Re-Key or Replace ignition housing?
CaliforniaShagWagon
CaliforniaShagWagon is offline
PostPosted: Sun Aug 28, 2005 4:58 pm    Post subject: Re-Key or Replace ignition housing? Reply with quote
The Story is long and embarassing but the end of it leaves me Keyless to my 64' Bus. The Doors and ignittion keys were not matching. A rekey is quoted at 200 bucks, a new ignition switch is 30. How hard is it to change out the ignition switch?
Shaka,
Adam
coolerthanelvis
coolerthanelvis is offline
PostPosted: Sun Aug 28, 2005 5:23 pm    Post subject: Reply with quote
As long as the door and ignition are the same key profile, it's fairly easy to rekey them yourself. The ignition is very easy to remove. Remove the battery cables first. I can't stress enough how important this step is. One of the wires at the ignition switch is coming, unfused, directly from the battery. If it grounds out, it will at the very least fry that wire and could fry all the wires in the harness coming from the engine compartment. Battery disconnected? Good. Now remove your parcel tray. Loosen screws in the steering shaft grommet to swing the parcel tray support out of the way. Remove wires from back of ignition switch. Remove screw (there's only one) from bottom of ignition switch. Pull switch out.
Now that it's out, take a jeweler's screwdriver and remove the clip in the back that holds the switch together. The tumbler assembly can be pushed out the front and you can rearrange the wafers in there until your key works. At least some of them should work with your key and you can leave some out or file them a little to make them work.
Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob
Campy
Campy is offline
PostPosted: Sun Aug 28, 2005 9:37 pm    Post subject: Reply with quote
I removed the ignition switch from my 1963 bus fairly easily without removing the tray.
justcruzin
justcruzin is offline
PostPosted: Sun Aug 28, 2005 9:48 pm    Post subject: Reply with quote
Me too!! I even put a different one in and then had to remove it because I think it was a bug ignition. So now I have the bug ignition one hooked up on the outside until I can get a replacement bus one!!!
justcruzin
Yalmar
Yalmar is offline
PostPosted: Mon Jul 06, 2009 11:47 am    Post subject: Reply with quote
justcruzin
Going to change my ingnition switch - removed the "electrical cabel-plate" on the other side... BUT it seems that the switch is locked by a "pin "(?) - not a screw - from underneath. On the attached picture - you'll see hole where the "pin" enters,..... http://www.justkampers.com/shop/type_2_split/vw-ca...14354.html
how do I get the switch loose ?
thom
thom is offline
PostPosted: Mon Jul 06, 2009 12:04 pm    Post subject: Reply with quote
That's a threaded hole - just a crappy picture.
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
Yalmar
Yalmar is offline
PostPosted: Mon Jul 06, 2009 1:08 pm    Post subject: Reply with quote
So its a screw then - not a bolt...... ? just have to find the corect screwdriver then....
volksaddict
volksaddict is offline
PostPosted: Mon Jul 06, 2009 7:36 pm    Post subject: Reply with quote
Thats a really sorry ass way to rig an ignition switch. Heck, might as well take all the tumblers out and just use a screwdriver as a key! If you can't redo the tumblers properly, using all of them, send it to gabvwkeys who advertises here and he'll fix it right. And it won't be anywhere close to 200 bucks. Geeze, he can probably even make your ign match the doors (1 key like factory) for less than 200 bones!
rebapuck
rebapuck is offline
PostPosted: Mon Jul 06, 2009 8:50 pm    Post subject: Reply with quote
I recently replaced my ignition( by myself!!) and it came with 2 keys. I'm kind of paranoid and like to have more than enough keys. The two biggest locksmiths (and 3 smaller) in the area could not find a key blank to match. Am I stuck? Or could the vw key guy come up with one? The problem is it's a generic switch from BusBoys. But where could I get a VW one?
Judy
1966 Camper "Hannah"
1967 SingleCab "Khady"
PostPosted: Mon Jul 06, 2009 11:18 pm    Post subject: Reply with quote
Originally it was a flat-head screw but yes, it removes quite easily. One of the wires is live so you should disconnect the battery first.
WM971252
WM971252 is offline
PostPosted: Tue Jul 07, 2009 10:47 am    Post subject: Reply with quote
Yep the "replacement" switch (available for Bugs too) are some weird key profile that I have not heard of any blanks around (but still trying...).
Andrew
Andrew is offline
PostPosted: Tue Jul 07, 2009 7:41 pm    Post subject: Reply with quote
Shaka,
Adam
A rekey should not be that expensive. Talk to this guy. You should be able to just send him all of your handles and ignition switch and he'll cut you a set of VW keys and key them all the same for less than $200.
http://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=7058
You're not going to be able to get a VW key for a generic switch. You'll have to replace that generic switch with a VW ignition switch. Talk to the same that I just told the guy above to talk to and he should be able to set you up with an ignition switch and a set of keys and be able to key it to the rest of your VW.
-Andrew
Clara Premium Member
Clara is offline
PostPosted: Tue Jul 07, 2009 9:27 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search
To have the one key system you need to buy the ignition switch with the correct key profile for your bus.
67 only is L (like 20L123),
64-66 is T profile (like T1234),
55-63 is the kind that have number letter number like 4Z1
55-60 are screw terminal, 61 & later are push terminal.
They are physically interchangable and fit 55-67, like the new ones, but the above are particulars to keep in mind if you want a one key system, and don't want to mess original wireing up.
The key code is here:
Yalmar
Yalmar is offline
PostPosted: Wed Jul 08, 2009 1:43 pm    Post subject: Reply with quote
huuuh - mine is stuck. Does someone have any photos showing the inside.
Do I have to un-screw the hole steering-shaft - and "enter from above"... Rolling Eyes Laughing
scottydub
scottydub is offline
PostPosted: Tue Feb 06, 2024 12:47 pm    Post subject: Re: Re-Key or Replace ignition housing? Reply with quote
Is it possible to make a key with a key code from the ignition?
Eric&Barb
Eric&Barb is offline
PostPosted: Tue Feb 06, 2024 3:13 pm    Post subject: Re: Re-Key or Replace ignition housing? Reply with quote
A proper old fashioned lock shop should be able to cut such for you. That is why the key code is there.
In Stereo, Where Available!
BarryL Premium Member
BarryL is offline
PostPosted: Tue Feb 06, 2024 7:04 pm    Post subject: Re: Re-Key or Replace ignition housing? Reply with quote
This guy will make and mail it to you.
https://gabvwkey.com
scottydub
PostPosted: Tue Feb 06, 2024 7:19 pm    Post subject: Re: Re-Key or Replace ignition housing? Reply with quote
Great! Where can I find the code? Is it on the ignition
Eric&Barb
PostPosted: Tue Feb 06, 2024 9:12 pm    Post subject: Re: Re-Key or Replace ignition housing? Reply with quote
scottydub
PostPosted: Wed Feb 07, 2024 1:41 pm    Post subject: Re: Re-Key or Replace ignition housing? Reply with quote
Excellent! Thanks
