Cooling system change & Flush UPDATE
purplepeopleeater
purplepeopleeater is offline
PostPosted: Thu Mar 18, 2010 9:02 am    Post subject: Cooling system change & Flush UPDATE Reply with quote
I searched, I have a bently but I stumbled on a bong to assist in coolent refill?
I have shades of green in my system, and I want to get this out (I should have dumped it sooner, im sure ill pay the price)
I need to get this changed out before it gets warmer, VW said about $400 to do it. Shocked
Last edited by purplepeopleeater on Fri Mar 19, 2010 6:12 pm; edited 1 time in total
Dogpilot
Dogpilot is offline
PostPosted: Thu Mar 18, 2010 9:46 am    Post subject: Reply with quote
Read up on the shop vac method of sucking out all the coolant. It really works well. A quick search will get you the info. There are loads of ways to re-fill the system, they all work. $400 is a bit steep for a coolant change. Must be some pretty special coolant they use to re-fill it. Me, I am happy with Sierra & distilled water.
I have a very steep driveway, so I fill with the back end on the slope and the radiator bleed open and I crack the rear heater one till I get fluid drips. Once I have it full, I drive it around the block, up and down the hills for a few minutes, then I park it with the front end up the slope. I let it idle for a minute or two. Then I put a matchbook under the throttle stop, and proceed to bleed the radiator. I repeat the nose up bleeding a few days later to get whatever may have missed its opportunity to escape and worked its way around. Andrew's bong is really good for folks that may not have any slopes available.
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
purplepeopleeater
PostPosted: Thu Mar 18, 2010 9:47 am    Post subject: Reply with quote
Thanks Dog!
purplepeopleeater
PostPosted: Fri Mar 19, 2010 6:33 pm    Post subject: Reply with quote
Okay folks, so I did some reading and made a shopping list and here's what I ended up with
Here is a shot of the vac I picked up (buckethead $20 bucks)
Here is the muck I pulled out (little extra that I added from flushing the resivor too)
Here is something I thought up(maybe its been done...I dunno) I used some 1/4'' tubing and stuffed it down the breather hole and stuck the other end in a jug of clean distilled water, I sucked about 4 gallons through the system this way.
don't worry, I did refill and bleed and brought it to temp and drained...The first time i did this after suckin all the water through the breather there was barely and color to the water I shopvacced out out...to prevent being flammed I repeated this again...on the 3rd time I refilled bled and brought to temp, bled then used the shopvac on it....and no noticable color.
So, I pulled another 2 gallons through the breather hole again and used the shop vac....here's me keeping it happy
Here its my bong i made to fill the system---I must say this unit is reallly really handy!
levi
levi is offline
PostPosted: Fri Mar 19, 2010 6:42 pm    Post subject: Reply with quote
Hey!
15 gallons of distilled?
You really only need 2, mixed with 2 gallons of the coolant.
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
purplepeopleeater
PostPosted: Fri Mar 19, 2010 6:55 pm    Post subject: Reply with quote
2 for mixing with the 2 of coolent, and the rest i used for flushing the system.
Jamos
Jamos is offline
PostPosted: Sat Mar 20, 2010 12:10 am    Post subject: Reply with quote
Nice work!
That shopping cart looks just like mine did a few weeks back...
except mine didn't say W*lmart & I used some Sierra instead of Prestone.
Good idea about sucking the distilled through the radiator!
Also I recommend adding some Redline water wetter to your coolant if you can find it locally.
'86 Wolfy Westy Weekender
2020 Audi Q5
Timwhy
Timwhy is offline
PostPosted: Sat Mar 20, 2010 4:50 am    Post subject: Reply with quote
Do you have a parts list and directions on how you made your bong?
I'll be doing my coolant system hoses and pipes in a few weeks and your set-up looks really slick!
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
OilNBolts
OilNBolts is offline
PostPosted: Sat Mar 20, 2010 5:22 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=234192
Current fleet: Vanagons, two '88 GLs and an 89 Bluestar. Beetles, '63, '64, '72 convertible. Plus, four Subarus and three Prius. Too many cars.
