Input shaft seal removal
jbow1076
jbow1076 is offline
PostPosted: Sat Aug 22, 2009 12:27 pm    Post subject: Input shaft seal removal Reply with quote
Hi All, I am trying to remove the input shaft seal on my 70 fastback and it is giving me fits. Does anyone know any tricks to removing this seal? thanks, Jeff
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sat Aug 22, 2009 12:37 pm    Post subject: Reply with quote
Mine are home made, but they work.
Gary: OK. Ima poop.
jbow1076
jbow1076 is offline
PostPosted: Sat Aug 22, 2009 12:57 pm    Post subject: Reply with quote
is the original seal a rubber rings with metal inside? I have the rubber off and now I can't figure out how to get the metal out...ugh!
Russ Wolfe
PostPosted: Sat Aug 22, 2009 12:59 pm    Post subject: Reply with quote
Yes, the seal is made from a metal base with rubber over that.
You will have to get that metal piece out.
Gary: OK. Ima poop.
Woreign
Woreign is offline
PostPosted: Sat Aug 22, 2009 2:21 pm    Post subject: Reply with quote
I have had good luck drilling a long screw into the metal part of the seal, and then using a hammer to pull on the screw and pull the seal out. I typically have to drill two screws, one on each of the seal, to remove it.
Tony K
Tony K is offline
PostPosted: Sat Aug 22, 2009 3:20 pm    Post subject: Reply with quote
I used a seal puller on mine. $8-10 at Sears I believe.
Russ Wolfe
PostPosted: Sat Aug 22, 2009 8:05 pm    Post subject: Reply with quote
That is kind of like the factory one.
Gary: OK. Ima poop.
