carterzest Samba Member
Joined: January 22, 2008 Posts: 3841 Location: Eagle, ID/Sun Valley, ID
Posted: Thu Apr 09, 2009 8:17 am Post subject: |
H O L D M E !
| Quote: |
There are a couple guys here in Portland that want to take a look at my new Zetec and our schedules have not lined up yet.
I think I was one of the first Bostig comments after your new baby gave up the ghost right after the engagement ring, the wedding ring, the suffering! Great write up and I cannot wait for our wives to meet! I am one, if not The One, that has drug thine feet for the automatic package from Bostig. I hear it may be coming, soon? However, I have not yet been afforded with the experience of driving with a Subaru at mine foot.
I still think the stock engine is adequate........ For ME TO POOP ON
Cannot surf SAMB at work anymore. It sucks!
| climberjohn wrote: |
Drew,
Well, I am one of those Portland guys, and it sounds like you have done a fine job. Thanks for the write-up. I am sure we can meet up soon. |
H O L D M E ! _________________ Happiness=Portland, Oregon in the rearview mirror! |
Crankey Samba Member
Posted: Thu Apr 09, 2009 5:41 pm Post subject: |
| can you run 87 octane in it ? |
mtnwater Samba Member
Posted: Thu Apr 09, 2009 8:15 pm Post subject: |
| Crankey wrote: |
With the normally aspirated version, yup - no problem. Not sure what the fuel requirements might be for the turbo. |
Der-ak Samba Member
Joined: September 05, 2006 Posts: 61 Location: Kitchener, Ontario, Canada
Posted: Thu Apr 09, 2009 9:00 pm Post subject: |
| carterzest wrote: |
BAHAHAHAHA!
carterzest FTW!
 _________________ '91 Westy, 2.1L WBX, MT, Orly Blue - "Steve": Temporarily off the road waiting for new brake lines.
'90 Westy, 2.1L WBX, MT, White - "Fiona": Recent "Barn Find", Sat for 10yrs. Currently being brought back to life.
'88 Westy, 2.1L WBX, MT, Dove Blue - "Suzie": Rear ended and written off.
| carterzest wrote: |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10785 Location: Western WA
Posted: Thu Apr 09, 2009 9:45 pm Post subject: |
| mtnwater wrote: |
| vinnyvango wrote: |
| As an engineer (with a lot of background in fluids) I'd say it's not theoretical...It's turbulent vs. laminar flow. Most intakes are designed to "remedy" turbulent flow within a few pipe diameters. |
Agree that turbulant vs. lamanir flow is real, I'm just not sure that turbulant flow through the intake is significant enough to "restrict" the intake in an appreciable way. I could be wrong. |
The hotrod folks spend hundreds of hours with little grinders removing every bump in an intake tract, grinding welds smooth on exhaust headers, matching manifold gaskets to make the engine breathe well. They spend hours and hours then sit there all satisfied, with a cigarette, after removing the disruptive equivalent of one inch of that corrugated pipe.
I bet the ribbed pipe reduces the effective diameter to half that of a smooth pipe. A few HP increase might provide an mpg increase too. Smooth exhaust pipe and rubber elbows at the corners might be a lot less restrictive and low cost too. I'll bet it would be worth the effort to smooth it out. I wouldn't know what to say about the noise problem. All guesses here.
If the dyno shows only 2-4 hp, that's not very much to worry about.....considering the ease of the rest of the conversion; the intake duct is easy to deal with later. A reliable exhaust is much more important from the beginning than an intake tract. The big part is getting the engine in there, start it up and go camping. Spring is here (in the NW). _________________
....KTMs, GasGas, SPOT mtb
Crughy Samba Member
Joined: July 12, 2004 Posts: 576 Location: Montreal, Qc
Posted: Fri Apr 10, 2009 6:06 am Post subject: |
Why not simply go with a bigger intake (except where the engine mates) and air filter.
Not like a big funnel. but simply over sized to reduce restriction.
There can't be too much air.
Why is this a pb?
JP |
Loosenut893 Samba Member
Posted: Fri Apr 10, 2009 6:14 am Post subject: |
| What kind of mileage does eveyone get with the Bostig? |
Williamtaylor33 Samba Member
Joined: September 07, 2007 Posts: 1545 Location: Arkansas
Posted: Fri Apr 10, 2009 8:06 am Post subject: |
I'm getting 19 around town and 22 on the highway _________________ 89 Bostig powered syncro westy |
Posted: Fri Apr 10, 2009 5:35 pm Post subject: |
| I don't see why the intake is running across the engine bay, why not fit the air box on the same side as the TB ? |
bostig Samba Member
Posted: Fri Apr 10, 2009 11:52 pm Post subject: |
| Crankey wrote: |
Lot's of valid questions, the main reason for not keeping the same side of the engine bay is the ECU box is behind the Driver's taillight.
