Baja Squared's Big Adventure
57baja
57baja is offline
PostPosted: Sun May 31, 2009 11:02 am    Post subject: Baja Squared's Big Adventure Reply with quote
... So it's not really that big of an adventure... But it was to me. I actually have this thing running and got to drive it around a bit.
WOOOO HOOOO!!!
For those of you that aren't familiar with this project, my 15 year old son and I are building a Baja Bug from a Squareback for his first car. Yes, it's not your typical lowered T3 that you'd find in this forum. Quite the contrary. Here are a couple of pictures of progress so far....
And here it is driving on the street.....
So here's where I could use some ideas:
It drives OK, but it seems to be overheating miserably. The previous owner had it stored for many many years, so it wasn't running when I bought it. The guys said that there was about 30,000 miles on the engine, but he could have been giving me a line of crap. Who knows? I don't have any gauges on it to get actual temps, but after you drive it for about two miles, the oil light flickers on the dash. I used some synthetic 5W30 in it that I had laying around the shop from my baja, and plan on trying some thicker oil. I've looked at timing and timed it to 30 BTDC at full advance (009) with dual ICT's (new). I know I should change the idle jets to 55 or 60, so maybe that's contributing. I didn't do a full compression check, but I did check one cylinder and found it pumped up to 100 at full operating temperature. Maybe I should check them all. It seems to have plenty of poop, so no issue there. It runs smoothly through the whole power band. There's no smoke and no smell of burning oil, either. Anything else you can think of? I'm going to drain the oil, refill it with 20W50, and do a valve adjustment today. I'd sure like to have it running well before the Classic, but know that it may actually need an engine.
I have about 20 years of VW experience, but very limited with a T3 (I only had one once before).
Your thoughts?
KaddieShack.com - Kadron Carburetor Specialists, VW Parts and Accessories
Have fun with the KS crew on Facebook and keep up to date on the latest builds and happenings
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun May 31, 2009 12:40 pm    Post subject: Reply with quote
If the car sat for a long time, check for mouse nests in the engine. I have mouse nests in one of mine, and it has never been installed in the car. They love to get inside our T-3 engines.
Actually, there is theory, that heavier oil increase the overheating problems.
It does not give up the heat as fast as the thinner oils in the cooler.
Gary: OK. Ima poop.
Pierre G
Pierre G is offline
PostPosted: Sun May 31, 2009 2:35 pm    Post subject: Reply with quote
X2 on some crap between cylinders and cooling tin. Could be mouse nests like Russ said, or dust/oil mix, or anything else...
1976 181/Thing, 1967 fastback, 1973 squareback, 1964 microbus, 1967 Double Cab, 1969 westfalia (currently under resto), 1972 LM1C dune buggy, 1974 jean's bug, 1974 1303 (super beetle, currently under reassembly after new paint).
66311
66311 is offline
PostPosted: Sun May 31, 2009 2:59 pm    Post subject: Reply with quote
You can't tell from the outside. The thermo flap is stuck on this one also.
notchback
Insensitive Jerk
notchback is offline
PostPosted: Sun May 31, 2009 3:33 pm    Post subject: Reply with quote
Another thing is where your cooling air is coming from. Having the body lift on there makes it so that the cooling air intake on the engine and the cooling air exit on the body do not line up. I can't tell what you're doing about that, but if you have leaks in there, then you're pulling cooling air over the exhaust, thereby warming it before it can cool the engine. You need to figure out a way to seal the cooling air intake like it is on a standard Type 3. This, along with a general lack of motivation, has been one of the things keeping me from using my lift kit.
zeen wrote:
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point.
FU#3
Bobnotch
Bobnotch is offline
PostPosted: Sun May 31, 2009 3:44 pm    Post subject: Reply with quote
He's got the cooling bellows in place as shown in this pic.
I am however wondering if his taller than stock sized tires (look like 235-75's) might be causing the engine to lug, thereby overheating it. d'oh!
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun May 31, 2009 4:12 pm    Post subject: Reply with quote
If compression and timing are good, overheating is probably a mixture issue. Does it ping at all?
Do you have a way to measure oil pressure other than the light? Could be a bad sensor. Does it "smell hot" or are you judging from the light.
