It won't start!
hrbe53
hrbe53 is offline
PostPosted: Thu Oct 22, 2009 3:08 pm    Post subject: It won't start! Reply with quote
After replacing every piece of the ignition on my 72 bug engine, the albatros still wont run. It did before i replaced it all. Now, i did install petronix electronic ignition, do i have to do some special tuning for this? Im completely lost here...
I did check for power, and everything IS getting power...
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
guitarcrazee05
guitarcrazee05 is offline
PostPosted: Thu Oct 22, 2009 3:15 pm    Post subject: Reply with quote
did you test if you have spark?
hrbe53
hrbe53 is offline
PostPosted: Thu Oct 22, 2009 3:16 pm    Post subject: Reply with quote
no spark...the first thing i check every time i try something...
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Oct 22, 2009 3:17 pm    Post subject: Re: IT WONT START!!! Reply with quote
Try points. Change too many things at once and you can't troubleshoot.
guitarcrazee05
PostPosted: Thu Oct 22, 2009 3:19 pm    Post subject: Reply with quote
just work backwards, no spark so check to see if the coils getting power
hrbe53
hrbe53 is offline
PostPosted: Thu Oct 22, 2009 3:20 pm    Post subject: Reply with quote
screw that! I've already gone through two sets cause every place has some different condensor or points that ends up frying. Dont doubt me, the last one gave a very very dark smoke...
hrbe53
hrbe53 is offline
PostPosted: Thu Oct 22, 2009 3:21 pm    Post subject: Re: IT WONT START!!! Reply with quote
guitarcrazee05
PostPosted: Thu Oct 22, 2009 3:21 pm    Post subject: Reply with quote
if your coils getting power and still no spark then i would say you either have a bad coil, your wireing to your distributer is wrong or you have a bad electronic ignition.
guitarcrazee05
PostPosted: Thu Oct 22, 2009 3:23 pm    Post subject: Reply with quote
ktphil's right, i hate points too but i have a good distributer set up with them that i can through in for just this situation. it's an easy way to tell
guitarcrazee05
PostPosted: Thu Oct 22, 2009 3:24 pm    Post subject: Reply with quote
could be somthing stupid like the wrong rotor or cap...
Buck Naked
Buck Naked is offline
PostPosted: Thu Oct 22, 2009 5:12 pm    Post subject: Reply with quote
But why did you get smoke? Did you get smoke just before this project began? Is this the reason for the complete replacement of the system? Have you checked battery voltage? Its possible that if you have tried starting it too much the battery isnt giving enough voltage to the electronic ignition module therefor no start, because the biggest draw(the starter) is using all the juice; nothing left for the little guys(the module)or like guitarcrazee05 said if its not working and its got power the coil or the module are dead.
Be unique, like everyone else.
'63 Beetle Ragtop
hrbe53
hrbe53 is offline
PostPosted: Thu Oct 22, 2009 7:25 pm    Post subject: Reply with quote
The condensor had an extra plug on it, it touched after i fought it for an hour trying to have it not, and it smoked my nose out! Also, im getting power clear to the center of the distributor cap. I think i have the wrong rotor. We just ant gettin any spark...everything else checked out... Crying or Very sad
guitarcrazee05
PostPosted: Thu Oct 22, 2009 7:35 pm    Post subject: Reply with quote
i thought you said you had an electronic ignition? you don't use a condensor if you have an electronic ignition, it's all built in.
Buck Naked
PostPosted: Thu Oct 22, 2009 7:45 pm    Post subject: Reply with quote
he said something about smoke and i asked where it came from, thats why he broght up the condensor. that situation , i belive, is one reason he`s not gonna put points back in the car ever. from what i gather and someone else has suggested it its probably a bad cap or rotor
'63 Beetle Ragtop
drscope
drscope is offline
PostPosted: Fri Oct 23, 2009 7:09 am    Post subject: Re: It won't start! Reply with quote
hrbe53 wrote:
After replacing every piece of the ignition on my 72 bug engine, the albatros still wont run. ...
Don't blame the car....it ran before you fixed it!
There seems to be a little confusion as to when you got smoke.
If this was AFTER the pertronix was installed, my guess is you smoked the pertronix.
If it was before, well then maybe you did something else wrong when you installed the pertronix.
Same cap & rotor? If not, put the old ones back on and see what you get.
fastinradford
fastinradford is offline
PostPosted: Fri Oct 23, 2009 8:21 am    Post subject: Reply with quote
is the pertronix hooked up to the correct side of the coil?
95 jetta 5spd, (first waterpumper vw)
the nice 74 Ghia, (of course the fiance drives that one).
My mk1 jetta 1.6d
"It'd still be like my grandads old broom though, original, only 3 new heads and two new handles" -Marv [UK]
hrbe53
hrbe53 is offline
PostPosted: Sat Oct 24, 2009 6:32 am    Post subject: Reply with quote
Dur on the whole "electronic dont use condensors"
Yes, it is wired correctly.
The old cap and rotor are MIA, and smoke was before
