kerian159 Samba Member
Joined: February 24, 2008 Posts: 344 Location: Pensacola, FL
Posted: Wed Aug 19, 2009 6:36 pm Post subject: '76 Type IV Engine Tin |
I've got a '76 Camper with slim type iv heaterboxes (411 style) and i'm missing the bottom engine tin. My question is, are the tin from early type iv engines and 411/412 the same? My brother is going to be going to a car show this weekend and if I could find out to let him know that would be good.
I switched to the slim heaterboxes to get abit more power out of the engine as per a few other posts on thesamba
Thanks,
Jay _________________ 1976 Type II Westy P22
"Growing older, but not up!" |
Posted: Thu Aug 20, 2009 7:58 am Post subject: |
anybody?  _________________ 1976 Type II Westy P22
73kombi Banned
Joined: April 11, 2006 Posts: 1215 Location: ~The London Bridge, AZ~
Posted: Thu Aug 20, 2009 8:02 am Post subject: |
I can't speak for the bottom tin, but I know the rear tin (bumper side) on a 411 is a 2 piece unit instead of 3.....I had that on my bus when I got it, impossible to remove in a bus without bending the pieces.
You might want to cross post this query in the 411 forum? |
Posted: Thu Aug 20, 2009 9:48 am Post subject: |
I might just do that. I figured since alot of people have changed over to those style heater boxes they would have to of changed the tin aswell. _________________ 1976 Type II Westy P22
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52663 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Aug 20, 2009 10:34 am Post subject: |
I'm still mystified by these power adding slim heat exchangers, more power?? Where are these posts? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Thu Aug 20, 2009 11:32 am Post subject: |
busdaddy wrote: |
I'm still mystified by these power adding slim heat exchangers, more power?? Where are these posts? |
I think it's a misconception caused by the fact that these heat exchangers are popular for type4 into type1 or type3 conversions due to the fact that they are smaller and easier to fit.
The exhaust flow through these is almost identical to that of '72-'74 bus heat exchangers exept that they are a wee bit shorter, which is no advantage on the already short exhuast of an air cooled vw.
Of course they do flow better than '75 and later bus exchangers, as do the '72-'74 bus exchangers.
If it was me I would go with the '72-'74 bus exchangers as the lower tin is easier to find. I also don't live in Florida so I like a little heat once in awhile. _________________
modok wrote: |
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold |
Posted: Thu Aug 20, 2009 2:06 pm Post subject: |
are the heater boxes different? between the type iv cars and the type iv engine used in the early buses? _________________ 1976 Type II Westy P22
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Thu Aug 20, 2009 3:16 pm Post subject: |
kerian159 wrote: |
are the heater boxes different? between the type iv cars and the type iv engine used in the early buses? |
Yes..... size difference. Top one is a 72-74 left, lower one is a 411/412 left when it came with the BA4 heater. The BA4 heater needed pre-heated air. The hot air tubes for the blower fan are also in a different spot.
Posted: Fri Aug 21, 2009 7:43 pm Post subject: |
Thanks Karl, pictures is just what I needed. I will be able to look at my heater boxes tomorrow to figure out which one i've got so I can start looking for the correct tin. Thanks again for the help
Posted: Sun Sep 06, 2009 10:14 am Post subject: |
Apparently i've got the 411 heaterboxes so if anybody has spare tin let me know
