Photo request - brake spindle
Blitzkrieg_
Blitzkrieg_ is offline
PostPosted: Sat Jul 26, 2008 3:17 am    Post subject: Photo request - brake spindle Reply with quote
Hello all,
I'm looking for the following:
1. A hi res pic of a Type 3 drum brake spindle (Spindle only)
2. A hi-res pic of a Type 3 disc brake spindle (spindle only)
I would appreciate any help, I've searched the gallery and can't find anything Sad
Thanks!
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sat Jul 26, 2008 6:21 am    Post subject: Reply with quote
What are you trying to do??
VW did change the inner front wheel bearing size in the middle of 1968. So If you are trying to go from drum to disc, you will probably have to change the inside bearing.
Gary: OK. Ima poop.
Blitzkrieg_
PostPosted: Mon Aug 04, 2008 12:57 am    Post subject: Reply with quote
I have a '68 Fastback. Now, bear in mind that South African fastbacks were all wide 5 PCD, with the obvious exception of the Automatic models...
Are the actual spindle sizes the same? I believe that all water cooled VW's (Golf, Polo, etc) use the same back wheel bearings that would work on the Type 3 front spindle...
Blitzkrieg_
PostPosted: Tue Aug 05, 2008 2:26 am    Post subject: Reply with quote
BUMP!!!!
Russ Wolfe
PostPosted: Tue Aug 05, 2008 9:56 am    Post subject: Reply with quote
The water cooled cars took the same bearings as the late 68 on T-3's. As for your SA car, and it being a 68 besides, it would be hard to say, which bearing it took.
Someplace here on The Samba, there is a FAG bearign conversion chart, from VW part numbers, to FAG part numbers. The FAG numbers can be looked up to get the dimensions.
Gary: OK. Ima poop.
Blitzkrieg_
PostPosted: Wed Aug 06, 2008 12:05 am    Post subject: Reply with quote
Thanks a lot Russ Very Happy
Blitzkrieg_
PostPosted: Wed Aug 06, 2008 12:37 am    Post subject: Reply with quote
So if i get this right, the actual spindle size didn't change, but only the bearing size?
Blitzkrieg_
PostPosted: Fri May 29, 2009 4:21 pm    Post subject: Reply with quote
Is there a difference in size between drum and disc spindles or would the bearings interchange?
Russ Wolfe
PostPosted: Fri May 29, 2009 5:17 pm    Post subject: Reply with quote
mid 68, they changed the bearing size of the inner bearing, and the seal.
Gary: OK. Ima poop.
Blitzkrieg_
PostPosted: Sat May 30, 2009 12:20 am    Post subject: Reply with quote
I know that Laughing
What I mean is there a physical difference in size between the two spindles i.e would the bigger bearings work on both of them? Wink
Meyer
Meyer is offline
PostPosted: Sat May 30, 2009 1:04 pm    Post subject: Reply with quote
Here is a not very good shot of some 65 T3 drum spindles I will be selling. You will have to double-click on the image to see it full-size:
I'm short on time right now, but if you need a specific shot or measurements, let me know.
Russ Wolfe
PostPosted: Sat May 30, 2009 1:34 pm    Post subject: Reply with quote
No, that is what they changed, the diameter of the spindle. If you have an early spindle, you have the smaller bearing diameter. If you have a later spindle, you have the bigger diameter spindle.
Gary: OK. Ima poop.
Blitzkrieg_
PostPosted: Mon Jun 01, 2009 12:27 am    Post subject: Reply with quote
Thanks Russ.
I'll just have to fabricate a sleeve to run the later bearing on an early spindle so that I can use the watercooled vws rear discs Sad
Russ Wolfe
PostPosted: Mon Jun 01, 2009 5:52 am    Post subject: Reply with quote
No, put the early bearing in them.
The fit in the drum/disk is the same.
Gary: OK. Ima poop.
Blitzkrieg_
PostPosted: Tue Jun 02, 2009 12:28 am    Post subject: Reply with quote
Very Happy
Excellent news then!
