donny1973 Samba Member
Joined: November 21, 2008 Posts: 317 Location: Palm Beach, FL
Posted: Sat Aug 29, 2009 5:23 pm Post subject: Body Off - Pleasant Surprise |
I finished the engine for my '68 vert a couple of months ago and it's been sitting on my bench as I wrestled with the idea of pulling the body the do the pans. Well yesterday I took the plunge and the following are some pics of the job thus far.
This was a one owner car that I brought back to Palm Beach from the dry Texas climate. It's been parked in the original owner's garage for the past 19 years and I knew it was clean, but I fully expected to find some rust issues when I lifted the body. Well to my amazement, there was absolutely no rust to speak of. All the typical problem areas are perfect - the heater channels, convertible suppor rails, package tray, etc. And this is an OG paint car, so there's no hidden atrocities on the outside either. I knew it was a good sign when all the body bolts came out easily.
This is my first VW and pulling the body was surprisingly easy (at least compared to the American muscle cars I've done), about three hours total, by myself. And for those who may be wondering, I didn't use any additional bracing and my doors opened and closed perfectly while I had the body supported on 4x4's and cinder blocks by the front and rear bumper brackets. I had no other supports under the body, so if it was going to fold up like a taco, it would have done it then. This proves that if the support rails in a vert are good, extra bracing isn't necessary. I have since put the body on a dolly I built on a 4x8 utility trailer so I can move it around easily when it comes time for cleaning and paint.
Today I removed the right side pan and tomorrow I'll do the left and clean up the lips on the tunnel and front and rear cross members. I'll be ordering my pans from Wolfsburg West on Monday. Will post additional pics of the progress if anyone is interested.
Donny
74soupsoup Samba Member
Joined: July 27, 2009 Posts: 39 Location: Enfield, CT.
Posted: Sat Aug 29, 2009 7:59 pm Post subject: |
| Wow- theres no rust at all :2gunfire: :2gunfire: :2gunfire: :2gunfire: |
jhicken Samba Member
Joined: October 24, 2003 Posts: 9479 Location: Fallbrook, CA
Posted: Sat Aug 29, 2009 8:32 pm Post subject: |
Nice base, congrats on the fine. It should turn out to be a nice car when you got it all finished.
Click on http://www.cjvws.com/garagespace.html and scroll down to nelson Rogers '67 vert. His resto turned out real nice.
-jeffrey _________________ Der Kleiner Kampfwagens |
crx81 Samba Member
Joined: September 07, 2005 Posts: 177 Location: N.P.R. Fla.
Posted: Sat Aug 29, 2009 10:05 pm Post subject: |
Sweet! Maybe next time I buy I should consider going out west to find one... _________________ My site:
http://www.geocities.com/crx81/ |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Sat Aug 29, 2009 11:08 pm Post subject: |
CLEEEEEEEEEEEN!!!
thats gonna be a nice resto |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6544 Location: Northern Illinois
Posted: Sun Aug 30, 2009 6:42 am Post subject: |
outstanding!!! please tell me this will be a stock restoration? this car deserves it! _________________ Midwest Autosavers, Inc. Crystal Lake, IL |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6355 Location: 37.5N 77.1W
Posted: Sun Aug 30, 2009 7:06 am Post subject: |
| On the East Coast, what you have could be called a finished resto. |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5492 Location: North Texas
Posted: Sun Aug 30, 2009 7:34 am Post subject: |
| runamoc wrote: |
That is exactly what I was thinking. Very nice base. _________________ MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super |
vintageorbust Samba Member
Joined: November 07, 2006 Posts: 217 Location: Ridgecrest, CA
Posted: Sun Aug 30, 2009 8:18 am Post subject: |
Great engine too  _________________ Meredith Phillips
Silly riceboys... useless wings are for penguins!
Chicks that can work on their own cars?! Yeah I know we're hot =) |
Posted: Sun Aug 30, 2009 5:34 pm Post subject: |
| DrDarby wrote: |
| outstanding!!! please tell me this will be a stock restoration? this car deserves it! |
Thanks for the comments guys. I was kind of torn between a stock resto and a resto-mod. I think you're right that this one deserves to go stock. I built the motor to near stock specs, just a bit of a cam and striaght cut gears.
Here's some pics of today's progress. Got the left side pan cut out and chiseled the remnants away from the lips. During the week I should be able to get the chisel work done on the right side and both sides ground down, cleaned and coated with weld through primer so as to be ready for the new pans.
In order to be as close to factory appearing as possible, I'm going to count the factory spot welds on each side and use my air punch to make the same number of holes for plug welds. Yeah, I know it's a tad on the anal side, but...
Donny
Posted: Sun Oct 04, 2009 8:03 am Post subject: |
Back at it after a few weeks. Last night I cleaned up the passenger side floor pan lip on the tunnel and front and rear supports. No surprises, everything cleaned up nicely and the surfaces are ready for plug welding the pan in. I found it much easier to stand the chassis on its side and work standing up rather than leaning over with it on the ground. I'll flip it around and do the other side one night this week.
I've had my fresh motor sitting on the workbench for months. I finally got tired of looking at the unpainted heater boxes so I pulled them off and sprayed them the same grey color as the intake. Not sure if it's "factory correct", but it definitely looks better. More to come.
