slantman Samba Member
Joined: February 27, 2008 Posts: 10 Location: Perth, Australia
Posted: Wed Feb 10, 2010 1:20 am Post subject: Type 1 engine tin? |
I'm in the process of replacing the worn out 1200 in my 65 Type 1 with a healthy 1914 turnkey engine from DRD. I have a question regarding the need for the tin that goes behind the engine, above the bellhousing. I have a pic of it below:
Do I need to keep this piece? The car is mainly street driven, with the odd run down the strip. I thought about leaving this piece out to help feed some more air to the dual 44IDF's, as well as help with cooling. My car has the standard sedan engine lid and doesn't have raised hinges, though I may look into that for summer driving. Thanks. |
tcgmark Samba Member
Joined: August 07, 2008 Posts: 55 Location: Fullerton, CA
Posted: Wed Feb 10, 2010 1:34 am Post subject: |
| Many will say, and I agree, that every tin on the motor has its importance. Inside an engine compartment is where all the tins hold some type of importance, mostly to keep heated air from the hot exhaust piping from recirculating back into the cooling system. I would suggest reusing it. |
Koyote Samba Member
Joined: March 31, 2008 Posts: 193 Location: Dijon, home of the mustard.France
Posted: Wed Feb 10, 2010 1:45 am Post subject: |
| you will have more fresh air in the engine compartiment if you remove it. but also more dust ! |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80680 Location: Sneaking up behind you
Posted: Wed Feb 10, 2010 5:51 am Post subject: |
You'll have more heat since the #1 and #3 exhaust pipes are just under that tin.
BTW... You'll need one that made for a dog house shroud... that one will not work. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Koyote Samba Member
Posted: Wed Feb 10, 2010 6:37 am Post subject: |
| you will have more fresh air that come under the car than heat from the 1 and 3 exhaust. But again, you will suck more dust too. |
Glenn  Mr. 010
Posted: Wed Feb 10, 2010 6:48 am Post subject: |
| Koyote wrote: |
| you will have more fresh air that come under the car |
Then how come I have no "hot running" problem in my car... because I do have that tin in place? _________________ Glenn
Member #1009
#BlueSquare
Koyote Samba Member
Posted: Wed Feb 10, 2010 7:41 am Post subject: |
| Glenn wrote: |
| Then how come I have no "hot running" problem in my car... because I do have that tin in place? |
no "hot running" problem is fine but "run cooler" is better in my opinion !
VW engineers were always concerned to let enter more fresh air in the engine compartiment when they "boosted" the power of the engine. So may be it's a good idea to follow this way of thinking, especially with more power. That's my opinion.
At least it will not hurt anything if you remove it. |
Glenn  Mr. 010
Posted: Wed Feb 10, 2010 7:45 am Post subject: |
There is such a thing as too cool. The engine needs to be at "operating temp" to be most efficient. That's why there's a thermostat.
Don't anticipate a problem before you have one. And if your engine is running hot... find the cause, don't remove tin.
If i can get a large displacement engine in a fully enclose engine bay to run "correctly" then so can you. _________________ Glenn
Member #1009
#BlueSquare
Posted: Wed Feb 10, 2010 4:17 pm Post subject: |
Thanks for the replies.
Okay, so I'll have to replace it anyway. What is the correct name for this piece, so I don't sound like a total noob when I go shopping for one to suit the doghouse cooler? |
Glenn  Mr. 010
AlteWagen Troll
Koyote Samba Member
Posted: Thu Feb 11, 2010 6:01 am Post subject: |
As Luftwagen shown us previously, this summer I have installed an air duct like this http://www.stockcarproducts.com/brkduct.htm
That's work very well ! just need a screen.
I need also more fresh air because my engine is turbocharged ( draw through) so with the turbo inside the engine compartiment there is more heat. But you don't need this tin, especially with your engine. Or you you can install this air duct. |
Glenn  Mr. 010
Posted: Thu Feb 11, 2010 7:23 am Post subject: |
| derluftwagen wrote: |
| Glenn wrote: |
| If i can get a large displacement engine in a fully enclose engine bay to run "correctly" then so can you. |
Glenn he OP has a 65 with no decklid vents, you have a late model with a ton of vents. I would swiss cheese the tin or run a duct like these guys |
A good friend has a 2110 in a 67 Beetle with not problems.
I say give it a try, don't assume there's a problem before you have one. _________________ Glenn
Member #1009
#BlueSquare
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Thu Feb 11, 2010 7:54 am Post subject: |
It's not doghouse, so he doesn't have to worry about recirculating hot air from the oil cooler.
As long as the "sled tin" is still in place, that piece of tin can be omitted with no ill effects at all, other than a cooler running engine.
If you want my opinion, leave it out. I left it out on all my VW's, daily driven, and taken on 40 mile dirt roads on camp trips. Long highway drives, and stop'n'go traffic in 115 degree heat in Vegas.
The key being, if the sled tin is in place and its a non-doghouse, it's perfectly safe to leave it out. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
