Oil Cooler Seals leaking.... Again.
Page: 1, 2, 3, 4, 5  Next
jimmynotch
jimmynotch is offline
PostPosted: Mon Aug 24, 2009 8:30 pm    Post subject: Oil Cooler Seals leaking.... Again. Reply with quote
I replaced the oil cooler seals this weekend after the ones I put in three months ago totally failed. I had left my car for 2 weeks while I went on vacation and came home to a poorly running motor and a massive douching from the oil cooler seals. I replaced the oil cooler seals and checked for cracks in the cooler. There were none. Today I took the car for a drive and voila!- the cooler seals are leaking again. Not nearly as much as before, but still a wet spot on top of the motor- which can only get worse not better. What the hell do I do now?
Jim in Sacto -
my wonderful loving supportive wife wrote:
You guys are dorks.
1965 1500-S Notchback --"Maggy"
1971 Type 2 Double Cab --"George"
TOOB member #2
JSMskater
Samba Grease Gorilla
JSMskater is offline
PostPosted: Mon Aug 24, 2009 8:40 pm    Post subject: Re: OIl Cooler Seals leaking.... Again. Reply with quote
you sure you have the right seals/cooler combo? do you have the bracket/spacer/plate thingie that keeps you from over tightening the cooler and squishing the seals too much?
71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors
jimmynotch
PostPosted: Mon Aug 24, 2009 8:58 pm    Post subject: Re: OIl Cooler Seals leaking.... Again. Reply with quote
No I am not sure that I have the right seal/cooler combo. I was under the assumption they were universal. And there was no bracket/spacer/plate thingy (is that a technical term? Very Happy ). What is there to prevent over tightening are three thick washer/spacer thingys that go between the case and cooler on each bolt. Should I have used some gasket sealer of some sort?
Jim in Sacto -
You guys are dorks.
TOOB member #2
Tram
Samba Socialist
Tram is offline
PostPosted: Mon Aug 24, 2009 9:00 pm    Post subject: Re: OIl Cooler Seals leaking.... Again. Reply with quote
NO GASKET SEALER. Shocked If you want to try a different cooler, PM me. I may have the bracket also. I'll see if I have something cooler- wise in the AM.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
rosevillain
rosevillain is offline
PostPosted: Mon Aug 24, 2009 9:38 pm    Post subject: Reply with quote
If you have the early case (single relief), and an early cooler, use the thick seals with the spacers. If you have a late case and cooler, use the thin seals without the spacers. If you have a late case and early cooler, or an early case and late cooler, use the adapter seals. Late has 10mm holes, early has 8mm holes in both the case and the cooler.
jimmynotch
PostPosted: Mon Aug 24, 2009 9:40 pm    Post subject: Reply with quote
But the cooler looks brand f'ing new. I mean I scotch brighted it and put on my reading glasses looking for cracks. Nothing. Bad seals again, maybe? And why no sealer?
Jim in Sacto -
You guys are dorks.
TOOB member #2
Tram
Samba Socialist
Tram is offline
PostPosted: Mon Aug 24, 2009 10:24 pm    Post subject: Reply with quote
The sealer can come off and plug the cooler.
Bryan67 wrote:
Those who can- do.
Russ Wolfe
Russ Wolfe is offline
PostPosted: Mon Aug 24, 2009 10:39 pm    Post subject: Reply with quote
I do not remember which, but I can look in the morning.
One style cooler has the part number stamped, and the other does not.
But right now, it is late and I do not remember which is which.
Gary: OK. Ima poop.
jimmynotch
PostPosted: Mon Aug 24, 2009 11:17 pm    Post subject: Reply with quote
Russ- What does the difference in oil coolers have to do with? Type of seal to use or something else? And if I used a VERY conservative amount of sealant...
Jim in Sacto -
You guys are dorks.
TOOB member #2
Tram
Samba Socialist
Tram is offline
PostPosted: Mon Aug 24, 2009 11:21 pm    Post subject: Reply with quote
I'll make you a smokin' deal you can't refuse.
If you can show me sealer on the oil cooler seals in the parts book, and give me a part number, I'll let you use it. Deal? Don't go pestering Uncle Wolfie when Uncle Tram says "NO!!!"
Seriously. Let's get to the bottom of your problem and FIX IT. Sealant is for American cars.
Bryan67 wrote:
Those who can- do.
JSMskater
PostPosted: Mon Aug 24, 2009 11:24 pm    Post subject: Reply with quote
I'll second that. Sealant is farking terrible, it goes everywhere you DONT want it to and fails to seal what you DID want it to. just get the right seal/cooler combo and use the bracket and you won't have any leaks.
TOOB Member #3
Tram
Samba Socialist
Tram is offline
PostPosted: Mon Aug 24, 2009 11:26 pm    Post subject: Reply with quote
Plus, I'm pretty damn sure that sealant is not '1500 Club' approved!
Bryan67 wrote:
Those who can- do.
jimmynotch
PostPosted: Mon Aug 24, 2009 11:51 pm    Post subject: Reply with quote
Well I am certainly glad that Unkie Trammy and JMSkatard can flip me a bunch of crap over the issue of sealant. Fine. No f-ing sealand. But one of you two better help fix the problem rather than sit back in your easy-chairs driving the keyboard in your underpants.
Jim in Sacto -
You guys are dorks.
TOOB member #2
JSMskater
PostPosted: Tue Aug 25, 2009 12:14 am    Post subject: Reply with quote
We can tell you what to do but you gotta do the wrench turnin' buddy. pull that cooler off and replace the seals with the right combo!
TOOB Member #3
jimmynotch
PostPosted: Tue Aug 25, 2009 12:26 am    Post subject: Reply with quote
What is the right combo? which cooler with which seals matched to the case I have?
Jim in Sacto -
You guys are dorks.
TOOB member #2
JSMskater
PostPosted: Tue Aug 25, 2009 12:34 am    Post subject: Reply with quote
whats the code stamped on your case? (the one printed on the top nearish the fuel pump right along the seam in the case) that's the first step in determining what you have. the second is finding the part number on your cooler. (Russ was talking about that earlier) this will tell us if you have an early cooler and case, a late cooler and case, or some combination between the two. Then we can recommend the correct seal and whether or not you need the bracket/spacer. kapeesh?
TOOB Member #3
rosevillain
PostPosted: Tue Aug 25, 2009 1:08 am    Post subject: Reply with quote
The right seals fit in the cooler and the case without having to force them. The holes are either 8mm or 10mm.
My guess is that you have an old case and a new cooler.
Tram
Samba Socialist
Tram is offline
PostPosted: Tue Aug 25, 2009 9:41 am    Post subject: Reply with quote
I don't wear underpants. Have you forgotten so soon?
Bryan67 wrote:
Those who can- do.
Russ Wolfe
PostPosted: Tue Aug 25, 2009 9:50 am    Post subject: Reply with quote
And I have my blue work pants on.
The difference in the coolers, is in the size of the oil passages.
This determines which seals to use.
8mm case, 8mm cooler = thick cooler seals, and 2mm thick washers.
10mm case, 10mm cooler = thin cooler seals, and no washers.
10mm case, 8mm cooler = special seals with the washers in the kit.
8mm case and 10mm cooler = special seals with no washers.
Gary: OK. Ima poop.
jimmynotch
PostPosted: Tue Aug 25, 2009 10:56 am    Post subject: Reply with quote
So then I will go look at the case number and the oil cooler number and hopefully we can figger it out. Spacers, washers, seals, oh my!
Jim in Sacto -
You guys are dorks.
TOOB member #2
Page 1 of 5
