woliver Samba Member
Posted: Sun Jun 21, 2009 2:50 pm Post subject: Jacks and Jack Stand |
Hey-
I have a 1973 Super, and I think it's time to get going on those brakes. I just (like, hours ago) had the stock jack finally break on me, so I ran out and got one of those 2.5 ton floor jacks and a pair of jack stands. Then I got home a realized that I have no idea where to put the pressure of a floor jack to get it off the ground!
I would love to know if anyone has some good structurally sound jack points, preferably one in the front and one in the back. I assume that the beetle is jsut like any other car, and I can just stick the two stands under the axle once I get it up there?
Here is a link to a similar jack to the one I just bought, if anyone needs to look at it: http://shop.oreillyauto.com/ProductDetail.aspx?Mfr...yCode=3397
where would I jack the beetle up with this?
thanks!!! |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80520 Location: Sneaking up behind you
redrum71 Samba Member
Joined: August 07, 2006 Posts: 494 Location: No-wheresville KS
Posted: Sun Jun 21, 2009 3:02 pm Post subject: |
i've jacked my 72 up in th rear off the lower shock mount and put the stands on the torsion housing tubes, the front, I put it unber the frame head, and same for the stands _________________
72 FAT chick
71 baywindow -
67 Baja  |
jamesdagg Samba Member
Joined: August 18, 2007 Posts: 3364 Location: B.C.Canada
Posted: Sun Jun 21, 2009 3:03 pm Post subject: |
Glenn has posted that pic tirelessly for years! I keep a copy in my trunk for the mechanic when I get tires changed etc.
jim _________________ '72 FI Westy
'71 Super rear inside defrost vents no longer available |
Posted: Sun Jun 21, 2009 3:04 pm Post subject: |
Damn it Glenn, you beat me to it  _________________
72 FAT chick
71 baywindow -
67 Baja  |
Glenn  Mr. 010
Posted: Sun Jun 21, 2009 3:05 pm Post subject: |
| dasvolvo wrote: |
Damn it Glenn, you beat me to it  |
Giggity _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Sun Jun 21, 2009 3:08 pm Post subject: |
| Glenn wrote: |
| dasvolvo wrote: |
Giggity |
LMAO!!!!  _________________
72 FAT chick
71 baywindow -
67 Baja  |
Posted: Sun Jun 21, 2009 3:16 pm Post subject: |
hahaha, thanks all, especially quagmire over there  |
66foot Samba Member
Joined: November 19, 2006 Posts: 398 Location: Pacific Grove, California
Posted: Sun Jun 21, 2009 9:29 pm Post subject: |
REAR
ALTERNATIVE TO JACK STANDS IF YOU ONLY NEED AN EXTRA 3-4 INCHES
Pat (66foot) _________________ "The perfect race car crosses the finish line in first place and then falls to pieces."
Ferdinand Porsche |
unknown force Samba Member
Joined: September 25, 2008 Posts: 234 Location: San Diego
Posted: Sun Jun 21, 2009 10:38 pm Post subject: |
thats where i jack up the rear as well, except that my stupid jack keeps breaking my pieces of wood dumbster diving is failing me _________________ 1973 Super
http://www.cardomain.com/ride/3252228 |
mikepickard Samba Member
Joined: September 23, 2009 Posts: 26 Location: Melbourne, Australia
Posted: Wed Sep 23, 2009 5:28 pm Post subject: |
Awesome. Exactly what I've been looking for.
A bit confused that you've jacked it at points different to the diagram though...
I don't suppose anyone has images of where to jack the front do they ?
(sorry, like the OP - I need it all jargon free!) |
askinsb Samba Member
Joined: May 04, 2009 Posts: 65 Location: Broomfield, CO
Posted: Sat Sep 26, 2009 11:13 am Post subject: |
| I'd also like to see a picture of where to put the floor jack in the front, but for a 69 Ghia. |
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Tue Mar 09, 2010 12:59 am Post subject: |
| And for A super, The back is the same. I also yous my floor jack under the stock jacking point just go back as far on it as you can (if you do it at the end it well bend )... And for the front, If I'm just changing A wheel/tire I go to the front sway bar mount, I have also put the floor jack under the "A pillar" in front of the door, if your going to be putting it on jack stands then I'd jack it up on the pan head, and place the jack stands under the sway bar mounts.. |
66foot Samba Member
Molly1973 Samba Member
Posted: Thu Jan 23, 2014 10:44 am Post subject: |
| Great post here! I haven't been doing this correctly...but will for sure now! |
RedBug99 Samba Member
Posted: Mon Jan 30, 2017 6:03 am Post subject: |
Appreciate the info here, but just so I'm clear, would you place the jack stands under these points (rather than the rear axle), or just use these points to raise the car?
GArBa Samba Member
Joined: January 27, 2014 Posts: 2129 Location: Milano, Italy
Posted: Mon Jan 30, 2017 9:40 am Post subject: Re: Jacks and Jack Stand |
for the rear axle I used a trolley jack under the end torsion tube castings (there is a flat spot at the bottom) to lift each side of the car and then placed the stands under the tubes where shown in the picture.
for the front axle I used a chock of wood and lifted it from the center with the trolley jack , then placed the stands at its ends like shown in the picture _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
Longmont1302 Samba Member
Joined: October 01, 2015 Posts: 332 Location: Longmont, CO
Posted: Tue Oct 24, 2017 8:50 am Post subject: Re: Jacks and Jack Stand |
I'd like to make sure I've interpreted Glenn's image correctly before I relax the jack on our 71 Super. If I'm reading the following chart correctly I've placed the jack stands under the track control arms: https://www.thesamba.com/vw/gallery/pix/663882.jpg
Once the weight is off the axle these arms drop down and it's tough to get the jack stand out very far from the center of the car.
Here's where I have the jack and have placed the jack stands:
...and a second view:
It just doesn't feel right, but this looks to me like where the red Xs are in Glenn's diagram. Thanks in advance for any help you can offer. |
Glenn  Mr. 010
Posted: Tue Oct 24, 2017 9:01 am Post subject: Re: Jacks and Jack Stand |
You have a Super Beetle and the diagram is for a Standard Beetle with torsion bar beam.
Don't put them there. _________________ Glenn
Member #1009
#BlueSquare
Posted: Tue Oct 24, 2017 9:06 am Post subject: Re: Jacks and Jack Stand |
Thanks, Glenn. I feel silly for missing "on Standard Beetle" written in large letters, but feel a little better that it somehow didn't feel right and I didn't release the jack.
Anyone have a suggestion of where I should put the jack and stands on the 71 Super?
Scott |