Alaric.H
Alaric.H is offline
PostPosted: Sat Mar 20, 2010 6:08 am    Post subject: Reply with quote
I found this at a pawn shop and I see them for sale once in awhile.
The way it works is it pulls a vacuum on the coolant system you put the end in a bucket full of antifreeze open the valve and it sucks it out in to the coolant system 5 minute job I did not even have to bleed it.
purplepeopleeater
PostPosted: Sat Mar 20, 2010 6:12 am    Post subject: Reply with quote
here is what I used to make the bong,
1x 2"x30" black pipe(pre cut piece sold at homedepot)
1x 2" to 1 1/2" rubber reducer with clamps
1x 5/16" brass hose barb
10ft of 5/16" silicone hose, couldn't get any smaller quanity.
cost me $15 bucks to make it, plus it looks cool sitting in my garage.
maybe I'll carry it around in the car.
Alaric.H
Alaric.H is offline
PostPosted: Sat Mar 20, 2010 6:55 am    Post subject: Reply with quote
I only have room for 1 bong at a time I wonder if you get pulled over with 2 bongs if it would be trafficking.
240Gordy
240Gordy is offline
PostPosted: Sat Mar 20, 2010 8:29 am    Post subject: Reply with quote
unless your local water is really dirty I wouldn't worry about using tap water to flush the system since you are sucking it out right away anyway.
Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR
?Waldo?
?Waldo? is offline
PostPosted: Sat Mar 20, 2010 8:44 am    Post subject: Reply with quote
The brass barb is unnecessary. If you drill the hole with a slightly smaller diameter than the OD of the tubing, then the tubing will seal to the ABS by just pushing it through. That also lets you push enough tubing through so that the end extends below the opening and into the coolant reservoir. That lets you siphon all of the coolant out of the ABS and results in the coolant level being below the opening of the coolant reservoir. When the bong is then removed after draining, there is no spilling.
K58
K58 is offline
PostPosted: Sat Mar 20, 2010 8:50 am    Post subject: Reply with quote
I think I was charged around $100 to flush and fill mine at a local VW/Subie shop (Mastercraft)
To me it ain't worth the hassle and mess and I have the piece of mind that if it wasn't done right I'm warranteed. You know, the burping thing...just my 02
klucz
klucz is offline
PostPosted: Sat Mar 20, 2010 9:57 am    Post subject: Reply with quote
The tool in Alaric.H's pic is such a great thing to have. Fast and accurate. Back when I worked at a general maintenance shop this was the boss' favorite new toy. Spilling coolant and breathing the fumes all day makes you miserable, and some vehicles would take forever to purge. I would definitely pick one up if I had a nice garage set up.
I remember flushing my 74 Bronco 302 in high school shop class. We hooked it up to pressurized water and flushed with the engine running. Took forever until the water flowed clean. About the same age then as many of our Vanagons are now. Even if I could properly dispose of the dirty water I'd probably be more cautious doing this with a Vanagon. Makes me wonder what is lurking in the depths on my Van's cooling system. Guess I should go and install the new radiator already.
84 Westy 4spd sold
squeegee_boy
squeegee_boy is offline
PostPosted: Sat Mar 20, 2010 10:04 am    Post subject: Reply with quote
Klucz and Alaric, what's that tool called? I want one, but my Google-fu is failing me.
Robyn
1984 FrankenSyncro Westy. EJ25 RMW kit
klucz
klucz is offline
PostPosted: Sat Mar 20, 2010 10:24 am    Post subject: Reply with quote
squeegee_boy - 'cooling system service, test and refill tool' should improve your fu. Can't remember the brand of the one we used but it wasn't a cheapo kit.
84 Westy 4spd sold
squeegee_boy
PostPosted: Sat Mar 20, 2010 11:52 am    Post subject: Reply with quote
Thank you, sensei!
Wink
randywebb
randywebb is offline
PostPosted: Sat Mar 20, 2010 1:19 pm    Post subject: Reply with quote
re: "I used some 1/4'' tubing and stuffed it down the breather hole and stuck the other end in a jug of clean distilled water, I sucked about 4 gallons through the system this way."
- any closeup pics of the insertion point?
- also, would you do it that way again?
