Woreign Samba Member
Joined: June 04, 2006 Posts: 2840 Location: Crestview FL
Posted: Sun Aug 17, 2008 2:40 pm Post subject: Exact location of the transmission vent hole? |
I want to check and make sure it's not clogged, but I have no idea where to look for it. Part schematics don't show the hole...
Thanks! |
shano63  Samba Member
Joined: October 06, 2006 Posts: 3650 Location: Stormville NY
Posted: Sun Aug 17, 2008 4:20 pm Post subject: |
Is there one?? I just put a refurb tranny in my car and I did not notice a vent hole. _________________ 63 T1 Ragtop Gulf Blue
20 Toyota Corolla 6spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Take it as it comes-- Morrison |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36456 Location: Conejo Valley, CA
Posted: Sun Aug 17, 2008 4:52 pm Post subject: |
| Not exact, but it's at the front top of the unit. I think pics have been posted. |
Posted: Sun Aug 17, 2008 5:06 pm Post subject: |
Is this it?
Posted: Sun Aug 17, 2008 5:19 pm Post subject: |
I stand corrected.  _________________ 63 T1 Ragtop Gulf Blue
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Mon Aug 18, 2008 5:05 am Post subject: |
Its in different places on different transmissions. Most are between the fins on the top of the nose cone. It is impossible to see them when the tranny is in the car. _________________ Mother Nature is a Mean Evil Bitch! |
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1330 Location: Beautiful New Zealand
Posted: Sun Nov 01, 2009 6:59 pm Post subject: |
Should this vent hole be completely clear then? Mine looks to be at least partially blocked with crud.
I have my transmission out to deal to a leak from the three detent plug holes, the original plugs are long gone. I found a good amount of tranny fluid lying in the tunnel under the shift coupling and it seems it may have travelled along the shift rod where it exits the nosecone. Pressure buildup from a blocked vent hole might exacerbate this maybe?
Here are a couple of pics of the holes left by the crumbled detent plugs as I didn't really find any images in my searches. They look about 10mm diameter and about as deep. I'm going to try sealing them with a nylon plug and some RTV...
_________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
Jeckler Samba Member
Joined: September 27, 2005 Posts: 2718 Location: Mesa, AZ
Posted: Sun Nov 01, 2009 8:40 pm Post subject: |
I used a wooden dowel and some Goop to seal mine up. _________________ Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
| bill may wrote: |
| I am the crabby old guy. |
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad. |
engineerscott Samba Member
Posted: Sun Nov 01, 2009 9:10 pm Post subject: |
| Jeckler wrote: |
| I used a wooden dowel and some Goop to seal mine up. |
Just a question (that I don't know the answer to) but is that wise? Surely the engineers that designed the unit had some rational for wanting to vent it. Perhaps to avoid pressure build up or vacuum in the transaxle housing as the internal temperature changed?
I can certainly understand the desire to close up a entry point for moisture or other contaminates. |
Posted: Sun Nov 01, 2009 10:12 pm Post subject: |
Sorry, wasn't clear. The detent plugs on mine were gone as well, so those holes are what I sealed up. _________________ Andy
| bill may wrote: |
