BUGTHUG Samba's Rented Mule
Joined: April 22, 2007 Posts: 833 Location: KANSAS toto's fire hydrant
Posted: Sun May 17, 2009 12:40 am Post subject: |
I have been using PB blaster and part of a choke cable for a couple days with no results; besides brake cleaner is there anything better? Carb cleaner?
I've heard of people using acetone, its more of a cleaner dissolver, where the PB is more of a lubericant. If you have air compresser you could try that and see if its letting anything thru. _________________ I know you would understand what I'm saying if you could just see my HANDS
Even the middle of the week says W T F
1963 15 window bus
1966 VW bug
1966 21 window micro bus
1969 Dune Buggy
1965 VW bug
1974 VW bug
1972 Kelmark, VW drive line
1948 Chevrolet Hearse |
HerrrKafer Samba Member
Joined: June 02, 2004 Posts: 1465 Location: East Fishkill, NY
Posted: Sun May 17, 2009 2:56 am Post subject: |
BUGTHUG wrote: |
outoftheoffice wrote: |
I have been using PB blaster and part of a choke cable for a couple days with no results; besides brake cleaner is there anything better? Carb cleaner? |
I've heard of people using acetone, its more of a cleaner dissolver, where the PB is more of a lubericant. If you have air compresser you could try that and see if its letting anything thru. |
Absolutely. Acetone and compressed air are usually the correct weapons for clogged gas lines, as you're typically trying to dissolve and then purge varnished gas.
I use wash bottle to dribble acetone down the line regularly for at least a full day. Polypro is generally fine for acetone at room temp, but to be safe I don't keep acetone stored long term in any plastic. Also be sure it doesn't get hot (e.g. left out in the sun), as acetone will degrade poly at higher temps.
Wash bottles are really handy to have around, by the way. I keep a few separate for fuel, isopropanol, and acetone.
You can start with a normal gun to blow air through the fitting after the acetone soak. If you're lucky, you'll start to clear the line right away. If not, repeat the whole thing a few times. If there's still no progress, you can pressurize the line against the obstruction to help free it. Clamp a barbed-x-quick connect air fitting to a piece of fuel hose, and clamp the hose on the fuel line. Pressurize slowly and see if you're making any progress. I wouldn't go past 75 or 80 psi though.
I also like to pressure check lines that have been sitting for a long time, whether I had needed to unclog them or not. Cap one end with a gauge, put 75psi in the line, and see if it holds it for a day.
I have cleared quite a few lines like this with no troubles. (Of course, you are responsible for being alert and smart about safety issues, and use these ideas at your own risk. ) _________________ Evan H.
EverettB wrote: |
In a perfect world, anyone running chromies would be shot. |
outoftheoffice Samba Member
Joined: March 02, 2009 Posts: 470 Location: Houston, Texas
Posted: Sun May 17, 2009 4:30 am Post subject: |
Before I saw the replies I picked up some chemtool carb cleaner, let that soak since last night. If I'm still not getting anywhere by tomorrow I'll switch to the acetone. thanks! |
si fly Samba Member
Posted: Sun May 17, 2009 4:40 pm Post subject: |
When I did mine it took a few hours so be patient. It might not seem like your getting anywhere but you really are. _________________ 1959 VW Beetle Sedan, DeLuxe
Second owner
You can replace them when they start lookin like swiss cheese. |
Posted: Tue May 19, 2009 3:54 am Post subject: |
Got the line cleared! Only problem is I can't tell which helped more because I had two different solvents in the tube at the same time - Chemtool carb cleaner and acetone.
Just using the chemtool and compressed air now to clean out any last bits of grit and grime before I drop the tank back in. |
Hotrodvw Samba Member
Posted: Tue May 19, 2009 6:19 am Post subject: |
I guess it really doesn't matter as long as you got it cleared. I would flush it out a couple times just be sure all the debris is gone. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue May 19, 2009 7:32 am Post subject: |
And, install a filter between the frame and the engine, over the trans. Be prepared to change it a couple times right away, when you start driving the car. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Tue May 19, 2009 8:16 am Post subject: |
Yea, doesn't matter now that it is free but for future reference it would have been nice to know which to recomend.
