Alan_U Samba Member
Joined: July 10, 2004 Posts: 1762 Location: Vancouver, BC Canada
Posted: Tue Apr 07, 2009 7:20 am Post subject: |
| Eaallred wrote: |
| I've been toying around with the idea of the dual tapered aluminum in my race car. It see's 9000rpm with K-800's and heavy 48mm intake valves. It's tempting to try, but i'll probably wait until I go Ti valves at least. |
Eric,
Your probably better off using ultra light ti valves with tapered chromoly for added clearance in the pushrod tube.
At 8500rpms or so you dont need k800's with ti. The "regular" chevy springs should be enough. _________________ 11.92sec pump gas true daily driver. Who says it cant be done.
No more time for VW's....... |
1961bluebug Samba Member
Joined: November 11, 2002 Posts: 1137 Location: Czech Republic, Europe
Posted: Tue Apr 07, 2009 7:43 am Post subject: |
| Does anybody know what is the typical pressure of VW dual springs? Thanks. |
Alan_U Samba Member
Posted: Tue Apr 07, 2009 7:46 am Post subject: |
| 1961bluebug wrote: |
Different variations out there. Length of valve stems will change seat pressure and cam lift and ratio rockers will effect pressure at the nose of the cam at full lift. _________________ 11.92sec pump gas true daily driver. Who says it cant be done.
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Tue Apr 07, 2009 8:55 am Post subject: |
| Alan_U wrote: |
| Eaallred wrote: |
Eric,
At 8500rpms or so you dont need k800's with ti. The "regular" chevy springs should be enough. |
Yea, my plan (eventually if money issues don't keep getting in the way) is to send my heads down to Jeff Denham and have him install Ti and re-do the valve springs to what he feels they should be. I'll need to decide between alum and chromo pushrods at that time. Alum is big diameter. I've switched to waterboxer tubes for more clearance, I don't know how close the alum will be though. Might have to buy a single and check it out at that time.
If I don't sell the car that is. I just finished a major project on it that is making me want to keep it now, hahaha _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11143 Location: Black Forest, CO
krusher Samba Member
Joined: September 24, 2002 Posts: 7661 Location: europe
Posted: Tue Apr 07, 2009 10:53 am Post subject: |
I have the aircooled.net alu pushrods on my 112hp 1800, very happy, much quieter that the horrible cr-mo's i had before.
Cant say a bad thing about them. _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
Posted: Tue Apr 07, 2009 12:37 pm Post subject: |
| Max Welton wrote: |
Eric, would you also be factoring in the pushrod weight difference in spring selection?
Max |
I would have Jeff do that. That's why I would need to decide if I were going to switch to alum or keep my chromo before I were to send him my heads. I could get quite a few more rpm's out of this motor with Ti valves and alum pushrods. _________________ Eric Allred
bigsid Samba Member
Joined: April 12, 2005 Posts: 53 Location: Southampton UK
Posted: Wed Jun 10, 2009 11:39 pm Post subject: |
| On a related topic, would HD aluminum pushrods be set with the same valve clearance as a stock pushrod ? |
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3899 Location: Eastern WA
Posted: Wed Jun 10, 2009 11:42 pm Post subject: AC.net/aircooled.net HD alu pushrods |
I'm running my with stock lash, no problems. _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
nsracing Samba Member
Posted: Thu Jun 11, 2009 8:14 am Post subject: |
The rule w/ pushrods is they have to be as stiff as possible...especially the exhaust side.
I only WISH the aluminum pushrods available are as stout as the stock Type IV size. I wonder if they can be had w/ wall thickness as Bus pushrods.
I like the BERG chromoly and use them exclusively for large strokers w/ heavy springs.
I have machined/ sized AC.NET aluminums for strokers. I wish they are much fatter. |
Posted: Thu Jun 11, 2009 8:37 am Post subject: |
our Dual Tapered are much stronger, if you are worried about that. They are also more $.
John
Aircooled.Net Inc. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Thu Jun 11, 2009 9:22 am Post subject: |
John,
Can the heavier aluminum pushrods be ordered without the tapers?
I really like them just consistent diameter along its entirety. That will also be something if they come the size of Bus pushrods. |
Posted: Thu Jun 11, 2009 9:24 am Post subject: |
I don't know. In ME classes you learn that the additional diameter is NOT NEEDED at the ends, since the ends do not flex.
John
Posted: Thu Jun 11, 2009 9:33 am Post subject: |
| [email protected] wrote: |
John
Aircooled.Net Inc. |
I know but it is just easier to chuck and cut the darn thing on the lathe to size. So you do not have a work stick-out of 6 inches!  |
Posted: Thu Jun 11, 2009 9:38 am Post subject: |
THAT IS TRUE! _________________ It's just advice, do whatever you want with it!
Bruce Samba Member
Joined: May 16, 2003 Posts: 17694 Location: Left coast, Canada
Posted: Thu Jun 11, 2009 11:11 pm Post subject: |
| ... the additional diameter is NOT NEEDED at the ends, since the ends do not flex. |
I concur. The extra diameter to the ends just adds weight and no strength since there's no bending happening at the tips. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Posted: Fri Jun 12, 2009 6:52 am Post subject: |
BTW, this is also why factory pushrods are straight and not tapered.
John
Aircooled.Net Inc.
| nsracing wrote: |
youngstah Samba Member
Joined: December 28, 2008 Posts: 89 Location: california
Posted: Fri Jun 12, 2009 7:11 am Post subject: |
What about heat transfer, would non tapered be a more even distribution of material accounting for this?
Can someone post a picture of a stock vs bus vs fancypants (aircooled) pushrod next to each other in the same pic? ...for visual contrast of scale. |
the caveman Samba Member
Joined: August 09, 2004 Posts: 885 Location: island state of Montreal
Posted: Fri Jun 12, 2009 1:26 pm Post subject: |
| I run AC.NET ones on my 2165 [94x78] CB 044's w/duals and dual 44mm idf's . I also spent the time to do the valve train geometry properly at the same time at my last rebuild. The days of valve train noise and constant adjustments seem to be over. I don't usually pull more than 6500 rpms; and am now very happy. |
Bruce Samba Member
Posted: Sat Jun 13, 2009 10:47 pm Post subject: |
| youngstah wrote: |
| What about heat transfer, would non tapered be a more even distribution of material accounting for this? |
Heat transfer? From where to where? _________________
