Almost Alive Samba Member
Posted: Fri Feb 26, 2010 3:16 pm Post subject: "Sled" Tin vs. HD Pushrod Tube Protectors |
I've been reading a lot about these "sled" tins lately and to be honest I've never had or taken apart an engine with them on it.
My most current build I used these HD pushrod tube protectors which needed to be slightly modified to fit but they are nice
http://www.appletreeauto.com/push-rod-tube-protectors-chro-pr-868.html
My question is how important are these commonly missing tins for cooling purposes and are these PR tube covers a bad idea to put in place of them?
I'm trying to diagnose an overheating problem which I would assume is from a cruddy aftermarket fan shroud but I'm looking at everything it could potentially be. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80546 Location: Sneaking up behind you
Posted: Fri Feb 26, 2010 3:30 pm Post subject: |
The pushrod tube protectors are generally used for offroad and open engine compartment vehicles. For a stock vehicle, it's go with the factory tin.
Yes, they are important. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
ALB Samba Member
Joined: August 05, 2008 Posts: 3506 Location: beautiful suburban Wet Coast of Canada
Posted: Fri Feb 26, 2010 3:40 pm Post subject: |
All I see is a waste of $35. The sled tins are there for the long term health of the motor. As Jimmy 111 put it, "As your speed increases the sled tins keep the air pressure under the car from overcoming the fan (as much as 2psi under the car). They need either heater boxes or block off tins to be functional." A car that seems to run fine around town but overheats on the highway (when the under-car air pressure is higher and the fan doesn't generate enough pressure to push the spent cooling air into the airstream) should be checked to see all the factory cooling tin is in place. They will protect the pushrod tubes from small road debris. If the bottom of the motor needs more protection (an offroad car?) then a skid plate is in order. Think of it this way; if the motor didn't need them the factory engineers wouldn't have put them there. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Fri Feb 26, 2010 3:42 pm Post subject: |
| Glenn wrote: |
Yes, they are important. |
It is for a beetle though its anything but stock.
It is a very low car which is why I chose them. My girlfriend hit a rock in the road kicked up by a plow truck in it before and it ended up causing some big PR tube problems. |
Posted: Fri Feb 26, 2010 3:45 pm Post subject: |
| ALB wrote: |
| All I see is a waste of $35. The sled tins are there for the long term health of the motor. As Jimmy 111 put it, "As your speed increases the sled tins keep the air pressure under the car from overcoming the fan (as much as 2psi under the car). They need either heater boxes or block off tins to be functional." A car that seems to run fine around town but overheats on the highway (when the under-car air pressure is higher and the fan doesn't generate enough pressure to push the spent cooling air into the airstream) should be checked to see all the factory cooling tin is in place. They will protect the pushrod tubes from small road debris. If the bottom of the motor needs more protection (an offroad car?) then a skid plate is in order. Think of it this way; if the motor didn't need them the factory engineers wouldn't have put them there. |
That is something I've never heard before and it could very well be contributing to the cooling problem as it happens mostly on the highway at about 60mph+
I really appreciate you posting this, I will acquire the proper stock tins and get them in place.
Now what about these block off tins? I'm not running heater boxes. |
Glenn  Mr. 010
Posted: Fri Feb 26, 2010 3:47 pm Post subject: |
Well, stock sleds are no lower than the case and if you have a deep sump, that will be the lowest point on your engine.
And modified engines need them even more that stock.
BTW, if you're running J tubes you need the industrial tins to close off the tin. _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri Feb 26, 2010 3:58 pm Post subject: |
| Thanks Glenn. I've never even seen those block off tins offered. Must not be looking hard enough. |
AlteWagen Troll
Posted: Fri Feb 26, 2010 4:02 pm Post subject: |
If you really need protection just use type 181 skid plate and sled tins and block off plates.
