johncollins Samba Member
Joined: April 07, 2008 Posts: 84 Location: Dayton, Ohio
Posted: Thu May 28, 2009 6:29 am Post subject: My Berry Mini-T 2 build (lots of pics) |
I wanted to start my own build tread. Here is what it looked like when I got it.
This is my progress so far
I plan on using 2x2 down the sides and using aluminum diamond plate on the floors. I'm going to make a center console to cover the tunnel and wiring and I am changing it to bucket seats instead of the bench. You can see in the pics that I moved the E-brake mount back.
Thanks for looking
Baja68 Samba Member
Joined: June 08, 2007 Posts: 576 Location: Houston Texas
Posted: Thu May 28, 2009 6:37 am Post subject: |
looking good.
Some custome paint there on your car. You did a good job cleaning upi your engine I need to that to mine  |
touchdowntodd Samba Member
Joined: April 13, 2009 Posts: 283 Location: milwaukee
Posted: Thu May 28, 2009 8:48 am Post subject: |
please tell me thats all new chrome, otherwise I officially know I suck at getting rust off chrome |
Posted: Thu May 28, 2009 9:07 am Post subject: |
Yes it is all new chrome, I did a complete rebuild over the winter on the motor, I still need a new coil and wire it, but other than that, it is ready to fire up
As to the paint job, I do plan on keeping it for a little while, I really like it. It is chipped up and a run here and there. Here is a close up of the front
donmac Samba Member
Joined: April 23, 2007 Posts: 367 Location: Pearland, TX
Posted: Thu May 28, 2009 10:13 am Post subject: |
You moved the e-brake handle back, I guess you are going with bucket seats? _________________ Don
67 Dune Buggy aka Shrek
74 Baja Junk Pile aka Wild Thing |
hcallaway Samba Member
Joined: September 06, 2008 Posts: 333 Location: Richmond VA
tinnocker Samba Member
Joined: July 24, 2008 Posts: 439 Location: Jasper Georgia
Posted: Mon Jun 08, 2009 12:16 pm Post subject: |
That is a great idea of using two engine stands to flip the engine. I worked by myself also and just flipped it over on the concrete floor. That may be why I am having back trouble now.  |
brgnascar Samba Member
Joined: October 16, 2008 Posts: 227 Location: Easley , S.C.
Posted: Mon Jun 08, 2009 5:50 pm Post subject: |
just an opion but, i would lose the clear distributor cap it will leave you stranded one day |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6768 Location: Northern California
Posted: Mon Jun 22, 2009 11:45 am Post subject: |
You mounted the parking brake on the chassis serial #. Will Ohio put a new assigned number on a modified chassis? |
jspbtown Samba Member
Posted: Mon Jun 22, 2009 12:02 pm Post subject: |
John,
Floors look great.....I like the diamondplate:
Are you going to cut the old lip down? You don't want to have that sharp edge. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15599 Location: Deep in the 405
Posted: Mon Jun 22, 2009 12:38 pm Post subject: |
brgnascar wrote: |
I agree. The transparent caps are pure junk. Replace it before you have a problem. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Mon Jun 22, 2009 1:30 pm Post subject: |
johncollins wrote: |
I still have the piece with the number, I just plan on welding it back on behind the parking brake mount. I hope it will not be a problem. |
If you already have it titled and registered, you'll probably be OK.
If you need to take it to the DMV to be checked, they probably won't accept it. Best case might be they assign you a new "special construction" number. |
Posted: Tue Jun 23, 2009 7:57 am Post subject: |
BL3Manx wrote: |
I do already have it titled and registered, I did that first before i started working on it. It had an out of state title on it so I had to get an out of state inspection done before I could transfer the title to me.
also I heard some VWs had a VIN plate, does any one have a picture of one?
Thanks for the advise on the distributor cap, I will carry my old one with me. _________________ Check out my build
http://s279.photobucket.com/albums/kk126/johncollins31/
http://www.thesamba.com/vw/forum/viewtopic.php?t=359622&highlight=minit |
rbenson0803 Samba Member
Joined: June 01, 2009 Posts: 4 Location: Las Vegas, NV
Posted: Tue Jun 23, 2009 6:47 pm Post subject: I belive I have a Min T |
I purchased a buggy the other day ... I am a 1st time owner of a VW. I believe it to be a Min t.
The previous owner was building a rat rod out of it ... so he hacked the front fenders off of it ... did a terrible job ... not enough material to put them back.
The bigger problem is the IRS frame is also missing the VIN number ... what can be done?
I figured that the fenders would have to be replaced with "Plymouth Prowler Like" fenders. Only since I can not reattach the original fenders ... to bad.
Also are windshoelds available? |
66 Shorty Samba Member
Joined: May 10, 2007 Posts: 917 Location: Rhode Island
Posted: Wed Jun 24, 2009 5:08 am Post subject: |
WOW! The frame is coming out Great! Very nice Score with that Buggy! The motor looks Sweet! Is it a stock rebuild or did you add some "go fast goodies"? I like the look of the diamond plate floor too.
rbenson, Does it still have the metal where the VIN was? Reason I ask is because I bought a Buggy & I couldn't read the numbers. A buddy of mine tried "raising the numbers" by using some type of acid & he could read them. Maybe someone here can tell you the process, or acid to use, or I could ask him. He's a member here & I can send him your info or vise versa...
Sorry for the Hijack, just wanted to try helpin him out!
Back to the regularly schedualed program... _________________ ~X-Man~
'60's Spatz Buggy body on '74 Chassis (Budget Build)
'69 Bug (Baja-to-be partial daily)
'10 Silverado (My daily) |
joescoolcustoms Samba Member
Posted: Wed Jun 24, 2009 8:22 am Post subject: |
I saw one of these for sale at Larry's Off Road drag/show/swap event 2 years ago and should have bought it. I have wanted this body style every since.
Nice work on the pan. I think I would have to raise the body a little too to allow room for my legs, 6'2". _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
