ARTIFACT Samba Member
Joined: June 19, 2009 Posts: 816 Location: SANTA CRUZ
Posted: Thu Feb 04, 2010 3:53 pm Post subject: how to determine if I have chromoly pushrods? |
(newbie alert)
I know it's been asked before, and I searched. The answers worked for previous posters, but I think I need more explanation here ... How do I check this?
Franklin installed the engine in my 57 a few years ago, but doesn't know (without driving it there - but read on).
I got the car recently. I am doing the valves for the first time on my own, and followed the .006 instructions... I have *not* started the engine, because I read about these chromoly pushrods, and I am unsure. I know, I should have checked *before*
Are there photos I can use to compare and identify what I have?
Thanks guys
1835, dual 44 Webers
_________________ L331 Horizon Blue January 1957 Canadian Deluxe Oval Beetle
drscope wrote: |
The older car has 10 to 20 years more experiance in figuring out how to piss you off! the newer cars are still learning. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79563 Location: Sneaking up behind you
Posted: Thu Feb 04, 2010 3:55 pm Post subject: |
Use a magnet... it will not stick to aluminum pushrods. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
exciter Samba Member
Posted: Thu Feb 04, 2010 4:40 pm Post subject: |
And usuall y but not 100% sure the chromoly ones are normally a black color! |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11047 Location: Black Forest, CO
Posted: Thu Feb 04, 2010 5:54 pm Post subject: |
so if it sticks to the pushrods, they are chromoly?
Making sure
Thanks guys _________________ L331 Horizon Blue January 1957 Canadian Deluxe Oval Beetle
drscope wrote: |
Glenn  Mr. 010
earthquake Samba Member
Joined: January 10, 2008 Posts: 4001 Location: SANDY VALLEY, NEVADA
Posted: Thu Feb 04, 2010 6:24 pm Post subject: |
Only the tube is made from aluminum, the ends are steel on both.
Earthquake _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
BugMan114 Samba Member
Joined: March 22, 2007 Posts: 3744 Location: Ellenwood, GA
Posted: Thu Feb 04, 2010 9:31 pm Post subject: |
so then how do you tell the difference between steel and chromoly? _________________ 1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!! |
Posted: Thu Feb 04, 2010 9:49 pm Post subject: |
Ok
magnet sticks to pushrod body
... So now I need to understand what 0.000" is supposed to feel like ... Hunting for the feeling gauge... Thinnest I have is 0.002...
Do I get it adjusted to "tight .002"?
I am sure all of this is obvious to all but me learning a lot each day I spend with my beloved bug
thx _________________ L331 Horizon Blue January 1957 Canadian Deluxe Oval Beetle
drscope wrote: |
germansupplyscott Samba Member
Posted: Thu Feb 04, 2010 10:10 pm Post subject: |
if the pushrod will rotate but you cannot feel any lash it is adjusted to "loose zero" clearance, which is what you want. _________________ SL |
youngnstudly Samba Member
Joined: October 21, 2005 Posts: 836 Location: Whine Country (SF Bay area)
Posted: Thu Feb 04, 2010 10:20 pm Post subject: |
I use the method that a lot of guys on here use for getting "zero lash" and that is to adjust the rocker adjuster (screw) in until it doesn't have lash, then slowly back it out while using your fingers to spin the pushrod. When you can spin the pushrod easy with your fingers but there is no lash present, that is considered to be zero.
Andy _________________ Vintage Volkswagens: When you're not swearing by them, you're swearing at them |
Toby from MO Samba Member
Joined: August 26, 2009 Posts: 202 Location: Imperial, MO
Posted: Thu Feb 04, 2010 11:12 pm Post subject: |
...with chromoly push rods...is the "loose zero" adjustment on both intake and exhaust valve? Local shop owner had mentioned he was running .002" on intake and .004" on exhaust...but not sure what material push rods he was talking about.
Thanks. |
Posted: Thu Feb 04, 2010 11:41 pm Post subject: |
Yes, I run zero lash on all the valves. _________________ Vintage Volkswagens: When you're not swearing by them, you're swearing at them |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17589 Location: Left coast, Canada
Posted: Fri Feb 05, 2010 1:51 pm Post subject: |
BugMan114 wrote: |
so then how do you tell the difference between steel and chromoly? |
Chromoly is steel. _________________
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Fri Feb 05, 2010 3:26 pm Post subject: |
Bruce wrote: |
BugMan114 wrote: |
Chromoly is steel. |
Chromoly is steel but not all steel pushrods are chromoly. _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
