vwmaniaman Samba Member
Joined: June 07, 2005 Posts: 605 Location: Grand Rivers,KY
Posted: Sat Jul 12, 2008 6:29 am Post subject: |
I have a 1600 SP all stock with 30-2 and an M distributor in my 65 Bug. Most reliable setup I've ever used. Getting 30+ mpg at 70mph. Still have points in distributor too. It always starts. |
PEPPE Samba Member
Joined: August 24, 2003 Posts: 1072 Location: Roma Italy
Posted: Wed Apr 01, 2009 7:32 am Post subject: r |
i use this older post to show the photo of the famous hidden "screw" of a pict-2
it is very difficult to remove.
i discovered that also earlier pict 2 have another hidden screw. it is in the top of carb and is an adjustable air bleed screw for idle jet.. very nice!
shawn407 Samba Member
Joined: March 10, 2008 Posts: 131 Location: Brandon,FL
Posted: Thu May 13, 2010 5:41 pm Post subject: |
sweet, thats probally my problem. |
DA67CA Samba Member
Joined: January 11, 2011 Posts: 17 Location: Honolulu, Hawaii
Posted: Wed Jan 19, 2011 10:15 am Post subject: stock carburetor on a 67 beetle |
I was just wondering what is the stock carburetor for 67 beetle? I thought it was the Solex 30Pict 2 but I read somewhere that this wasn't used until 1968? So that that make the Solex 30Pict 1 the stock carb for the 67 bug? Thank you! |
tspot100 Samba Member
Posted: Wed Jan 19, 2011 3:33 pm Post subject: |
i second that the 30 pict2 is a very reliable carb. rock solid idle and good running. the jets are removable, at least on the 3 carbs i rebuilt. stock carb with stock dist. |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26541 Location: Douglas, WY
Posted: Wed Jan 19, 2011 6:37 pm Post subject: |
The 30PICT-1 was the carb used in 1967. The one used on 12V US-Spec 1500 Bugs had a base flange modification state number of VW 105-1 and the matching distributor was the 113905205K.
The 30PICT-2 jets are all removable, of course. But, it's not a jet that is behind that little cap screw, it's a needle.
-Andy |
Big-C Samba Member
Joined: October 28, 2010 Posts: 28 Location: Gresham, Oregon
Posted: Sun Jan 23, 2011 6:38 pm Post subject: Solex 30 PICT 2 What is this? |
The photo shows the Carb on a new (to me) 1968 Std Type 1. I'm wondering, what is the snout looking object attached to the front of the carb linkage by a rod that pushes and controls the idle on my bug. At start up the engine idles great, maybe a tad too slow but it idles. But after warm up the motor idles at high rpm. The rod/plunger coming out of the snout object controls the idle by adjusting a arm in the linkage.
Please ignore the dirt, grime, leafs and pine needles, I've only had it a week.
What is the snout looking object? How do I adjust it to work correctly? Is it worth keeping on the carb? Any suggestions?
Posted: Mon Jan 24, 2011 8:52 am Post subject: |
That's the throttle positioner. It's only purpose it to hook to a secondary lever that'll pull the throttle open when you are "engine braking" - keeping the carb from fully closing even if your foot is off the pedal and coasting along in gear - this allows enough air into the mixture to reduce the amount of unburnt hydrocarbons coming out the tailpipe. The 66-69 Bentley Manual has a couple of pages talking about it.
Very original looking setup there! Even if dirty... still unusual to see so many original parts together. |
ledsel Samba Member
Posted: Mon Mar 12, 2012 6:39 pm Post subject: Idle jet |
I have a 30PICT-2 carb and it had a 6Volt choke and idle jet. I changed it to a 12 Volt but the Idle jet is longer. Will it work? it screws in O.K. but sticks out farther. |
mharney Samba Member
Posted: Tue Mar 13, 2012 12:03 pm Post subject: |
It's fine. |
