offline
PostPosted: Sun Apr 05, 2009 2:29 pm    Post subject: Reply with quote
Never, ever user platinum plugs in a air cooled VW engine
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Mr. 010
Glenn is offline
PostPosted: Sun Apr 05, 2009 2:30 pm    Post subject: Reply with quote
Dumb question time-
Remove the old plugs and hope hay are correct or remove the valve covers and find the casting markings and see which they use.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
CoastalDefender
PostPosted: Sun Apr 05, 2009 2:50 pm    Post subject: Reply with quote
Burn too hot?
SkrapMetal
Samba Hornblaster
PostPosted: Sun Apr 05, 2009 3:00 pm    Post subject: Reply with quote
Burn too hot?
They're just crap and they cause misfiring. I'm sure they work fine for other applications though.
oo9less since 2007
-72 Ghia-
vintageorbust
vintageorbust is offline
PostPosted: Sun Apr 05, 2009 4:38 pm    Post subject: Reply with quote
What would you recommend running in a very hot climate? A cooler plug? I hooked my bug up to the smog machine and tuned it to damn near perfect and the plugs are showing signs or running hot. How long should you run a set of plugs?
Meredith Phillips
Silly riceboys... useless wings are for penguins!
Chicks that can work on their own cars?! Yeah I know we're hot =)
mnussbau
mnussbau is offline
PostPosted: Sun Apr 05, 2009 4:55 pm    Post subject: Reply with quote
So what markings would indicate which plugs?
Mike
‘74 bug vert
Parts...
a.graham52
a.graham52 is offline
PostPosted: Sun Apr 05, 2009 5:20 pm    Post subject: Reply with quote
iv actully replaced ignition moduals on 1999+ vehicals becuase these plugs have less resistance then normal plugs and cuases the modual to fry over time.
Mr. 010
Glenn is offline
PostPosted: Sun Apr 05, 2009 6:28 pm    Post subject: Reply with quote
041, 042, G01, G03......
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Wilfredo R
Wilfredo R is offline
PostPosted: Sun Apr 05, 2009 7:11 pm    Post subject: Reply with quote
What's wrong with useing platinum spark plugs? I use them and lately have had no problems
Mr. 010
Glenn is offline
PostPosted: Sun Apr 05, 2009 7:13 pm    Post subject: Reply with quote
They're a waste of money.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
TallCity
TallCity is offline
PostPosted: Sun Apr 05, 2009 7:34 pm    Post subject: Reply with quote
I had read some where that the Bosch Platinum +4 were designed as a spark plug for turbo cars (H20 cooled). The four prong is to make sure that at least one electrode makes a spark. True..Untrue.. I don't know but they do cost a lot more money.
Semper Fi
Money does not buy you COMMON SENSE but it does buy you a better COFFIN.
Chrome don't get you home.
a.graham52
PostPosted: Sun Apr 05, 2009 7:41 pm    Post subject: Reply with quote
i dont know about the turbo part but my ASEP teacher said the same about the electrodes. pretty-much the four electrodes just give the smark its choice on how to get back to ground. in theory its great and i have noticed that my 95 golf liked them... i dont recommend them on dizzyless systems.
Wilfredo R
PostPosted: Mon Apr 06, 2009 4:52 am    Post subject: Reply with quote
So they don't last longer than super like any other car? Cause on my fox, they last longer than supers. So i'm guessing thats why at my local volkswagen shops, they only sell Bosch super and NGK spark plugs...
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Mon Apr 06, 2009 5:33 am    Post subject: Reply with quote
Well, I won't use Platinums even on watercooled cars. I've used Bosch series 3-terminal copper plugs on my Golf for years, those the highest milage copper plugs I think you can get. Silver-core plugs were used on later watercooled VW models for high-milage spec plugs too. I'd rather use either of those than Platinums.
However, you can't them in standard reach plugs for aircooled engines.
I think the jury is still out as to how well the new WR8AC+ plugs that Bosch makes now work out for longevity. W8ACs though, I've never had problems with them, even at very high milage.
Page: 1, 2, 3  Next
