vw donvieira Samba Member
Joined: May 11, 2004 Posts: 640 Location: stockton, California
Posted: Sat Jan 23, 2010 9:34 am Post subject: Cargo door hinge screw plates missing |
| On the body where you mount the cargo doors it has a plate that the screw attaches to. It appears boxed in somehow so you have some plate movement for door adjustment. When I got the body work done I noticed that plates on one side were missing and we even cut small "windows" in an attempt to find the plat. No luck so we made plates but are there any recommendations on how I should go about installing them. Where to cut into the body, etc. Thanks, vwdon |
floor13 Samba Member
Joined: January 12, 2006 Posts: 130 Location: Strait Air VW Club
Posted: Sun Jan 24, 2010 11:03 am Post subject: |
I went through the same thing.. I cut a hole on the inside and held the backing plate in place while my buddy put the door on. It sucked. Ill see if I have any pictures to give you a better idea. _________________ 70 Deluxe Sunroof Bus
64 Caravelle Bus
68 Vert Bug Rat
64 Type 3 Variant
65 Drag Bug
62 Ghia
72 Super Beetle |
58deluxerag Samba Member
Posted: Sun Jan 24, 2010 1:22 pm Post subject: |
Here is where I cut my 15 window to get in for the nut plate. Was missing both lowers
_________________ -Corey
'58 Binz
'58 Beetle Ragtop
'65 Sundial |
Posted: Sun Jan 24, 2010 3:14 pm Post subject: |
| Thank you so much. Don |
Joined: April 27, 2002 Posts: 6876 Location: Pentwater, Michigan
Posted: Sun Jan 24, 2010 4:08 pm Post subject: |
Find a way to support the plate otherwise the next time the door is taken off you'll have to go through the whole process over again. Don't ask me how I know... n _________________ Roads Scholar
Member# 2059 |
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
Posted: Sun Jan 24, 2010 9:47 pm Post subject: |
| I would like to get a visual of that setup. Thank you, vwdon |
DownRiver Samba Member
Joined: January 05, 2003 Posts: 797 Location: threeonethree
Posted: Mon Jan 25, 2010 6:16 am Post subject: |
Here's the plate on a new Gerson Lower B.
_________________ Whether you think you can or think you can't, you're right. -Henry Ford
VanSlyke VW Doublecab |
Vintagespeed Samba Member
Joined: October 01, 2005 Posts: 579 Location: Westerlo (Belgium)
Posted: Mon Jan 25, 2010 5:18 pm Post subject: |
if you can't get the metal plate fixed, there's a simple solution someone posted before.
Get an extra nut, cut of the head and cut/grind in a little I-shape so you can bolt the headless bolt right in there.
So now the plate stays in place, while you bolt in the other normal bolt and aftwerwards you replace the headless bolt.
This prevents the plate from ever falling down, but sure enough it's just a help |
EasyNow Samba Member
Posted: Sat Apr 30, 2022 4:50 pm Post subject: Re: Cargo door hinge screw plates missing |
Does anyone have a recommendation for a good source to purchase a nut-plate for the cargo doors? I don’t need the pillar portion, just the nut-plate. Thx...
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9831 Location: Exit 7, New Jersey
Posted: Sat Apr 30, 2022 9:25 pm Post subject: Re: Cargo door hinge screw plates missing |
Should be pretty easy to fabricate if you have some 3/16" steel lying around. Measure, cut, drill and tap. _________________ Founder and Chairman Emeritus, ECMSAS
| BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
| Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
Posted: Sun May 01, 2022 6:09 am Post subject: Re: Cargo door hinge screw plates missing |
| Kinda was thinking that, but if there is a source I could acquire one... well, that would be even better. Thanks for the thought here j-pickens. |