Glenn  Mr. 010
henrym Samba Member
Joined: August 19, 2006 Posts: 1011 Location: The Valley
Posted: Fri Feb 26, 2010 6:16 pm Post subject: |
Always try to use as much stock tin as you can. The sled tins are great but unfortunately, they do not fit with many (actually most) aftermarket exhausts. _________________ 1970 Ghia, Pat Downs-equipped 2276 |
Glenn  Mr. 010
Posted: Fri Feb 26, 2010 6:18 pm Post subject: |
| henrym wrote: |
| unfortunately, they do not fit with many (actually most) aftermarket exhausts. |
Then don't buy one that doesn't fit. If people stop buying crap, they'll change the design. _________________ Glenn
Member #1009
#BlueSquare
bugninva Samba Member
Joined: December 14, 2004 Posts: 8857 Location: sound it out.
Posted: Fri Feb 26, 2010 7:22 pm Post subject: |
| Almost Alive wrote: |
what is overheating? the oil or the heads? timing could be an issue... _________________
| [email protected] wrote: |
| With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3453 Location: Calgary, Canada
Posted: Fri Feb 26, 2010 8:44 pm Post subject: exhaust |
| Glenn wrote: |
| henrym wrote: |
Then don't buy one that doesn't fit. If people stop buying crap, they'll change the design. |
The Berg pipe is directly under the cylinder head...radiating heat into the head: not good IMO, in some applications.
Other aftermarket headers place the J-pipe into the sled area where air is flowing over the J-pipe...simply trim the sled tin as needed and you're good to go  _________________ Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Glenn  Mr. 010
Posted: Fri Feb 26, 2010 8:53 pm Post subject: Re: exhaust |
| neil68 wrote: |
| The Berg pipe is directly under the cylinder head...radiating heat into the head: not good IMO, in some applications. |
Actually the industrial shields are between the header and the had which keep the heat from reaching the head and keep the air that's flowing over the head to exit out the rear.
This is the exact same setup that was used in the Type 126 industrial engine and the 1973 VW Thing engine. _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri Feb 26, 2010 9:03 pm Post subject: Re: exhaust |
| neil68 wrote: |
Other aftermarket headers place the J-pipe into the sled area where air is flowing over the J-pipe...simply trim the sled tin as needed and you're good to go  |
having the pipe more up under the engine interferes with the ability to use the thermostat. that is more of a negative than the possibility of radiant heat from a j-tube. with the industrial shields like Glenn runs, the original plenum formed at the bottom of the engine is retained, and I'd bet radiant heat is not an issue... _________________
damicotile Samba Member
Joined: September 16, 2004 Posts: 1070 Location: WOODLAND CA.
Posted: Fri Feb 26, 2010 9:53 pm Post subject: |
So where can I get those tins Glenn? From the dealer?
I called Gene Berg and wouldn't you know it, they're closed on Fridays.
Whats a Type 126 anyway _________________ '73 SB
82x94
W-120 w/ CB light weight lifters
Silicon bronze sleeves
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
A-1 Sidewinder coated
__________________________________ |
ALB Samba Member
Posted: Sat Feb 27, 2010 12:04 am Post subject: |
| bugninva wrote: |
what is overheating? the oil or the heads? timing could be an issue... |
I wholeheartedly agree, there are other factors to consider; but if you have the above situation and are missing the sled tins it's the first thing to fix. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Glenn  Mr. 010
Posted: Sat Feb 27, 2010 6:24 am Post subject: |
| damicotile wrote: |
Whats a Type 126 anyway |
I doubt any dealer would have them.
Call Berg on Monday.
A Type 126 is an Industrial engine. Usually used to power air compressors, water pumps and other not automotive machines. Hence they need no heat. _________________ Glenn
Member #1009
#BlueSquare
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6449 Location: 37.5N 77.1W
Posted: Sat Feb 27, 2010 7:33 am Post subject: |
| Quote: |
| I doubt any dealer would have them |
I remember seeing a template for making them on this site. I saved it but can't find it now.  _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Glenn  Mr. 010
