Type-1 TO Type-2 Coupler
mikes69baja
mikes69baja is offline
PostPosted: Wed Nov 18, 2009 8:29 pm    Post subject: Type-1 TO Type-2 Coupler Reply with quote
Is anyone using the Type-1 TO Type-2 Coupler made by EMPI to connect a 3rib tranny to a stock shift rod. I believe the connector allows you keep the shift rod in the tunnel without using a 10deg kit. Im just wondering if it works.
Ed Carp
Ed Carp is offline
PostPosted: Wed Nov 18, 2009 8:39 pm    Post subject: Reply with quote
i have that set up. it works just fine. at first i couldn't get it to hookup. angle seemed wrong and was just a hair to short. i pulled the shift tube and found it was quite bent. so i stuck it in a press and simply bent it back as straight as i could. hooked it up and shifts fine. only used it for a weekend at pismo so far. and you know if anything is gonna break it'll do it out in the dunes. but i do plan on putting the shifter on top of the tunnel when i can afford.
1969 money pit, i mean baja.
chenoworth look alike sand rail
i believe bugpack rail?
dirtkeeper
dirtkeeper is offline
PostPosted: Wed Nov 18, 2009 8:57 pm    Post subject: Reply with quote
I think the stock shift rod has a bend in it
and if it works fine why are you considering putting it on top of the tunnel?
mikes69baja
PostPosted: Wed Nov 18, 2009 9:36 pm    Post subject: Reply with quote
I think all the shift rods have a bend in them. Good to know it works. I have not been able to make up my mind on how im going to mount my new 002 tranny. finally decided on not using the 10 deg kit.
thesatelliteguy
thesatelliteguy is offline
PostPosted: Wed Nov 18, 2009 9:57 pm    Post subject: Reply with quote
not trying to steal your thread, but what other ways are there to mount the 002 trans? if you use a 10 degree kit, the coulper has to be out of the tunnel?
Toyotas are so bumpy it makes me sick, literally.
My build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=383878
mikes69baja
PostPosted: Wed Nov 18, 2009 10:30 pm    Post subject: Reply with quote
well the two main ways are to use the 10 deg kit which mounts the trans on an angle to put the nose cone in the tunnel. if u use the bus to bug mount the shift rod sits on top of the tunnel. unless u use the empi adaptor. The 10 deg kit seems like a rip off to me pacific customs wants $165 for it. Bus to bug is like $35.00
Gary Massin-Ball
Gary Massin-Ball is offline
PostPosted: Fri Dec 04, 2009 2:32 pm    Post subject: Reply with quote
I have the bug to bus in my rail with the aluminum adapter. It was short too so I took the welds off the end of the tube and was able to slide the sleave out 1/2" I needed and welded it back up.
I was skeptical about the strength and accuracy of the adapter but it works fine and I really can't tell the differene from the bug trans set up.
I did install a new shift ball in the linkage in the nose cone and boxed the carrier to make it stiffer. I also because the main bearing had pounded into the nose cone about .040 to .060" I had the nose cone milled down and installed a beef plate between the nose cone and housing.
