Type 4 Rod Bushing Clearance..?
DubKru
DubKru is offline
PostPosted: Mon Jun 08, 2009 8:36 pm    Post subject: Type 4 Rod Bushing Clearance..? Reply with quote
What is the rod clearance in the wrist pin bushing? I got my rods back and they seem to have a little wiggle. How should it feel?
Robbie
2L, Raby cam, HAM Heads, Mallory, Dual Dell 40's, Porsche discs, Fuchs (Colored matched not to my bus),tunin' the crap out of it, slammed on Wagenswest suspension.
Polish Rifle wrote:
I like to take care of my engine and find a nice speed to cruise in on my bus, but sometimes.....you just get in the mood to run the piece of crap into the ground.
raygreenwood
raygreenwood is offline
PostPosted: Tue Jun 09, 2009 4:36 am    Post subject: Reply with quote
At room temp of about 72-75F....it should be a smooth push fit. Holding the rod in both hands....and using both thumbs...moderate pressure. No wiggle whatsoever. Without straining it should take a couple seconds to push the pin in. Ray
germansupplyscott
germansupplyscott is offline
PostPosted: Tue Jun 09, 2009 6:16 am    Post subject: Re: Type 4 Rod Bushing Clearance..? Reply with quote
Robbie
ray's description above is very good.
did you send the machine shop a pin when they machined the rods? is it a new pin or a used one?
SL
DubKru
DubKru is offline
PostPosted: Tue Jun 09, 2009 7:45 am    Post subject: Reply with quote
New pin. I figured it shouldn't have that much slack...
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Tue Jun 09, 2009 8:23 am    Post subject: Reply with quote
New or used wrist pins?
Bleyseng
Bleyseng is offline
PostPosted: Tue Jun 09, 2009 9:19 am    Post subject: Re: Type 4 Rod Bushing Clearance..? Reply with quote
[quote="DubKru"]What is the rod clearance in the wrist pin bushing? I got my rods back and they seem to have a little wiggle. How should it feel?
Robbie[/quote.
they shouldn't have any "wiggle" as they should smoothly push in without much effort.
take em back! and have a new pin with you.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
DubKru
DubKru is offline
PostPosted: Tue Jun 09, 2009 11:52 am    Post subject: Reply with quote
The new pin is at the machinist with the rods.
Is "friction fit" the proper terms I need to be using or are there any numbers to tell him?
germansupplyscott
PostPosted: Tue Jun 09, 2009 12:09 pm    Post subject: Reply with quote
the VW engine manual says, to quote directly
at room temperature the piston pin should be a push fit in a new bush
SL
DubKru
DubKru is offline
PostPosted: Thu Jun 11, 2009 11:19 am    Post subject: Reply with quote
THANKS!
I got the shop to go back and refit new bushes. The fit just didn't seem right and I wanted to make sure it wasn't just me.
SGKent Premium Member
SGKent is offline
PostPosted: Thu Jun 11, 2009 1:13 pm    Post subject: Reply with quote
DubKru - that was a wise decision. The description Scott and Ray gave were accurate. Lightly oiled, at room temp there should be a little drag as one is pushed through but neither play nor binding. The rod should also be checked for straightness at the same time. In an ideal situation you want to do the following while your rods are out.
*check for straightness
*clean them (glass bead or shotpeen)
*verify the thrust surfaces are within tolerance (big end width)
*resize the big end, making sure the measuring after resizing goes all the way around and doesn't pinch across the cap.
*lightly clean up the thrust surfaces
*resize the small end (wrist pin end) requires new bushings usually
*verify still straight
*check the weight of the rods and pins to balance them
*check the piston weight to balance them
*test the bearing fit with plastigauge before final assembly. use the old nuts for this then use new nuts on the final assembly. Verify the thrust clearances are correct on the crank.
Joey
Joey is offline
PostPosted: Fri Jan 29, 2010 7:39 am    Post subject: Reply with quote
So, without oil, should the pin drop right through the bushing or should there be resistance?
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
germansupplyscott
PostPosted: Fri Jan 29, 2010 7:44 am    Post subject: Reply with quote
no, not at all. the pin should not be passed through the honed bushing without oil, for one thing. but the resistance would be a bit greater if the pin was slid though the bush dry.
SL
Desertbusman
Desertbusman is offline
PostPosted: Fri Jan 29, 2010 8:38 am    Post subject: Reply with quote
A drop thru fit is not a push fit Wink
71 Superbug
71 Westy
Joey
Joey is offline
PostPosted: Fri Jan 29, 2010 9:07 am    Post subject: Reply with quote
They easily drop through without oil, but don't with oil. With oil they will drop through but takes a few seconds. Without oil there is slop, with oil slop is still there but not as much. No good?
Joey
germansupplyscott
PostPosted: Fri Jan 29, 2010 9:31 am    Post subject: Reply with quote
i think the bushes need to be replaced if the pin will slide through under any circumstances.
SL
Joey
Joey is offline
PostPosted: Fri Jan 29, 2010 9:42 am    Post subject: Reply with quote
I agree. I just have to convince the machine shop that just did them that they are wrong.
Joey
germansupplyscott
PostPosted: Fri Jan 29, 2010 11:01 am    Post subject: Reply with quote
OH.
i always sent a pin and a note that i want them "snug". they can always be honed to fit looser.
SL
Desertbusman
PostPosted: Fri Jan 29, 2010 11:49 am    Post subject: Reply with quote
The other option is only let a recognized experienced top notch VW engine builder and shop to touch the parts. Additionally, VW has published all the pertenant specs. They are there for a purpose. If you arn't following the good published info it's best not to touch the engine.
71 Superbug
71 Westy
Joey
Joey is offline
PostPosted: Fri Jan 29, 2010 2:07 pm    Post subject: Reply with quote
Unlike the southwest where there's a VW shop in every town, here there isn't any. German Supply would probably be the closest (if you want to call 1063 miles close). This shop has done them for me a few times before (Sept. was the last time) and they were fine so I don't know what happened this time... maybe a different employee... I dunno. I gave them the specs from the Bentley.
Joey
germansupplyscott
PostPosted: Fri Jan 29, 2010 2:13 pm    Post subject: Reply with quote
i agree with this, it isn't easy to find machine or repair shops in canada with aircooled experience.
SL
