Heater Tube Replacement
Page: 1, 2, 3  Next
david_594
david_594 is offline
PostPosted: Mon Jun 08, 2009 6:43 pm    Post subject: Heater Tube Replacement Reply with quote
So I finally got around to replacing the heater tube on my bus. Just in time for a nice hot summer.
Before all of this my bus would barely make enough heat in the winter to keep my windshield defrosted. And whenever I touched the heater pipe I could hear crunching within the outer wrapping. Pictures for your enjoyment...
So when I unwrapped my original heater tube this basically fell on my head. Its pretty obvious where my heat was going. Sad
So the replacement. I used a 2.5" 403 grade stainless steel pipe. I bought a 5' section off ebay for $48 and cut it down to ~50" in length. This gave me just enough length to slide it in both ends of my original pipe. The original was ~2.75" in diameter so this gave reasonable snug, but far from airtight seal.
Once it was in place I placed a few pop rivets in at each end to secure it somewhat.
I then wrapped each end with many layers of Nashua brand 324A "Cold Weather" foil tape. This tape is rated for temps up to 325* Fahrenheit and really the only foil tape I could find with a suitable temp range at home depot.
After than I decided to insulate it by first wrapping it in a 2" piece of fiberglass insulation, and then wrapping that with a piece of Reflectex.
I the taped the reflectex together using the same Nashua tape.
Overall the project cost me about $75 which I think is pretty reasonable and I feel like my replacement is well sealed, insulated and there is no reason why it shouldn't last another 40 years.
1968 westy weekender
2000 jetta tdi
79 vespa p200e
calebmelvin
calebmelvin is offline
PostPosted: Mon Jun 08, 2009 6:55 pm    Post subject: Reply with quote
Wow that thing was toast! Good job, too bad you have to wait a bit to get much use out of it Cool
Caleb
'68 Tagged Manx | My Wanted Ads
rcnotes
rcnotes is offline
PostPosted: Tue Jun 09, 2009 6:56 am    Post subject: Reply with quote
Nice job!
Tom Powell
Tom Powell is offline
PostPosted: Tue Jun 09, 2009 10:43 pm    Post subject: Reply with quote
Just read your posting on your new heater tube. This winter i didn't get the volume of air or the heat that I did last year and there was noise from the right side vent. Tomorrow morning I'll crawl under the camper and squeeze my heater tube and see if it crunches or crackles. I'll bet mine needs replacing also. Thanks for the post, the pictures, and the repair info.
Aloha
tp
foxtail1
foxtail1 is offline
PostPosted: Sat Jan 09, 2010 7:27 am    Post subject: Reply with quote
It looks like there will be a lot of squeezing going on, me to after I saw the photos of your heat tube. That will have to wait until summer time.
As they say, "You never know until you ask the question."
64 bug
64 bus
59 ghia
71 bus
Wildthings
Wildthings is offline
PostPosted: Sat Jan 09, 2010 10:10 am    Post subject: Reply with quote
Just a suggestion, use stainless steel stove pipe and/or close cell foam insulation, the fiberglass insulation is going to get wet, hold water and rust out steel or even galvanized steel pipe pretty quickly.
SGKent Premium Member
SGKent is offline
PostPosted: Sat Jan 09, 2010 10:45 am    Post subject: Reply with quote
also - that tape has a tendency to loosen with time. Use cable ties to back it up.
George Carlin:
Skills@EuroCarsPlus:
rustbus
rustbus is offline
PostPosted: Sat Jan 09, 2010 11:05 am    Post subject: Reply with quote
On the farm we have 3" aluminum irrigation piping - i used a section of this and it works great, and keeps the vehicle weight down for efficiency Razz
May of '72 Deluxe. Red Bay Bus 2.0L L-Jet CS & 091 trans conversion
my Bus thread
Wildthings
PostPosted: Sat Jan 09, 2010 6:55 pm    Post subject: Reply with quote
Nice idea, I may go that route the next time I fix up a heater system.
SGKent is offline
PostPosted: Sat Jan 09, 2010 7:29 pm    Post subject: Reply with quote
I am kind of at a loss here. My heater tube is like an accordian and runs all the way from the back to the front. It is double walled and is sealed with flexible rubber membranes. The pipe in the photo looks like it was rusty thin wall steel. Do some years have a hard tube instead of a flexible one?
George Carlin:
Wildthings
PostPosted: Sat Jan 09, 2010 7:41 pm    Post subject: Reply with quote
Earlier models had steel tubing while later ones had the corrugated paper. Both have there failings. Crying or Very sad
BuckeyeBus
BuckeyeBus is offline
PostPosted: Sat Sep 01, 2012 7:41 pm    Post subject: Main Heater Tube Reply with quote
Is there anything inherently dangerous about using standard auto exhaust pipe for a tube replacement?
busdaddy
busdaddy is offline
PostPosted: Sat Sep 01, 2012 7:59 pm    Post subject: Reply with quote
Nope, as long as it fits it works fine.
