can someone please link me some aftermarket tachs for 84 van
Blix
Blix is offline
PostPosted: Tue Mar 02, 2010 12:15 pm    Post subject: can someone please link me some aftermarket tachs for 84 van Reply with quote
Hey all, I have an 84 westfalia with the clock in the dash, no tach. Can someone please link me to an aftermarket tach that I can purchase online that will work with the van please? Thanks I'm hoping to get this installed asap, just got new tires and am gearing it up for the spring woot, thanks
When I say whas up, you know where I'm from.
84 Westy
MarkWard
MarkWard is offline
PostPosted: Tue Mar 02, 2010 12:48 pm    Post subject: Reply with quote
Do you want to add a tach in addition to the stock cluster or replace the clock with a tach? Do a search here in the classifieds for tachometer and do another search for cluster. I would also look on ebay. I think it would be easier to buy a used cluster rather than modifying your cluster to work with a clock.
Franklinstower
Franklinstower is offline
PostPosted: Tue Mar 02, 2010 12:59 pm    Post subject: Reply with quote
i agree, just buy a used cluster with the tach in it. Prefereble from '84 wolfsburg or 85.
A very doable procedure to gain a tach in the clock position. See write up on OldVolks Home page.
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB
msinabottle
msinabottle is offline
PostPosted: Tue Mar 02, 2010 2:24 pm    Post subject: Reply with quote
i agree, just buy a used cluster with the tach in it and it is a 5 minute replacement.
Shocked
Er, speaking from personal experience, it's not quite THAT fast a replacement, but it is possible and tremendously worth doing. Have a look here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=152334
Very-do-able, but don't go in uninformed. Read that, and you won't be.
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
MarkWard
MarkWard is offline
PostPosted: Tue Mar 02, 2010 2:26 pm    Post subject: Reply with quote
Or here http://www.oldvolkshome.com/late_van_cluster_install.pdf
FNGRUVN
FNGRUVN is offline
PostPosted: Tue Mar 02, 2010 5:51 pm    Post subject: Reply with quote
Here's what I did for my aircooled.
Sunpro brand from JC Whitney. $40 and works good
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
r39o
Samba Polizei
r39o is offline
PostPosted: Tue Mar 02, 2010 6:05 pm    Post subject: Reply with quote
The external one is OK. For me they vibrate and look out of place.
I vote for the factory setup. It is nice imho.
FNGRUVN
FNGRUVN is offline
PostPosted: Tue Mar 02, 2010 6:56 pm    Post subject: Reply with quote
He asked for an aftermarket tach idea if I read correctly. I don't know, maybe I need to work on my reading comprehension.
VisPacem
VisPacem is offline
PostPosted: Wed Mar 03, 2010 5:12 am    Post subject: Re: can someone please link me some aftermarket tachs for 84 Reply with quote
I had an 81 air-cooled, I used a tach from a Rover 2000 and tried one from an MG Midget, from the Pig A Part. they both worked. I just like the way the Rover looked better. At the time I think I paid 5 bucks.
LG aka VisPacemPB, *The* party Pooper
No Regrets (Nothing to do with Vanagons)
MarkWard
MarkWard is offline
PostPosted: Wed Mar 03, 2010 7:35 am    Post subject: Reply with quote
Aftermarket I prefer Autometer gauges. I also like a full sweep. http://www.summitracing.com/parts/ATM-3991
Jonesy02719
Jonesy02719 is offline
PostPosted: Wed Mar 03, 2010 7:57 am    Post subject: Reply with quote
My 91 Jetta Diesel also did not come with a tach. I installed a custom triple gauge cluster in my console, using a VDO cockpit tach (as well as voltmeter & oil pressure gauges). My alternator had a spade connector (the W signal IIRC), so I ran a wire from there to the tach. You have to use the dip switches and other methods to fine tune it to get it accurate though.
I like the look of the VDO gauges, since they came as original equipment in a lot of early watercooled VWs.
danfromsyr
danfromsyr is offline
PostPosted: Wed Mar 03, 2010 7:58 am    Post subject: Reply with quote
WTHs a "spring Woot" Question
and fwiw any tach with a 4cyl input will work on your vanagon.
now mounting them is a different thing altogether. and most people feel they end up looking 'tacked on' Surprised
many like www.dakotadigital.com and www.Egauges.com (which may be having web issues)
Abscate wrote:
windnsea
windnsea is offline
PostPosted: Wed Mar 03, 2010 8:27 am    Post subject: Reply with quote
Get a later model instrument cluster and rework the connectors in the connector pin to match the later cluster. That way you'll still have the clock, but you'll also have a factory tach!
Gary
shenan-agon
shenan-agon is offline
PostPosted: Wed Mar 03, 2010 12:51 pm    Post subject: Reply with quote
A while back I picked up a tach from a junked van, but upon getting home I realized that it didn't match up at all with the circuit foil on the backside of my cluster. Do I need to get an entire cluster (foil and all) to swap in? Or is there a way to make this work? Does anyone have a diagram for what the connections are on the back of the tach/fuel/temp assembly?
My '86 Wolfsburg is sort of a weird bird, since it seems most of the '86+ vans already have a tach - but they chose to put a clock in this one instead.
dokarex
dokarex is offline
PostPosted: Sat Mar 06, 2010 4:41 pm    Post subject: Reply with quote
ebay and the samba all have clusters listed if you need a diesel on check ebay.de
it is a five minute swap
Got my diesel dash cluster from Germany with tach (160CDN on ebay.de) couldn't wait to get home and install it, went to Tim Hortons and while in the drivethrough I thought well I'll start taking the dash apart, well by the time I got my coffee the new dash was installed (didn't get the cover back on) but it was plugged in and working The cluster is a little rough with some PO soldering but it works and now I have a tach, tripmeter, clock(works ),and a 100000's odo instead of 10000's
If I wasn't to big too do cartwheels that's what I would be doing.(I was going crazy trying to figure out what to use for a tach).
1987 Doka 1.9TD from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2006 Jetta Wagen 1.9TDI
B6200 Kubota Diesel
16ft Freestyle catamaran
16 ft Sunray 85 Horse (sunk)
alnvilma
alnvilma is offline
PostPosted: Sat Mar 06, 2010 7:51 pm    Post subject: Reply with quote
I always put one of these in my bus(s). small enough to stick anywhere and works great.
http://www.google.com/products/catalog?client=gmai...ps-sellers
EL31415
EL31415 is offline
PostPosted: Sun Mar 07, 2010 1:11 am    Post subject: Reply with quote
You can get a cheap digital tachometer
--> http://cgi.ebay.com/ebaymotors/2-1-16-52MM-Digital...ccessories
1985 Westy
