gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Tue May 11, 2010 7:34 am Post subject: Front Suspension Stiffener from CSP |
Hello-
Has anyone tried one of these?
http://www.vwparts.net/CSP498001111A.html
They look like a good idea (assuming that you don't break off the mounting bolts while extracting them.)
Thanks,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
74 Thing Samba Member
Posted: Tue May 11, 2010 7:44 am Post subject: |
Those look like parts that originally came on Thing beams. Basically they attact to the ends of the beam and tie it in to the pan to make it more rigid for off roading. |
Chad1376 Samba Member
Joined: January 29, 2005 Posts: 1435 Location: Henderson, Nevada
Posted: Tue May 11, 2010 8:21 am Post subject: |
74 Thing wrote: |
Here's the Thing brace - the bottom looks similar, but the CSP brace doesn't connect to the upper beam.
The Thing pan has a reinforced area where the brace attaches to the pan. I'm curious how the CSP is supposed to attach. It seems like it would help strengthen the beam from fore-aft movement, but I don't see how it would provide much benefit in keeping the beam from twisting along the tunnel axis. _________________ My never ending 1302 Autocross Project:
http://www.shoptalkforums.com/viewtopic.php?f=51&a...02b8f83f22 |
pupjoint Samba Member
Posted: Tue May 11, 2010 10:22 am Post subject: |
the CSP bars are 99% exact copies of what was fitted as OEM to Bugs exported to Japan and Thailand , a few more countries that I am not sure.
in my part of the world, we have been using these bars for close to 20 years now since we get them from abandoned cars.
the only part that is different is the squarish rectangle plate that acts as a washer.
this is how they look like on my 66
this is a Japan spec car, came factory fitted with these bars, see the washers
i do not know the exact reason why VW originally fitted these though , maybe some sort of safety compliance? |
Posted: Tue May 11, 2010 10:25 am Post subject: |
some other pics
john7 Samba Member
Joined: August 06, 2003 Posts: 1550 Location: Garden grove ca
Posted: Tue May 11, 2010 10:27 am Post subject: |
bugpack has sold something similar for years for baja bugs. but they are really easy to make too and for way less $ _________________ Jesus Saves
Slot Mag King!
I accept Paypal, CASH, GOLD, SILVER, COINS, GUNS & money orders. |
Posted: Tue May 11, 2010 10:29 am Post subject: |
john7 wrote: |
bugpack has sold something similar for years for baja bugs. but they are really easy to make too and for way less $ |
i have seen those and those feel really crappy. the OEM ones are really heavy and huge. I believe the CSP ones should be the same. |
marekv8 Samba Member
Joined: January 24, 2006 Posts: 276 Location: Louisiana
Posted: Wed May 12, 2010 6:42 am Post subject: |
I assume that the CSP pieces won't work with a slightly narrowed (2") beam? |
Posted: Wed May 12, 2010 6:57 am Post subject: |
marekv8 wrote: |
it should since it is a direct copy.
i am using the originals and i have a 4 inch narrowed beam and caster shims. |
vwtaiwan Samba Member
Posted: Thu May 13, 2010 6:14 am Post subject: |
marekv8 wrote: |
For 2"~3" narrow beams, you need to redrill the grease fitting. |
Posted: Fri May 14, 2010 1:43 am Post subject: |
vwtaiwan wrote: |
marekv8 wrote: |
yup forget bout that . My grease nipple was redrilled |
spook Samba Member
Joined: December 30, 2003 Posts: 2038 Location: in the shop 35750
marzano Samba Member
Joined: July 26, 2006 Posts: 55 Location: Sao Paulo, SP, Brazil
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1223 Location: Kansas City, Kansas
Posted: Sat Mar 21, 2015 6:40 pm Post subject: |
Very neat.... do these make a good difference? |
Howard 111 Samba Member
Posted: Sat Mar 21, 2015 7:36 pm Post subject: |
This is an OLD post, but it doesn't matter.
I run a turbo/FI street '73 Ghia. It was built just for straight line speed. I run no sway bars in the front. A 4' narrowed beam but KYB gas shocks all around, and a rear sway bar. The gas tank is a 10 gallon tank moved to the rear. It runs surprising well in corners.  _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
