63 Beetle Assist Straps / Coat Hook ?
72superblue
72superblue is offline
PostPosted: Sat May 08, 2010 1:50 pm    Post subject: 63 Beetle Assist Straps / Coat Hook ? Reply with quote
Anyone have difficulty mounting the coat hook on top of the straps?
All new straps / hooks from WW. Strap is on, no problem.
But I have *no* idea how this hook will fit over the strap. Screws look wider than cap.
shano63 Premium Member
shano63 is offline
PostPosted: Sat May 08, 2010 7:15 pm    Post subject: Reply with quote
Here is a pic from WW, might help... http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113857611BWW
63 T1 Ragtop Gulf Blue
20 Toyota Corolla 6spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
bill may
bill may is offline
PostPosted: Sun May 09, 2010 6:19 am    Post subject: Reply with quote
do you have the steel bracket that goes onto strap that the 2 screws go thru it and the strap? the cover slides downwards onto the steel bracket.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
72superblue
PostPosted: Sun May 09, 2010 7:43 am    Post subject: Reply with quote
I do have the brackets, thank you. Appreciate the picture too, that helps (missed the bracket the first time around).
I just can't figure out how the hook "snaps" in place over the bracket ... doesn't seem to be a fit. Will try again this afternoon.
bill may
bill may is offline
PostPosted: Sun May 09, 2010 8:03 am    Post subject: Reply with quote
it don't "snap" into the bracket. ^ there i said it slides down into place. put bottom of cover onto steel bracket and push down into place.
www.sv2s.com
SBS #100
72superblue
PostPosted: Tue May 11, 2010 1:25 pm    Post subject: Reply with quote
Bill,
Slid into place, but it doesn't "snap"? Just sits there? Here are pics ... if this is how it is, just seems a bit, er, unfinished. Smile
BWD
Samba Mailman
BWD is offline
PostPosted: Tue May 11, 2010 1:40 pm    Post subject: Reply with quote
You have the wrong coat hook! That is for '67 up!
You need this one. http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113857635A
BWD
JHC
member #2850
1966 Beetle
_____________________________
72superblue
PostPosted: Tue May 11, 2010 3:20 pm    Post subject: Reply with quote
UGH.
Got the wrapper, part # 301-829 from MidAmerica. http://www.mamotorworks.com/acvw?frame=1.6470
From the picture, though, looks like the 379-380 hook was sent (packaged / labeled incorrectly).
But THANK YOU for the help!
bill may
bill may is offline
PostPosted: Tue May 11, 2010 6:17 pm    Post subject: Reply with quote
correct----- that is for late 67 onwards that have 2 vertical screws instead of 2 horizontal screws.
www.sv2s.com
SBS #100
shano63 is offline
PostPosted: Tue May 11, 2010 6:55 pm    Post subject: Reply with quote
72superblue wrote:
UGH.
If it was gonna be easy you wouldn't be having this much fun... Very Happy
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
hitest
hitest is offline
PostPosted: Tue May 11, 2010 8:22 pm    Post subject: Reply with quote
72superblue wrote:
UGH.
...and this is where it all went downhill.
FU#5
72superblue
PostPosted: Fri May 14, 2010 11:54 am    Post subject: Reply with quote
Parts arrived today. What. A. Difference. Now I understand your "huh?" about the snapping questions.
Thanks again for the guidance.
