emergency brake cables
extremebuggy
extremebuggy is offline
PostPosted: Wed Nov 04, 2009 7:39 pm    Post subject: emergency brake cables Reply with quote
I am replacing the emergency brake cables on my fiberglass buggy car, and I heard that the pan is shorten on these cars. So can anyone tell me where I can find an emergency brake cable that will be short to accomodate the shortened pan.
BL3Manx
BL3Manx is offline
PostPosted: Wed Nov 04, 2009 9:04 pm    Post subject: Reply with quote
I would never use one of the clutch cable shortening fittings but I've never had any problem with these on my parking brake cables.
http://www.thesamba.com/vw/classifieds/detail.php?id=720600
57streetrodbuggy
57streetrodbuggy is offline
PostPosted: Wed Nov 04, 2009 9:57 pm    Post subject: Reply with quote
they are pretty good but for some reason they dont sit flush against the E-brake handle (or at least they dont with the cheap chrome E-brake handles). mine actually angled out away from the handle because the lower part was too wide and hit the handle before going through the little bracket on top. i ended up grinding off some of the excess metal from the shorteners and cutting a bit out of the E-brake handle mount on the tunnel to give them clearance.
Bermoco buggy on 57 pan - under construction
There's no such thing as too much horsepower, there is only a point where the car breaks in two
Dale M.
Dale M. is offline
PostPosted: Thu Nov 05, 2009 8:22 am    Post subject: Reply with quote
Determine the length you need and have custom cable made....
http://www.push-pull.com
Yes they do custom length VW brake and clutch cables....
Check last page of "products" sheets (pages)....
Dale
bornred62
bornred62 is offline
PostPosted: Thu Nov 05, 2009 8:11 pm    Post subject: Reply with quote
I've used the ones above for years with no problems.Just a few things you need to do. First of all get rid of the chrome e-brake handle.
Pick up a later model handle that has the pivot and the mounting bracket.
mounts on the pivot and the threaded ends go through. Gets them away from the handle a bit. then put the shortener in a vise and drill it deeper
so more cable goes into the end. I also drill on the other side of the set screw a little higher and install another set screw. It aint coming out.
Gene C
Gene C is offline
PostPosted: Thu Nov 05, 2009 11:35 pm    Post subject: Reply with quote
I learned a neat install of the shortened cable
Was to take the longest length cable and then cut it ( right about the rear of the tunnel) and over lay them with two U clamps to splice them together
That way you have the stock threads that fit coming through the handle
easy to get the right length and adjust
Gene C
Burlingame Ca
BL3Manx
BL3Manx is offline
PostPosted: Fri Nov 06, 2009 9:21 am    Post subject: Reply with quote
Those are good tips. Too bad that's not the way they come.
I have a some that were made in the 60's, that were made from square stock instead of hex stock, so they have a narrower cross section and lay flatter against the side of the handle. I also put the early rubber boot over the handle so you can't see if the adjusters are a little pigeon toed.
extremebuggy
PostPosted: Thu Nov 12, 2009 5:58 pm    Post subject: Reply with quote
I know you have to cut the cable but how does these connect to the end of the cable that has been cut?
BL3Manx
BL3Manx is offline
PostPosted: Thu Nov 12, 2009 6:08 pm    Post subject: Reply with quote
The shortened cable goes inside the hole on the end of the fitting then the set screw is tightened. Make sure the set screw is backed off so the cable goes all the way to the end of the hole. Once its in all the way, tighten the set screw hard.
Use a Dremel with a thin cut off disc to cut the cable. It also helps to wrap some masking tape around it at the place you cut. You don't want the strands to unravel when you cut it.
Glasser
Glasser is offline
PostPosted: Thu Nov 12, 2009 7:38 pm    Post subject: Reply with quote
Another way to cut them is with a wire feed welder. Just don't hang on to the cable while welding / cutting it, it's gets dam hot fast! The welder will melt the cable in half and weld the ends closed so no fraying. Some trial and error to get the heat set right but works nice when you get it right.
I used the chrome handle and ran into the same problem. I modified it with the old type system so got he best of both worlds Smile
Brent
My build up http://www.thesamba.com/vw/forum/viewtopic.php?t=265364&postdays=0&postorder=asc&start=0
Project#2. Neighbors build up. http://www.thesamba.com/vw/forum/viewtopic.php?t=327008
Mongo63
Mongo63 is offline
PostPosted: Fri Nov 13, 2009 12:23 am    Post subject: Reply with quote
I drilled and tapped an extra set screw location opposite and higher than the original just to ease my worried mind.
Southside Buggistas VW & kit car club
www.southsidebuggistas.com
Mongo only pawn in game of life...
mharney wrote:
Behold the true power of the extractor! Mongo has it right!
lostinbaja
lostinbaja is offline
PostPosted: Fri Nov 13, 2009 5:50 am    Post subject: Reply with quote
I usually drill the set screw hole all the way through so when the set screw is tightened the cable has a couple more corners to add extra friction to keep the cable from slipping.
Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92