[/img] |
ach60  Samba Member
Joined: May 14, 2001 Posts: 4137 Location: Santa Maria
Posted: Sun Oct 04, 2009 7:43 pm Post subject: |
It looks nice, and I'm sure you'll do a nice job on the resto.
But these cars are only original once, and to be honest from the photos
I think the car was too nice to come apart.
Sorry for being a dick, enjoy it, and do what you want because it is your car. _________________ Good Luck
Al |
Posted: Mon Oct 05, 2009 7:36 am Post subject: |
| I hear you and agree to an extent. I'm a fan of survivor cars and have owned several. I would have left this car together but just knowing there was rust in the rear sections of the pans would have bothered me every time I drove it.Rather than patching them I opted to replace them with the heavier guage WW pans and duplicate the original welds as closely as possible. In my opinion, doing the job as close to the way VW did required pulling the body. Although it's a low milage car, when I tore the motor down, three of the pistons had broken rings. In addition, fuel has solidified through the entire original fuel line. Removing the old line and running a new one through the tunnel was much easier with the body off. The upshot is if I could have enjoyed the car in the condition it was in, I would have left it alone. |
rlutterb Samba Member
Joined: January 10, 2006 Posts: 1417 Location: Carrollton Ohio
Posted: Mon Oct 05, 2009 1:07 pm Post subject: |
My 73 super was in similar shape, with zero rust except the rear pans and the passenger front pan section. I left it together and did a very good weld in of the patch panels. To each his own I guess......drawback to leaving it on the pan is it's a bear to get to ALL of the little area's that one would like to paint
_________________ 1973 Super Beetle project
1978 VW convertable
1987 El Camino
1995 Miata M
2015 Chevy Silverado |
Posted: Sun Nov 15, 2009 7:53 am Post subject: |
Santa came early this year and left a a large box from Wolfsburg West. The project can now resume after a bit of a hiatus. After removing the original pans and cleaning up the tunnel lip, I stripped the paint from the beam, tunnel and trans and repainted them. I also removed the original fuel line from the tunnel and ran a new one via the same route. What a PIA even with the body off.
I'm quite impressed with the WW pans. Very heavy gauge metal and nice crisp stampings. I laid them in place and had to do a bit of trimming and shaping to get them to sit in perfectly and to get the measurements just right. I'm really glad I took measurements of the original pans before I cut them out. It's reassuring to know that everything will line up nicely when I drop the body back on.
With the pans in place, I got underneath and marked them around the outer edge of the lip with a sharpie. This gave me a reference point to use for punching the plug weld holes. I popped a hole about every 1.25" which is about the spacing of the original spot welds. Next I'll clean the paint off edge of the pans for good penetration, weld them in place and seam seal everything to prevent rust.
When the pans are done, I'll bolt in the fresh motor and take it over to Paul at JB Bugs to install the drop spindles, ball joints, tie rod ends and trailing arm seals. I hope to have the project wrapped up in time for Winter Jam.
whobba Samba Member
Posted: Sun Nov 15, 2009 8:34 am Post subject: |
| ach60 wrote: |
Sorry for being a dick, enjoy it, and do what you want because it is your car. |
I kinda felt that way, too. I felt sick to my stomach to see such a straight clean bug getting torn apart, but then realized that the new pans and engine are a good thing. There aren't very many original german bugs out there these days, they've all been dicked with to the point of no return. But this one will be nice and maybe the resto will enable the bug to last for another 40 years. _________________ **SUPPORT THE SAMBA**
http://www.thesamba.com/vw/donate.php
http://www.thesamba.com/vw/products/ |
whobba Samba Member
Posted: Sun Nov 15, 2009 8:35 am Post subject: |
| ach60 wrote: |
Posted: Sun Nov 15, 2009 8:40 am Post subject: |
Looks great and to your earlier post yes the heater boxes should match the intake. _________________ Midwest Autosavers, Inc. Crystal Lake, IL |
Fitz. Samba Member
Joined: October 06, 2009 Posts: 362 Location: Montavilla, Portland, Oregon
Posted: Sun Nov 15, 2009 9:51 am Post subject: |
Beautiful! I think I'd have done the same thing. If all it needed to be a rust-free car was new pans, I'd go for it. My '68 has a little surface rust in the rear package tray--which I've treated--and my pans are fine, with exception of the battery area, which has also been treated, and repaired with aluminum and pop-rivets. Cheesey, but it's a daily-driver so the rust it has will have to wait until I buy another car, and pull the body off this one... It's not too far off the condition of yours, and a body-off resto is definitely in my plans.
Again, nice car!  _________________ Settle down, it's a car. |
vwbud1973 Samba Member
Joined: April 24, 2007 Posts: 126 Location: Flanders, NJ
Posted: Sun Nov 15, 2009 11:46 am Post subject: |
You people and your rust free cars... I hate you all!
Seriously I'm jealous. I've got to replace/rebuild everything on my 73... pans, framehead, popes hat, and about 18 inches of the tunnel... I'll have the pics up here someday soon.
I think what you are doing is great. looks like you know what you are doing and you are doing it the right way. more people should! (the P.O. of my car especially!)
Good luck with the project!
What kind of bike is that in the background? Not a MotoGuzzi is it? |
