vanagon doesnt trip the fuel pump auto-shutoff in time
mmdingman
mmdingman is offline
PostPosted: Thu Jan 21, 2010 5:53 pm    Post subject: vanagon doesnt trip the fuel pump auto-shutoff in time Reply with quote
when I fill up my 85 Vanagon, the auto-shut-off of fuel pumps trip, but too late. A little fuel spills out afterward.
I'm not versed on fuel systems... is a breather hose at fault? I plan on doing the tank reseal/ new hose routine this spring, maybe that'll fix it.
Anyone had the same problem?
85 Wesfalia Wolfsburg (2009ish - present)
87 Syncro Hardtop (1997 -2010ish)
bbbjim
bbbjim is offline
PostPosted: Thu Jan 21, 2010 6:57 pm    Post subject: Reply with quote
I've done the fuel tank reseal and still have the spit back. I've always had it and just make sure I stand back . I admit I have set up a couple of friends by telling them to "stand right here". I have had luck with running the the pump myself and cutting it off when I hear the whoosh. Jim
1987 Westy aka Moon Shadow
1966 Delux aka Cloud Woman
camerahunter
camerahunter is offline
PostPosted: Thu Jan 21, 2010 7:11 pm    Post subject: Reply with quote
I always fill by gallons, not by dollar amount, and not until completely full.
I think the tank holds 15 gallons total? So by looking at the gauge I always try to leave room for one gallon of air or more.
To answer your question, yes, all mine do that if I let it go until the auto shut off.
David
1984 - Daily driver
presslab
presslab is offline
There is a newer fill tube on 88+ vans (I think) that has a ball in the end to keep this from happening. I installed one on my 86 and it never spits gas anymore.
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
mmdingman
PostPosted: Fri Jan 22, 2010 9:10 am    Post subject: Reply with quote
thanks thanks thanks!
Reckless Amateur
Reckless Amateur is offline
PostPosted: Fri Jan 22, 2010 6:06 pm    Post subject: Reply with quote
How funny. My mechanic and I have been trying to figure this out today. Sounds like the newer fuel fill pipe is the solution--but I've searched GW, Bus Depot and Van Cafe and can't find what I think you're referring to (Bentley says it's the filler pipe? or is if the filler neck? or what?). So Presslab, what is it exactly and where can I find one? Hope we can get to the bottom of this one. I'm tired of fuel burps!
91 Bostig-powered Westy (automatic)
Philadelphia, PA
kshbaja
kshbaja is offline
PostPosted: Fri Jan 22, 2010 7:17 pm    Post subject: Reply with quote
I second the comment about the fill tube with the float ball working very well. I replaced mine recently with one off a 91 from the junkyard and have no problem any longer.
1986 Westfalia
Reckless Amateur
PostPosted: Fri Jan 22, 2010 7:29 pm    Post subject: Reply with quote
Sounds like it's off to the junkyard to find one, then? It's what Bentley calls the filler pipe that goes right into the fuel tank, right?
Philadelphia, PA
mmdingman
PostPosted: Sat Jan 23, 2010 6:22 am    Post subject: Reply with quote
the parts catalog doesnt help... there are two gas filler pipe part numbers listed fro 86-91 and three for 85 & earlier. One of the two pipes under 86-91 says 'unleaded fuel only restriction', so if I had to guess, I'd say that would be it. Doesnt explain the model year breakpoint we're observing here though. anyway, that filler pipe is 251 201 129a
tencentlife
tencentlife is offline
PostPosted: Sat Jan 23, 2010 8:03 am    Post subject: Reply with quote
The nozzle shutoff port is on the lower end of the tip. So, as it nears full, you have to lift the nozzle handle upward. This tilts the tip downward where it will be immersed in the liquid as the level comes up the filler. This technique works to make them shut off, but you can't walk away, you have to be there to hold up the nozzle at the end.
This has been discussed plenty around here, the old hands all know it already, I'm surprised no one has "filled" you all in!
Experience is death to doctrine.
Reckless Amateur
PostPosted: Sat Jan 23, 2010 3:26 pm    Post subject: Reply with quote
Thanks, TenCent. So I don't need to replace the fill tube, just practice my technique, huh? Certainly a lot cheaper.
Philadelphia, PA
tencentlife
PostPosted: Sat Jan 23, 2010 3:42 pm    Post subject: Reply with quote
Yup, technique is free. Works for me!
joetiger Premium Member
joetiger is offline
PostPosted: Sun May 02, 2010 6:19 pm    Post subject: Reply with quote
I just did the fuel tank reseal; not too difficult but messy for sure. I only splashed gasoline in my face once. I'd done all my reading (thanks Kayakwesty!!) and was surprised by how puny-looking the tank is once you get it on the ground.
I was hoping that the reseal would keep gas from coming out on fillup, but I still got the splash. (After reading this thread I see why.) I was able to fill up to just under 15 gallons. Is that normal? I know the tank is allegedly 16 gallons, so I'm wondering why it would take a full fill-up.
Any luck on finding the fuel filler neck in somebody's NOS? Late model u-pull-it Vanagons are getting very rare in these parts...
Thanks!
Joe T.
'02 Baja-ish Beetle "Bubbles"
Reckless Amateur
PostPosted: Mon May 03, 2010 3:22 am    Post subject: Reply with quote
Hey, I just installed the later model filler neck and (at least after a couple fillups) it seems to have done the trick. No more burp. (The "technique" wasn't doing the trick.) I found it in the classifieds--just post a WTB and see what happens. Cheers.
Philadelphia, PA
jmranger
jmranger is offline
PostPosted: Mon May 03, 2010 8:27 am    Post subject: Reply with quote
Any part number you can share, and/or visual cues to recognize the right part ? Pictures would be great.
Thanks,
Reckless Amateur
PostPosted: Mon May 03, 2010 8:55 am    Post subject: Reply with quote
Comparing the one from the 87 I had and the one I got from a 1990, I think, the newer one had a ping pong ball float at the end which I don't thing the 87 did. If that helps. Very Happy
Philadelphia, PA
jmranger
jmranger is offline
PostPosted: Tue May 04, 2010 8:47 am    Post subject: Reply with quote
Almost a mug shot Smile
BusDepot and Frank Condelli have the 251 201 129a part named earlier in the thread. But be sure to be seated before looking at the price...
Perales
Perales is offline
PostPosted: Tue May 04, 2010 8:58 am    Post subject: Reply with quote
A picture is worth a few more words.
This technique also lets the displaced air out of the tank so it doesn't burp up.
-- 1987 Westfalia automatic (Captain Vino)
joetiger is offline
PostPosted: Tue May 04, 2010 9:13 am    Post subject: Reply with quote
I've tried the nozzle technique but I've never been able to get it to work. Generally what I've always done is slow the gas flow down to a trickle as I'm estimating that the tank is almost full. That's the only way I've found to not have it splash out.
I found a used fill tube from a '90. I'll report back after I've installed and filled up.
Joe T.
jmranger
jmranger is offline
PostPosted: Tue May 04, 2010 4:42 pm    Post subject: Reply with quote
Merci Perales.
Haven't tried the technique yet - van smells gas when full, so a reseal is in order, and full fill-ups are to be avoided in the meantime. But if I find the right part at the right price, I'll change it at the same time.
