AC.net/aircooled.net HD alu pushrods
Page: Previous  1, 2, 3  Next
Alan_U
Alan_U is offline
PostPosted: Tue Apr 07, 2009 7:20 am    Post subject: Reply with quote
Eaallred wrote:
I've been toying around with the idea of the dual tapered aluminum in my race car. It see's 9000rpm with K-800's and heavy 48mm intake valves. It's tempting to try, but i'll probably wait until I go Ti valves at least.
Eric,
Your probably better off using ultra light ti valves with tapered chromoly for added clearance in the pushrod tube.
At 8500rpms or so you dont need k800's with ti. The "regular" chevy springs should be enough.
11.92sec pump gas true daily driver. Who says it cant be done.
No more time for VW's.......
1961bluebug
1961bluebug is offline
PostPosted: Tue Apr 07, 2009 7:43 am    Post subject: Reply with quote
Does anybody know what is the typical pressure of VW dual springs? Thanks.
Alan_U
Alan_U is offline
PostPosted: Tue Apr 07, 2009 7:46 am    Post subject: Reply with quote
Different variations out there. Length of valve stems will change seat pressure and cam lift and ratio rockers will effect pressure at the nose of the cam at full lift.
Eaallred
Eaallred is offline
PostPosted: Tue Apr 07, 2009 8:55 am    Post subject: Reply with quote
Alan_U wrote:
Eric,
Yea, my plan (eventually if money issues don't keep getting in the way) is to send my heads down to Jeff Denham and have him install Ti and re-do the valve springs to what he feels they should be. I'll need to decide between alum and chromo pushrods at that time. Alum is big diameter. I've switched to waterboxer tubes for more clearance, I don't know how close the alum will be though. Might have to buy a single and check it out at that time.
If I don't sell the car that is. I just finished a major project on it that is making me want to keep it now, hahaha
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
Max Welton
Max Welton is offline
PostPosted: Tue Apr 07, 2009 9:52 am    Post subject: Reply with quote
Eric, would you also be factoring in the pushrod weight difference in spring selection?
Max
1967 Type-3 Fastback
krusher
krusher is offline
PostPosted: Tue Apr 07, 2009 10:53 am    Post subject: Reply with quote
I have the aircooled.net alu pushrods on my 112hp 1800, very happy, much quieter that the horrible cr-mo's i had before.
Cant say a bad thing about them.
(06:31:07) RoachGhia: "i drink dick way too fast"
Eaallred
Eaallred is offline
PostPosted: Tue Apr 07, 2009 12:37 pm    Post subject: Reply with quote
Max
I would have Jeff do that. That's why I would need to decide if I were going to switch to alum or keep my chromo before I were to send him my heads. I could get quite a few more rpm's out of this motor with Ti valves and alum pushrods.
Eric Allred
bigsid
bigsid is offline
PostPosted: Wed Jun 10, 2009 11:39 pm    Post subject: Reply with quote
On a related topic, would HD aluminum pushrods be set with the same valve clearance as a stock pushrod ?
Teeroy Premium Member
Teeroy is offline
PostPosted: Wed Jun 10, 2009 11:42 pm    Post subject: AC.net/aircooled.net HD alu pushrods Reply with quote
I'm running my with stock lash, no problems.
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
nsracing
nsracing is offline
PostPosted: Thu Jun 11, 2009 8:14 am    Post subject: Reply with quote
The rule w/ pushrods is they have to be as stiff as possible...especially the exhaust side.
I only WISH the aluminum pushrods available are as stout as the stock Type IV size. I wonder if they can be had w/ wall thickness as Bus pushrods.
I like the BERG chromoly and use them exclusively for large strokers w/ heavy springs.
I have machined/ sized AC.NET aluminums for strokers. I wish they are much fatter.
[email protected]
john@aircooled.net is offline
PostPosted: Thu Jun 11, 2009 8:37 am    Post subject: Reply with quote
our Dual Tapered are much stronger, if you are worried about that. They are also more $.
John
Aircooled.Net Inc.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
nsracing
nsracing is offline
PostPosted: Thu Jun 11, 2009 9:22 am    Post subject: Reply with quote
John,
Can the heavier aluminum pushrods be ordered without the tapers?
I really like them just consistent diameter along its entirety. That will also be something if they come the size of Bus pushrods.
[email protected]
PostPosted: Thu Jun 11, 2009 9:24 am    Post subject: Reply with quote
I don't know. In ME classes you learn that the additional diameter is NOT NEEDED at the ends, since the ends do not flex.
John
Aircooled.Net Inc.
nsracing
nsracing is offline
PostPosted: Thu Jun 11, 2009 9:33 am    Post subject: Reply with quote
John
Aircooled.Net Inc.
I know but it is just easier to chuck and cut the darn thing on the lathe to size. So you do not have a work stick-out of 6 inches! Very Happy
[email protected]
PostPosted: Thu Jun 11, 2009 9:38 am    Post subject: Reply with quote
THAT IS TRUE!
Bruce
Bruce is offline
PostPosted: Thu Jun 11, 2009 11:11 pm    Post subject: Reply with quote
... the additional diameter is NOT NEEDED at the ends, since the ends do not flex.
I concur. The extra diameter to the ends just adds weight and no strength since there's no bending happening at the tips.
[email protected]
PostPosted: Fri Jun 12, 2009 6:52 am    Post subject: Reply with quote
BTW, this is also why factory pushrods are straight and not tapered.
John
Aircooled.Net Inc.
youngstah
youngstah is offline
PostPosted: Fri Jun 12, 2009 7:11 am    Post subject: Reply with quote
What about heat transfer, would non tapered be a more even distribution of material accounting for this?
Can someone post a picture of a stock vs bus vs fancypants (aircooled) pushrod next to each other in the same pic? ...for visual contrast of scale.
the caveman
the caveman is offline
PostPosted: Fri Jun 12, 2009 1:26 pm    Post subject: Reply with quote
I run AC.NET ones on my 2165 [94x78] CB 044's w/duals and dual 44mm idf's . I also spent the time to do the valve train geometry properly at the same time at my last rebuild. The days of valve train noise and constant adjustments seem to be over. I don't usually pull more than 6500 rpms; and am now very happy.
Bruce
Bruce is offline
PostPosted: Sat Jun 13, 2009 10:47 pm    Post subject: Reply with quote
Heat transfer? From where to where?
Page 2 of 3