Russ Wolfe wrote: |
And, install a filter between the frame and the engine, over the trans. Be prepared to change it a couple times right away, when you start driving the car. |
Already installed one there! |
si fly Samba Member
Posted: Tue May 19, 2009 2:19 pm Post subject: |
Congrats! Even after mine was cleared I kept flushing it and you just keep getting stuff out. It's crazy.
Hey guys, here is a new question. I have heard a few people talk about "4"beam and some dropped spindles" And stuff like that.
What are those? _________________ 1959 VW Beetle Sedan, DeLuxe
Second owner
si fly Samba Member
Posted: Tue May 19, 2009 2:34 pm Post subject: |
Oh, and one more question/advice.
I have been looking at replacing the bumpers on my bug and I was wondering why there is such a large gap in prices between Wolfsburg and jbugs? They are even both triple chrome. _________________ 1959 VW Beetle Sedan, DeLuxe
Second owner
Posted: Tue May 19, 2009 3:25 pm Post subject: |
4" beam is narrowed 4" oaver all width. 2.5" spindles are drop spindles. You can drop your ride 2.5" w/ them, and keep a decent ride. WW bumpers are a much better quality than what J-Bugs puts out. Remember...........you get what you pay for.  _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
si fly Samba Member
Posted: Tue May 19, 2009 6:59 pm Post subject: |
What do you mean "4" beam is narrowed 4" oaver all width."?
WW is a little expensive for my taste and if you get what you pay for, do you think that midamerica would be like the middle of the field? _________________ 1959 VW Beetle Sedan, DeLuxe
Second owner
hpw Samba Member
si fly Samba Member
Posted: Tue May 19, 2009 8:06 pm Post subject: |
Well, I can see that they are not liked very much but are they selling worse quality bumpers than jbugs? I am less woried about the money I guess that I thought. I want a good quality though when I do replace the stock bumpers.
Know what I'm saying? _________________ 1959 VW Beetle Sedan, DeLuxe
Second owner
Posted: Tue May 19, 2009 10:16 pm Post subject: |
Mid-America won't see a dime of mine.....period. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
Posted: Wed May 20, 2009 3:07 am Post subject: |
If you are going with stock bumpers I would try and find a good used pair of original bumpers off another bug.
True, WW does has some of the best quality reproduction parts out there (that's why they are more expensive-and worth it) and I'm sure they are good bumpers but they still aren't as good/strong/long lasting as a set of originals.
You'll want to do a search on lowering your VW (there are plenty of other threads) but a 4" beam is a beam that has had 2" cut off of each side. The end result is the front axle width being reduced a total of 4". Other common widths include 2" and 6" |
si fly Samba Member
Posted: Wed May 20, 2009 2:09 pm Post subject: |
That really clears it up for me, thanks.
Well the original bumpers are really staight with no dents or anything but on the top part of the bumpers the chrome it coming off a little and rusting. Not bad, but it is not good for sure.
Do you guys know how much it costs to get parts re-chromed? _________________ 1959 VW Beetle Sedan, DeLuxe
Second owner
my59 Samba Member
Joined: August 13, 2003 Posts: 3973 Location: connecting the dots
Posted: Wed May 20, 2009 3:01 pm Post subject: |
First find a plater- lots have gone away beacuse of the EPA
When you find one, price shipping the parts round trip
Get a quote from the plater
Chrome is expensive.
Be glad you're not looking at a 50's US car
If its suface rust you might try a scrub pad, lime away, and elbow grease. If the rust comes off, then rinse, dry and then wax the hell out of them. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
si fly Samba Member
Posted: Wed May 20, 2009 3:10 pm Post subject: |
I e-mailed a company from the internet and they guessed it would cost about $2200 That seems crazy to me, but I have never looked into getting it re-dipped.
That it the reason I have been looking at just buying new bumpers. Even WW (the most expensive and most likely best quality) would cost about $1000 new.
I'm just weighing the options. _________________ 1959 VW Beetle Sedan, DeLuxe
Second owner
Posted: Thu May 21, 2009 3:56 am Post subject: |
Depending on the condition of yours, you could probably sell them for some decent money (maybe +/- $200/each if they are in fact original VW bumpers in good shape) to help fund some new ones. I don't know chrome pricing but $2200 for dipping those bumpers is just crazy.
A little rust on the top? Man, just slap those suckers on and roll them! You can replace them when they start lookin like swiss cheese. |