The reason for not going larger is cost + fitment + noise attenuation doesn't equal a return in performance equivalent to the effort. Someone pointed out how much time folks spend smoothing and touching up little aspects of the intake tract... we've had quite a bit of experience with head porting and our own in-house flow bench... very rarely does it make sense to do as much work as folks are willing to pay for to improve flow in most situations. Typically it's a matter of this is theoretically correct, therefore this must have a tangible effect, when in fact this is rarely the case, especially when weighed against the cost and/or effort of doing so. Compressible fuilds like air DO NOT respond or act as common sense dictate, period. Anyone that applies a flowing water metphor for instance will quickly be surprised at how little it applies and how easily they will mislead themselves.
The vast majority of money spent on even "substantial" things like head porting, are wasted because the rest of the system isn't optimized to take advantage of it... esp when it can and has been measured. Speculation is all well and good, but it yields nothing. Testing on the other hand yields substantially more. This isn't to say there aren't more solutions to the problem, but folks are paying us to make the best use of their conversion dollar, and we do what we believe that is.
Jim Akiba |
Posted: Sat Apr 11, 2009 3:04 pm Post subject: |
| Quote: |
ok, so if you have a doka then you have lots of access to the vents on either side you can do whatever works best ? cool ! |
240Gordy Samba Member
Joined: May 15, 2008 Posts: 2354 Location: Vancouver, BC
Posted: Sat Apr 11, 2009 3:12 pm Post subject: |
| Crankey wrote: |
| Quote: |
and the engine compartment has a little more headroom ! _________________ Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR |
DeadSetMonkey Samba Member
Joined: April 15, 2010 Posts: 532 Location: Denver, CO
Posted: Sat Feb 23, 2013 8:28 pm Post subject: |
| mtnwater wrote: |
| Swing - I converted my van from an EJ22 to the Bostig V2.0 zetec. Not only is it possible, I believe that in some ways it's easier than converting from the wbx. There are a few nuances that you would need to pay attention to, but as others have noted the support from Bostig guys and the other Bostig customers is fantastic. Go for it! |
so. EJ22 vs Bostig _________________ ----------------------------------------------------
'90 Syncro Westy 2.5Subi Turbo, BFGs 215/75/15 Rheins |
Posted: Sat Feb 23, 2013 8:48 pm Post subject: |
| DeadSetMonkey wrote: |
| so. EJ22 vs Bostig |
Whattya want to know? Normally aspirated bostig power/torque was comparable to the EJ22. I installed a beta turbo kit about 10k miles ago and never looked back. |
BillM Samba Member
Joined: June 18, 2004 Posts: 1381 Location: Stonington,CT
Posted: Sun Feb 24, 2013 10:14 am Post subject: |
| mtnwater wrote: |
I also have a beta turbo mated to my zetec. The only thing
I look back at is to see the faces of the people I just passed! _________________ Bill M
87 Westy |
sbf6463 Samba Member
Joined: August 31, 2014 Posts: 7 Location: Portland, Oregon
Posted: Sun Aug 31, 2014 6:35 pm Post subject: Zetec conversion |
I'm just starting to research converting my 91 Westy automatic and Zetec has been recommended. Everything I've read so far is about converting synchros...Is the Zetec a good conversion for an automatic, as well?
Susan |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Sun Aug 31, 2014 7:54 pm Post subject: Re: Zetec conversion |
| sbf6463 wrote: |
Susan |
Yes, they work great in 2WD autos. I think they have worked out their "vibrations in automatics issue" at this point. Those vibration issues were mostly at idle anyway not while driving and they weren't that bad regardless from what I've read. _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
Chainsaw Samba Member
Joined: August 07, 2015 Posts: 249 Location: Issaquah Washington
Posted: Sun Mar 12, 2017 8:27 am Post subject: Re: Bostig Zetec Review: Install and after 2000 miles |
This is certaily interesting. Gotta do some mor reading on this vs the subaru engine. _________________ 89 Westy. 2wd. Manual. |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4615 Location: East Kootenay, British Columbia
Posted: Sun Mar 12, 2017 8:48 am Post subject: Re: Bostig Zetec Review: Install and after 2000 miles |
| Chainsaw wrote: |
| This is certaily interesting. Gotta do some mor reading on this vs the subaru engine. |
Some of the information in this thread is old. The Bostig kit has changed quite a bit since '09. ECU is now inside the van, the Cobra intake head has replaced the long hose, etc. For now there is no turbo option, Jim is working on new power upgrades.
The power available from the two engines (EJ22 vs Zetec) is pretty close, but I would rate the Zetec engine as the more reliable. _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
jimf909 Samba Member
Posted: Sun Mar 12, 2017 9:11 am Post subject: Re: Bostig Zetec Review: Install and after 2000 miles |
Cost to install has also increased notably over the 2009 prices quoted, think closer to $8K-$10K DIY, $15K for a pro-install.
After nearly a year and 10K miles with the Bostig, I've found it to be a notable improvement in many ways over the wbx.
There's lots more out there to read though. Enjoy! _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
