Lifted bus, Type 4 CV question
Slowlow Premium Member
Slowlow is offline
PostPosted: Fri May 08, 2009 10:01 am    Post subject: Lifted bus, Type 4 CV question Reply with quote
Im about to tear into my '70 Doublecab to start lifting it.
Im only curious will Type 4 CV's directly bolt on or will I have to replace something else?
I mean, will my Baywindow axle's work?
I originally planned to use 930's, but several posts say that the added $$ for the 3 degree difference isnt worth it
Ive replaced CV's but never mixed and matched before....
Any help is appreciated!
• Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 •
turboblue
turboblue is offline
PostPosted: Fri May 08, 2009 10:15 am    Post subject: Reply with quote
They are a bit wider but a direct bolt in.
I have them installed in my off road buggy.
I used aftermarket axles with a bit longer spline though.
http://www.blindchickenracing.com/How_to/CVJoints_Axles/cv_joints_101.htm
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
57baja
57baja is offline
PostPosted: Fri May 08, 2009 12:11 pm    Post subject: Reply with quote
x2 No problem.
KaddieShack.com - Kadron Carburetor Specialists, VW Parts and Accessories
Have fun with the KS crew on Facebook and keep up to date on the latest builds and happenings
Green bug Guy
Green bug Guy is offline
PostPosted: Mon May 11, 2009 2:11 am    Post subject: Reply with quote
yoou need longer splined axles! otherwise you wont be able to put the c clips on the ends of the axle shafts.
Slowlow is offline
PostPosted: Mon May 11, 2009 12:20 pm    Post subject: Reply with quote
Is this with a 930 OR the thing style??
Thanks
Green bug Guy
PostPosted: Mon May 11, 2009 7:52 pm    Post subject: Reply with quote
^that is the T4 cv (thing style)... the cv is thicker than the T1 and T2 cv's so they need an axle with a longer spline. i have this set up on my bug... works real good!
Slowlow is offline
PostPosted: Tue May 12, 2009 8:39 am    Post subject: Reply with quote
^^ Alright, thanks for the clarification!
And excuse my ignorance..... but who can I get longer axles from?
Embarassed
turboblue
PostPosted: Tue May 12, 2009 9:04 am    Post subject: Reply with quote
Embarassed
You need a longer splined axle not a longer axle to run those thicker CVs.
You should have either 18-3/4" or 19-1/4" axles IIRC.
Most any performance VW dealer should have them or can get them.
Gary
Slowlow is offline
PostPosted: Tue May 12, 2009 4:20 pm    Post subject: Reply with quote
^^ No No, I understood... just a typo on my part by not saying longer Splined.
fusername
fusername is offline
PostPosted: Wed May 13, 2009 6:14 pm    Post subject: Reply with quote
let me know how it works out, I want to do the same on my 77
[email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote:
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine!
