Erratic sudden power drops in 1987 2.1 Syncro Van
comdesigns
comdesigns is offline
PostPosted: Mon Aug 09, 2004 10:03 am    Post subject: Erratic sudden power drops in 1987 2.1 Syncro Van Reply with quote
Over the past two weekends, I have done two road trips with my 1987 Syncro. On both of them, I experienced a few sudden drops in power for a second or two. In 20 hours of driving it happened maybe 5 times.Twice it even seemed like the engine had just stopped running entirely but restarted without a problem (while still at speed on the interstate).
Most of the time I was at cruising speed and not under a particular load but it happened once during town driving accelerating to a gear change and once going up a long grade. At first I thought it was the A/C kicking in causing a power drop, but it is more dramatic than the typical AC drop and it happened without the A/C on this trip so I have eliminated that.
The way it just suddenly drops like someone turned the key off for a millisecond makes me suspect something electrical, but I plan on replacing the fuel filter just because.
Otherwise the van runs great. 17-19 MPG, steady idle. A bit week at low RPMs, but I haven't tuned it to high altitude (5000 ft) since buying it in Seattle.
Any thoughts as to what might be the root cause? Feel free to add recommendeations for high-altitude tuning.
mightyart
mightyart is offline
PostPosted: Tue Aug 10, 2004 7:29 am    Post subject: Reply with quote
Do you have the Fuel injection upgrade?
My Art:
http://www.instagram.com/flynn8552/
barrettw
barrettw is offline
PostPosted: Tue Aug 10, 2004 8:04 am    Post subject: Reply with quote
Read your post and came across this article today. Sounds similar to what your experiencing. http://www.geocities.com/harald_nancy/intermitt._syndrome.htm
comdesigns
PostPosted: Tue Aug 10, 2004 4:11 pm    Post subject: Reply with quote
Thanks for the replies. I did recently pull the air flow meter housing (and grounding wire) when I put in a K&N air filter and vacuumed debris out of the air intake quarter panel. Perhaps the ground isn't sufficiently seated.
As to the question of whether I have the fuel injector modification. I am enough of a newbie to not know. I know that the system is fuel injected and that within the past 20K miles the injectors were cleaned to pass emissions. I don't know if the system has been modified in any way.
There is a Bosch ECU under the back seat. I will check its ground as well to make sure it is solid.
