50 degree I-4 install hydraulic engine mounts
BlackDogVan
BlackDogVan is offline
PostPosted: Wed Jan 27, 2010 10:50 am    Post subject: 50 degree I-4 install hydraulic engine mounts Reply with quote
Searched...
Anyone have experience retrofitting hydraulic engine mounts to the stock diesel carrier bars & engine mounts? I have some text info on using Saab 9000t hydro units but no images or details on their install.
thanks!
crazyvwvanman
crazyvwvanman is offline
PostPosted: Wed Jan 27, 2010 11:35 am    Post subject: Re: 50 degree I-4 install hydraulic engine mounts Reply with quote
This is probably what you were looking for. This shows them on 82 carrier bars. The mounting method and location would be a little different on 83+ bars.
http://www.members.shaw.ca/ragnarhairybreeks/me/memain.html
Mark
BlackDogVan wrote:
Searched...
thanks!
MarkWard
MarkWard is offline
PostPosted: Wed Jan 27, 2010 1:08 pm    Post subject: Reply with quote
Mark, do you know what year Saab mounts he used and were they from a 900 or 9000? Thanks for posting the link to the pictures.
crazyvwvanman
PostPosted: Wed Jan 27, 2010 1:34 pm    Post subject: Reply with quote
I don't know. He says they are for a "SAAB 2.0L 4 cylinder turbocharged engine".
If you are on the Vanagon and/or TDIconversion lists he is still around sometimes.
Mark
BlackDogVan
PostPosted: Wed Jan 27, 2010 1:37 pm    Post subject: Reply with quote
I like the ones used in the overland kits, they look easy to fab brackets, anyone know if they are a OEM unit?
http://www.vanagain.com/images/AdvancedKit.jpg
The Saab units can be very spendy & with the state of Saab I can't imagine they will get cheaper. Adapting some Jetta Mk3 tdi mounts would be the same amount of work.
Something good & cheap from the big three woud be good to find.
Captain Pike
Captain Pike is offline
PostPosted: Wed Jan 27, 2010 1:46 pm    Post subject: Reply with quote
Quantum works too.
LEARN TO SELF RESCUE
....Bad Sneakers....
crazyvwvanman
PostPosted: Wed Jan 27, 2010 1:47 pm    Post subject: Reply with quote
Those are a standard Audi 5 cyl mount. I don't know the cost comparison but if the SAAB are too high I would go with the Audi ones. I have seen other people put them on their inline 4 engines. The 82 diesel Vanagon rubber mounts are no longer available new so various people have been motivated to engineer a replacement. It makes sense to use a readily available part like the Audi ones. (VW Quantums from around 85-88 came with 5 cyl Audi engine that used the same mounts)
Mark
MarkWard
MarkWard is offline
PostPosted: Wed Jan 27, 2010 1:58 pm    Post subject: Reply with quote
Mark thank you. I am on the TDI conversion list, but when I was upgrading my mounts, I got no replies about any hydraulic mounts. My conversion is a little unique to the other TDI's that have been done. There was an email link on the page you posted so I sent an email. It has not bounced back yet. I am considering adding a 3rd mount in the timing cover area using the New Beetle r/s engine mount. I already have one, but need to fabricate and new bracket to connect to the engine. I think at 50 degrees, the ALH is too much weight on the L/S mount. Adding a 3rd mount I could support more weight on it and use the side mounts more to control twist than supporting the whole shooting match. Saab is going out of business, so maybe Saab mounts might not be the way to go. Thank you for posting.
ragnarhairybreeks
ragnarhairybreeks is offline
PostPosted: Wed Jan 27, 2010 2:00 pm    Post subject: Reply with quote
I got your email and sent what I have from the original maker (Frank G). Its the same whack o'emails I sent to blackdog.
cheers
alistair
'86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com
MarkWard
MarkWard is offline
PostPosted: Wed Jan 27, 2010 2:02 pm    Post subject: Reply with quote
I have seen the Audi ones used like in Eurospec's kit, but those mounts were not intended to be supported by their ears alone. The ears were more to attach them to the subframe that had a better attaching structure than just the ears. The Saab pictures were a nice fit to the stock carrier bars. Something you could do with minimal fabricating skills.
raygreenwood
raygreenwood is offline
PostPosted: Wed Jan 27, 2010 2:04 pm    Post subject: Reply with quote
Those are Saab 900 mounts. They fit a wide range of other cars. that type of mount is used by a lot of people. Just go junk yarding and look. look at Nissans as well.
Saab does not produce all fo their parts...and theer are enough Saabs left that aftermarket companies produce parts for that you can pretty much count on them being easy to get for a decade. Ray
BlackDogVan
PostPosted: Wed Jan 27, 2010 2:21 pm    Post subject: Reply with quote
Hmmm... the Quantum/Audi units do look pretty handy & 1/3 the price of the Saab option. So these should be supported on the bottom & not just by the ears? I'd order from the 1988 Audi 5000 turbo page so they match my brake calipers. Wink Any old school Audi owners have memories of these being junk?
http://parts.autopartsonlinecanada.com/parts/apoca...category=A
MarkWard
MarkWard is offline
PostPosted: Wed Jan 27, 2010 2:30 pm    Post subject: Reply with quote
I remember them being kind of large compared to the above pictures with the modified 82 carrier bars and Saab mounts. I don't recall ever replacing any that had blown out failed, but some that had drooped.
BlackDogVan
PostPosted: Wed Jan 27, 2010 2:34 pm    Post subject: Reply with quote
Well for the price I ordered one to play with & mock up some brackets. More news at 11...
MarkWard
MarkWard is offline
PostPosted: Wed Jan 27, 2010 2:37 pm    Post subject: Reply with quote
blackdogvan. I'd like to see what you come up with. If you search my name, I have uploaded photos here of my conversion. mark
danfromsyr
danfromsyr is offline
PostPosted: Wed Jan 27, 2010 2:41 pm    Post subject: Reply with quote
they work fine on my 5000 & our I5 swap install
they are supported from underneath on the ears, they are not aupported from underneath by the center/body portion.
even on the heavier Audi V8s.
they can/will tear apart if you just pull the motor up w/o losening them.. found out the hard way, and when I part a tough 5cyl turbo I use the engine hoist to seperate the tough one buried & rusted under the turbo. DS is always easy to get to, PS is a pita.
Dan in NY
Abscate wrote:
crazyvwvanman
PostPosted: Wed Jan 27, 2010 2:45 pm    Post subject: Reply with quote
They are used with just the ears supported. The reason they are readily available is they need periodic replacement. I have replaced one a couple times in 11 years in my 5 cyl Syncro Vanagon. In my conversion the driver side rubber mount is closer to the exhaust header than ideal so the high temp seems to shorten its life. The other side is fine but I replace in pairs.
Mark
MarkWard
MarkWard is offline
PostPosted: Wed Jan 27, 2010 2:47 pm    Post subject: Reply with quote
Mark are you using the stock carrier bars with the Audi mounts?
crazyvwvanman
PostPosted: Wed Jan 27, 2010 3:44 pm    Post subject: Reply with quote
No, I am only using them on my 5 cyl conversion. I do have a set of diesel bars with the Audi mounts installed but I have not installed them yet. I got them as part of a larger deal when I purchased an inline 4 conversion setup from a crashed Westy.
Mark
BlackDogVan
PostPosted: Wed Jan 27, 2010 3:58 pm    Post subject: Reply with quote
Mark
Can you post a picture or two that?
Page 1 of 8
