Light blinks for what reason?
beteljuze
beteljuze is offline
PostPosted: Sat Apr 24, 2010 11:32 am    Post subject: Light blinks for what reason? Reply with quote
Ok I did a search but I'm not sure I understand. The red blinking light in the temp gauge blinks when the coolant level in the tank is low, correct? So it doesn't have anything to do with the coolant tempature, right? Thats what the gauge is for. So If your engine is getting hot, the needle will move up. If you start the engine and the coolant level is low, the red light will blink, whether the engine is hot or cold, right?
BlackDogVan
BlackDogVan is offline
PostPosted: Sat Apr 24, 2010 11:48 am    Post subject: Reply with quote
overheat is solid red, low coolant level is blinky
**oops, sorry about the dis-information!**
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat Apr 24, 2010 12:24 pm    Post subject: Reply with quote
Actually, both problems cause a blinking. There is no solid on state for the temp gauge led.
The low coolant control unit relay simulates a hot engine condition to trigger the blinking led. The early version sent a constant hot signal and this made the led blink and also pegged the needle hot. During the 85 model year a different version of the relay was phased in and it sends short 'engine hot' pulses to the temp gauge, enough to make the led blink but not enough to raise the needle very much. The pulses don't create the blinking, they only trigger the led blinking circuit within the gauge itself.
Mark
pioneer1
pioneer1 is offline
PostPosted: Sat Apr 24, 2010 1:05 pm    Post subject: blinky Reply with quote
Hey: One more thing...the light flashes for a few seconds on start-up.
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
Wildthings
Wildthings is offline
PostPosted: Sat Apr 24, 2010 1:34 pm    Post subject: Re: blinky Reply with quote
That is to tell you that the system is activated and the light works. In general all warning lights should come on at start up so you will know if they work or not.
240Gordy
240Gordy is offline
PostPosted: Sat Apr 24, 2010 1:39 pm    Post subject: Reply with quote
I seem to remember my dad's bay window doka had a feature where you push and hold the hazard button and all the dash lights would go on.
Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR
mmmdiesel
mmmdiesel is offline
PostPosted: Sat Apr 24, 2010 9:11 pm    Post subject: Reply with quote
So what does it mean if your coolant level is fine and you get constant blinking on start up, only stopping when you turn off the engine and then no longer blinking when you restart? I'm also getting constant blinking when the engine has been running for a few minutes and temps are reading slightly above half, again stopping when I pull over and re-start? This is with a 1.6td.
1998 T4 Caravelle 2.5 Tdi
2000 Eurovan Multivan 2.8 VR6
1960's Heilite Single Wheel
beteljuze
PostPosted: Sat Apr 24, 2010 9:42 pm    Post subject: Reply with quote
Yes, Yes, thats close to what I'm talking about. I'm looking at a 90 Camper to buy. The owner states sometimes the red light comes on randomly while he is driving. If he shuts off and restarts it goes out. He says it not overheating or getting hot, and it does it only sometimes.
What does this mean??
Wildthings
PostPosted: Sat Apr 24, 2010 9:53 pm    Post subject: Reply with quote
These systems get wacky as they age. Connections go bad and parts give out. If you do a search through dozens of post on this subject you will find what others have done.
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sun Apr 25, 2010 12:30 am    Post subject: Reply with quote
Try removing the coolant level sensor, and scrubbing it down with some CLR & an old tooth brush.
They get skuzzy in the expansion tank and will do exactly what your seeing happen.
T.K.
Nikkoleto
Nikkoleto is offline
PostPosted: Fri Apr 30, 2010 4:58 am    Post subject: coolant Reply with quote
What if the coolant warning light blinks as soon as u turn the engine on and the engine is cold?
foodeater
foodeater is offline
PostPosted: Fri Apr 30, 2010 7:52 am    Post subject: Re: coolant Reply with quote
read the fifth post in this topic.
89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP
240Gordy
240Gordy is offline
PostPosted: Fri Apr 30, 2010 7:58 am    Post subject: Re: coolant Reply with quote
or religiously read entire threads before posting. or start reading threads from way back just for fun, it can be fascinating stuff. hours and hours of fun.
Tencentlife said,
randywebb
randywebb is offline
PostPosted: Fri Apr 30, 2010 11:27 am    Post subject: Re: coolant Reply with quote
self-test for the warning system - normal
this is one thing that should be automatically Emailed to people when they join this forum
1986 2.1L Westy 2wd Auto Trans.
telebiker
telebiker is offline
PostPosted: Fri Apr 30, 2010 7:36 pm    Post subject: Re: coolant Reply with quote
Along with the caution to change all the fuel lines!
Baxta
Baxta is offline
PostPosted: Fri Apr 30, 2010 8:22 pm    Post subject: Re: coolant Reply with quote
I thought the flashing red light was the reminder to change your fuel lines! Laughing
Greg
'87 Syncro Westy 'Bastian'
2.2l
