redlines4us Samba Member
Joined: October 29, 2009 Posts: 206 Location: Pennsylvania
Posted: Thu Dec 03, 2009 3:44 pm Post subject: Can I run this combo with drop spindles |
Can I run this wheel & tire combo with 2-1/2" drop spindles on my '74 Classic Standard Beetle (Not Super).
I plan to lower the rear with torsion bar adjustment.
Chrome Smoothie Wheels - 4x130 Lug, 15”d x 51/2 w with DUNLAP GT QUALIFIER Tires, 195/50R15
Think I'll have any clearance problems anywhere. I'm buying these used, so another tire size is not an option.
Thanks! Bill
P.S. Not my car pictured, but the car they are on now. Should look the same on mine without being lowered, Looks like plenty of clearance to lower it. Any opinions?
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80077 Location: Sneaking up behind you
Posted: Thu Dec 03, 2009 3:49 pm Post subject: |
It's not the drop but the offset of the rims.
First off a 1950/50-15 is a pretty small (diameter) tire so in the rears you'll have to push the engine harder to maintain the same speed as a stock size tire.
I have 195/60-15 on 5.5x15 ET42 rims with the front dropped 3" with AVIS adjusters. If it weren't for the deep offset of the rims, the tires would rub. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Derek Cobb Annoying
| If you drop it, it'll rub. The drop spindles add width and I can see on the other car that the tire tread is already past the inner lip (and outer) of the fender. If you don't narrow the beam, it'll rub. |
Posted: Thu Dec 03, 2009 4:23 pm Post subject: |
So are you suggesting a narrowed beam without drop spindles. Would I order an adjustable narrowed beam? If so what width for this wheel & tire combo. I usually order parts from California Import Parts. Can anyone tell me what part or parts I need. They seem to have all different beams. Sorry, but I'm new at this and don't want to order something I can't use.Thanks again! Bill
http://www2.cip1.com/SearchResults.asp?Search=beam&Search1=Search |
Glenn  Mr. 010
Posted: Thu Dec 03, 2009 4:29 pm Post subject: |
Dropped spindles push the wheels out further than stock, so you need a 2" narrowed beam just to break even.
It's cheaper to buy tires that fit than making the car fit the tires. _________________ Glenn
Member #1009
#BlueSquare
Posted: Thu Dec 03, 2009 4:35 pm Post subject: |
| So if I run those tires on the rear, what is the widest size tires to match the rears would you suggest for the front that would work with dropped spindles. I have to lower it somehow to close up that tire/fender gap. Thanks! Bill |
Glenn  Mr. 010
Posted: Thu Dec 03, 2009 5:24 pm Post subject: |
$450 is a lot for 4 steel rims. _________________ Glenn
Member #1009
#BlueSquare
Posted: Thu Dec 03, 2009 5:26 pm Post subject: |
I'm buying them used in like new condition with new tires for $400.
Those are just the same wheels I'm buying.
Bill |
Derek Cobb Annoying
Posted: Thu Dec 03, 2009 7:26 pm Post subject: |
| If you must use those tires and rims, then you should consider simply getting an adjustable, narrowed beam and skip the drop spindles. It sounds like you don't intend to 'slam' the bug, you just want to close up the fender gap. A two inch narrowed adjustable beam will allow you to drop the car exactly where you want it and it will get those big, fat tires under the fenders. |
Fattie I'd roll it
Joined: November 27, 2005 Posts: 5582 Location: louisiana
Posted: Thu Dec 03, 2009 8:30 pm Post subject: |
195/65r15 tires in the rear will be great ... it's what I'm running... I run 195/65r15's in rear and 195/50r15's in front...but I went slammed so I had to go with a 5" beam and spindles...but 4" may have worked as well
... I agree with Glenn 195/50r15's in the rear is just too short a tire
Now...
if you plan to run 195/50r15 tires in front with just drop spindles you will be fine
and empi 8's have an offset similar to what your working with and are 15x5.5 _________________ Donate and help me get another aircooled dub to share with you guys www.paypal.me/WhosCare |
Posted: Fri Dec 04, 2009 4:35 am Post subject: |
| Quote: |
Now...
if you plan to run 195/50r15 tires in front with just drop spindles you will be fine |
That's exactly the look I'm trying to obtain. Can't slam it due to the Pennsylvania pothole filled roads. So, from your pictures, I'll be just fine with 195/50r15 tires in front with just 2-1/2" drop spindles.
That's what I was hoping!
Thanks! Bill |
Derek Cobb Annoying
Posted: Fri Dec 04, 2009 5:15 am Post subject: |
| Fattie wrote: |
Now...
and empi 8's have an offset similar to what your working with and are 15x5.5 |
If you are telling me that the above car does not rub when you're going around a corner with a passenger and you stomp the brakes I have to call BS. Those tires are directly under the fender lip. That car will certainly rub. There are still labels glued to the tread, so you haven't even driven it yet. It'll rub. |
ratspud Samba Member
Joined: December 30, 2007 Posts: 138 Location: Columbia SC
Posted: Fri Dec 04, 2009 8:12 am Post subject: |
Those rims are wide for the front. I suggest a 4" narrowed beam with the drop spindle. Then use a 145-60 on the front. The 195's will be fine on the rear. You should have no rubbing issues with this set up. I have it on my car, and everything works great. Anything more than 4" narrowed makes you cut into the body. It will be a tight fit, but it will work, and you can maintain shock towers and shocks. _________________ 74 standard beetle
1776 built by KSR with dual 36 dellortos
4" narrowed beam |
Posted: Fri Dec 04, 2009 12:22 pm Post subject: |
Wow,
Now I'm more confused than ever. How can opinions differ so much on one question. I think I'll just fill up my toolbox with concrete nd put it in the trunk. Ha! Ha!
I think I may just get the 2-1/2" drop spindles and take my chances with that tire and wheel combo. By the looks of that picture, they will probably be alright. I don't plan on sharp cornering with a fat chick in the passenger seat and braking at the same time. At least I hope not!
Any other suggestions?
Thanks! Bill |
Derek Cobb Annoying
Posted: Fri Dec 04, 2009 3:23 pm Post subject: |
If it does rub, please let us know so we can definitively answer the question.
I feel pretty certain that it will (I did almost the exact same thing on a 70 vert) but I have been wrong before.
Simple solution will be skinny tires like 145's. |
Posted: Fri Dec 04, 2009 4:31 pm Post subject: |
OOPS,
I forgot to mention one very important fact. I'll be running '66 and earlier front fenders on my '74. I don't have the original '74 fenders to compare, but these fenders look to possibly be a little wider than the originals.
Any input on this theory?
Thanks again! |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Fri Dec 04, 2009 6:55 pm Post subject: |
| redlines4us wrote: |
| How can opinions differ so much on one question. |
Bill, that's an easy question to answer... the "opinions" you are getting are what folks are using and know does/doesn't work.... there is no one right or wrong way, and that is why opinions and setups vary...
the earlier style fenders are no wider, just a bit different shape around the headlight bucket. _________________
| [email protected] wrote: |
| With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
Posted: Fri Dec 04, 2009 6:56 pm Post subject: |
| Thanks! |
Fattie I'd roll it
Posted: Mon Dec 14, 2009 9:44 pm Post subject: |
update ? _________________ Donate and help me get another aircooled dub to share with you guys www.paypal.me/WhosCare |