Oh, and tell the yahoos downtown at the power company to turn off the streetlights during the day!!
sharkskinman
Lateral Lunatic
sharkskinman is offline
PostPosted: Sun May 31, 2009 4:28 pm    Post subject: Reply with quote
thats great man
Im still fighting with the idea of lift plates
I have the steel plates now
but Not sure the IRS will go 3" down
tried today and didnt want to go down that far
maybe i forgot to unhook the Ebrake
Looking great
Keep em coming
74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote:
Extremity is relative to how far your willing to jump
Ward Cleaver wrote:
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards
PS4 "NKOGNEATO"
57baja
57baja is offline
PostPosted: Sun May 31, 2009 4:46 pm    Post subject: Reply with quote
Thanks for the encouragement guys. Here's an update:
I was thinking about the bellows misalignment and found that to be restricting the airflow, as it was pinched somewhat. So.. I removed the bellows for now. I have cut up the fenders so far that it is actually service as a ram-air intake for the cooling air behind the tires. After removing the bellows, it didn't make any difference whatsoever.
So I adjusted the valves, changed the oil to Royal Purple 20W50, and took apart the passenger's side engine tin to check for problems with the thermostat. I discovered that there is no thermostat, and there was no debris in the engine there. That was a very good idea about the mouse nest. I'd never have thought about that.
So I took off the hose that goes to the heaters on the driver's side, and it literally fell apart. Hmmm. After looking at it, I noticed a couple of great big holes in the aluminum flexible tubing going to both sides. So for now, I removed both sides and capped them off with the bottoms of baby bottles. I hope my wife doesn't notice them gone or I'm gonna be in trouble!
I just drove it about 8 miles, 3 of which was on the freeway. It runs fine with no oil light at idle.
Hmmm????
Maybe there is/was a rats nest in the driver's side? Maybe the cooling air escaping was causing havoc, but I would have never thought it would have been happening that quickly, and with the ambient temperature as low as it's been lately.
Hmmmm.....
For now, I'm going to continue driving it around town until I see reason to do otherwise.
Keep the suggestions coming, though.
BTW, it doesn't ping, and I know it's running a little lean. I should have 55's or 60's as idle jets if I recall correctly. I think I have 52's.
And I have a 002 bus transmission in it that made the gearing extremely low for dirt running and rock crawling. The ring and pinion is 5.37 as opposed to the T3 tranny that has 3.88. The gears are otherwise the same inside, or roughly so.
It is a cool crawler, and I can't wait to try it out in the dirt!
57baja
57baja is offline
PostPosted: Sun May 31, 2009 4:50 pm    Post subject: Reply with quote
Oh, and BTW Phil. One of the first things I did was change the sending unit with a brand new one. My nose is not calibrated as well as some, but it doesn't smell hot to me. It smells like a VW, though! I'm serious about that!
j5josher
j5josher is offline
PostPosted: Sun May 31, 2009 7:22 pm    Post subject: Reply with quote
well with my luck if you didn't rebuild the motor then running synthetic will make the oil light come on.. idk why it just does.. happen in the fasty, thing and the baja... i just dont run synthetic its a waste of your money if it just drips out anyway..
For any reason you believe me. Turn around and think differently.
Russ Wolfe
PostPosted: Sun May 31, 2009 7:27 pm    Post subject: Reply with quote
I have synthetic in all of my air cooled, including my Briggs & Stratton.
My cars do not leak oil.
VW's did not leak when they were new, they shouldn't leak today. Not if they are built right.
Gary: OK. Ima poop.
Buttafuoco
Buttafuoco is offline
PostPosted: Sun May 31, 2009 7:44 pm    Post subject: Reply with quote
I was once told not to use high grade synthetic oil because, well, it works too well...causing the oil to pass into areas where, with traditional oil, which was the only oil available at the time of the engine design and engineering, would never pass through to. But I would trust Russ' word over just about anyone when it comes to ACVW.
JSMskater
Samba Grease Gorilla
JSMskater is offline
PostPosted: Sun May 31, 2009 7:53 pm    Post subject: Reply with quote
these are the same myths that are perpetuated over and over. Listen to Russ and go down to the "what oil do I use" thread in Performance Engines/ Racing.
71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors
Buttafuoco
PostPosted: Sun May 31, 2009 8:00 pm    Post subject: Reply with quote
At Aircooled.Net we recommend that you run synthetic oils in all cases, with one exception: you should continue to run dino oil (and change it every 1k miles) if your car still has the stock oiling system.