Слава Україні!
SGKent is offline
PostPosted: Sat Sep 01, 2012 8:05 pm    Post subject: Re: Main Heater Tube Reply with quote
As long as it isn't hooked up to the tailpipe Smile
I'd try to stay with something stainless and avoid anything that melts when wrapping it. The temperature coming off the heat exchangers will melt plastic quickly.
George Carlin:
Tcash
Tcash is offline
PostPosted: Tue Aug 23, 2016 9:51 am    Post subject: Re: Heater Tube Replacement Reply with quote
aerosurfer wrote:
Wanted to share my new heat tube version I did this week. The old diverter was completely gone, and the whole system was poorly rigged (incompletley at that too) from the P.O.
Cut out a like new diverter piece from a parts bus, and finally got around to crafting it all up.
from the Hardware store I used
Two 3"to 4" aluminum connectors
3" Piece of aluminum ducting, Came as a 5' section
4" flexible dryer tubing
3" flexible dryer tubing
Aluminum tape
Roll of Reflectix
First I only wanted to do this once (in theory) so I made sure to POR15 the underside of the floor and frame above where the tube will be
Then I welded the diverter back into position. The dryer tubing hanging down is the 3" tubing up over the beam to the heater tree in the cabin, partly wrapped in reflectix. The aluminum tape on the intake side of the diverter is to widen the opening as that will receive the 4" end of one of the connectors
With the original fiberglass diaper back in place. Taped and sealed
Now the 3" aluminum tube, cut in the middle to allow it to be snug in both ends
Started wrapping Reflectix in sections over the aluminum pipe
Off the the rear Y pipe I inserted the 3" end of the other connector into it. Once again with Speed tape on the outside diameter of 3" side of the connector to seal and snug it, then forced the other half of the 3" aluminum pipe into the 4" section
I was able to cut it so it was very snug in the gap. This I only used speed tape to seal the sections
On the rear part, the Reflectix slides snugly into the gap of the 4" connector around the 3" pipe. I didnt get a picture of it, but before I put on the other half of the pipe i slid the 4" dryer flex tube over the reflectix as additional insulation and protection. And all sealed up.
I still have some more reflectix to add the front hose, and I have to install and cover the other outlets in the diverter, but I can report the heat is very nice and pretty strong. Elsewhere in the system its sealed , but not perfect off the heater boxes and flappers. I had nothing to compare it to prior (in any bus), but it blows out of the defrost vent very well. I know some have said to delete the diverter junction all together, but it was such a perfect part and I was able to get the forward floor vent tube and a non broken cable for it. Still have to make something or use SCAT tubing for the vent under the rear bed
heater tube replacement solution
Welt wrote:
Before removing the rotisserie, some final things were done down under. Copied the original insulation with aluminized fibreglass fabric and ceramic wool.
Installed everything with aluminium tape and galvanized steel wire.
aerosurfer
aerosurfer is offline
PostPosted: Tue Aug 23, 2016 10:17 am    Post subject: Re: Heater Tube Replacement Reply with quote
That's my write up on the aluminum heat duct and I can say it has held up very well so far. Blows nice and hot.
Also if anyone needs the fiberglass insulating piece on the Y pipe I just listed one in the classifieds
http://www.thesamba.com/vw/classifieds/detail.php?id=1963275
Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone)
jtauxe Premium Member
jtauxe is offline
PostPosted: Tue Aug 23, 2016 1:53 pm    Post subject: Re: Heater Tube Replacement Reply with quote
My metal guy in Denver replaced the heater tube with a 3.5" stove pipe. It has an inner and outer layer, and insulation between.
Here is the double cab on the rotisserie:
And another pic of the pipe, sealed up:
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
otiswesty
otiswesty is offline
PostPosted: Sat Apr 01, 2017 12:51 pm    Post subject: Re: Heater Tube Replacement Reply with quote
Looks like just the right size
1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy
DougB
DougB is offline
PostPosted: Tue Oct 17, 2017 7:19 am    Post subject: Re: Heater Tube Replacement Reply with quote
If you don't mind me asking, what's the length on that stove pipe segment you installed? It looks like one pre-made unit (no cutting visible), so it makes me think it was bought to the correct dimensions.
Thanks in advance!
- Doug Smile
'75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
A very, very understanding wife
Hoppy Camper
Hoppy Camper is offline
PostPosted: Tue Oct 17, 2017 4:21 pm    Post subject: Re: Heater Tube Replacement Reply with quote
I used the exact same piece, bought it right off the shelf at Home Depot. Don't remember the size, but something standard, maybe 4 feet? Grab a tape measure
1979 Mexico Beige Westy auto
The Wilds of New Hampshire!
www.hoppycampernh.com
https://youtube.com/@hoppycamper
View user's profile Send private message Visit poster's website Instagram YouTube Gallery Classifieds Feedback
Page: 1, 2, 3  Next