There is one thing I need to clarify though -- if you are not running an oil filter, there really is no point to using synthetic since your oil is going to become contaminated very quickly. Your engine will still benefit somewhat from it, but due to the higher cost of synthetic oil, the gain of running it before it becomes contaminated is negligible. Oil change intervals range from 1000-3000 miles in the VW engine with a strainer (not a filter). VWoM (Mexico) recommends 1k mile intervals on non-filtered engines; keep this in mind for your pride and joy! But on the flip side, the stock VW engine only takes 2.5 qts anyways, it's not going to break you if you do want to run synthetic!
JSMskater
PostPosted: Sun May 31, 2009 8:36 pm    Post subject: Reply with quote
I'm sorry but I feel like you said nothing in this post. dont run synthetic on a stocker because its a waste of money! then... it wont matter since you're not buying that much anyway.
and why on earth would you recommend running dino on stock but not on everything else? There isn't any reason to suggest that. When you start talking detergent vs. non detergent, it's a whole nother bushel of apples but again, the issues people bring up are easily rectified if you take precautions. If anything, the set up that stands the MOST to gain from synthetic is a stock oiling system Rolling Eyes
furthermore, VWOM's engines have hydraulic lifters, filters, and run a fairly advanced FI system that even controls ignition. comparing it to the stock oiling system a lot of our engines are running to VWOM's beetle engines is comparing apples and oranges since the needs of those engines and the needs of ours in a lot of ways are drastically different. I know because I have a mexican beetle in mexico.
simply put- there is no reason... at all... not to run synthetics in our aircooleds, stock or otherwise, with the exception of break-in on a new motor. even on an OG 40yr old motor, you can switch to synthetic if as long as you do a quickie oil change within a short interval to get rid of any junk the synthetic may have dislodged. The gains you get in engine life, cooler running, and a wider range of temperatures that the oil lubricates at completely outweighs the various myths and downright fallacies about this whole issue.
TOOB Member #3
Buttafuoco
PostPosted: Sun May 31, 2009 8:42 pm    Post subject: Reply with quote
Sorry...that was not a post writen by me, I simply copy and pasted a post written by Glenn in the performance forum. I'm indifferent about the issue as my knowledge about the different types of oils are limited. In a nutshell, I was merely supporting the fact that Synthetic may be the best way to go....for the cooling purposes.
57baja
57baja is offline
PostPosted: Sun May 31, 2009 8:43 pm    Post subject: Reply with quote
Now that this thread changed direction a bit... I run synthetics in everything. Here's why I'm a believer: I had the oil pick-up tube come out of the case inside my baja with a brand new 2187cc engine with 500 miles on it while on the freeway stuck in a traffic jam. I idled it off the freeway, down the off ramp, around some turns, and on to a side street in heavy traffic getting off the freeway for the horse races at Santa Anita Race Track. All of this took about ten or fifteen minutes of on and off driving with the oil light on solid. I added three quarts to get it home, and tore the engine down, fearing complete and total meltdown of the bearings. The rods and mains looked absolutely pristine! Figure that.
I'm a believer.
My son and I also entered a project about synthetic oils in the LA County Science Fair a few years back. After researching it, synthetic oil is the only way to go.
Now I'll get back to the originally scheduled programming....
I may get up the balls to drive it to work this week. It's about a 30 mile trek one way, so I really need to work up to it. We'll see.
Adriel Rowley
Adriel Rowley is offline
PostPosted: Sun May 31, 2009 9:22 pm    Post subject: Reply with quote
Walmart has Castrol 5 quart at $21. Considering I paid just less than that for dyno Valvoline, not bad. $10 oil change to me is worth the extended life and insurance. Over heated on an occasion, and have pulled a couple studs, but was due to not having case savers.
They are hardy! Put in some tooled and parts, and have an adventure. Breaking down is a bit of a pain, but can be rewarding. I discovered a beautiful place in not so nice L.A. running out of gas! Laughing
Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Dad's 1964 Beetle purchased September 1968.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9252810#9252810
1971 Sunroof Squareback with Fuel Injection
http://www.thesamba.com/vw/forum/viewtopic.php?t=219811&highlight=squareback+rejuvenation
Russ Wolfe
PostPosted: Sun May 31, 2009 10:33 pm    Post subject: Reply with quote
I just switched my 21 year old VW Fox over to Mobil 1 a couple weeks ago. Drove it to Charlotte, NC and back with no problems. 2300 miles, and used 1/2 quart of oil. Now this is an engine with 95K miles on it, and I was pushing it pretty hard at times.
I will probably change the oil and filter again shortly when I get time.
Gary: OK. Ima poop.
