Big Brakes GoWesty
OhChit
OhChit is offline
PostPosted: Tue May 25, 2010 5:18 pm    Post subject: Big Brakes GoWesty Reply with quote
I was talking with the boys at Go Westy and they will be offering the S.A. Big Brake Kit very shortly at a resonable price.. I surely hope so or I'm doing my own like many others have. Just two problems, short on time and $$$$'s Sad
Fast Cars, and Slow Women Makes me DrooL.
syncrodoka
syncrodoka is offline
PostPosted: Tue May 25, 2010 5:25 pm    Post subject: Reply with quote
What do you do when the SA big brake has a problem -like a caliper for example, and they are NLA again? You will be back to doing your own like others on the forum from readily available parts. Something to consider Idea
RCB
RCB is offline
PostPosted: Tue May 25, 2010 5:44 pm    Post subject: Reply with quote
Well for christ sake man just hang loose until someone makes a good caliper Wink Rumer has it that ..............never mind Rolling Eyes
tozovr
tozovr is offline
PostPosted: Tue May 25, 2010 5:48 pm    Post subject: Reply with quote
I love love love love the Big Brake kit from Van Cafe on my '83. the prev owner did the conversion and after driving my stock '87 and then this...I'm just blown away with the performance...all random Audi stuff I can get at Napa if need be....in fact I have a bunch of pads from my A4 sitting on my shelf...Hmmmm Track compound Hawks LOL
...like a young Julie Andrews all whacked out on PCP, kinda fun but kinda scary too
'83 1.6TD
DX 5 Speed
"Whistler"
www.sinisterbikes.com
syncrodoka
PostPosted: Tue May 25, 2010 5:49 pm    Post subject: Reply with quote
Tell that to they guys that spend hundreds of dollars on a kit that they can't get parts to fix down the road. Rolling Eyes
Alaric.H
Alaric.H is offline
PostPosted: Tue May 25, 2010 6:01 pm    Post subject: Reply with quote
SA brakes are not that great any way.
RCB
RCB is offline
PostPosted: Tue May 25, 2010 6:05 pm    Post subject: Reply with quote
If there is money and a profit to be made in manufacturing the kit , dont you think someone will /might/maybe /make it. Until then I guess those people are outa luck Crying or Very sad
Maybe someone could start a specialty brake part company, they could call it ,Halt Hold it and Woah Laughing
syncrodoka
PostPosted: Tue May 25, 2010 6:09 pm    Post subject: Reply with quote
Why buy something knowing that repair parts will be difficult if not impossible to get in the future HMMM? Oh wait that is the whine from your other threads- never mind Rolling Eyes
RGS Paul
RGS Paul is offline
PostPosted: Tue May 25, 2010 6:48 pm    Post subject: Reply with quote
Gotta admit that I'm with Syncrodoka here, there are two good Audi based big brake kits on the market right now that will have parts available for a while, the SA stuff? Well rotors might be around next week they might not… Not something I enjoy thinking about. But then again I think that the brakes on the 7 Passenger Syncro are fine.
Paul
'87 Syncro 7-Pass. Adventure Touring Vehicle
"Simplicate, then add lightness." Colin Chapman
tozovr
tozovr is offline
PostPosted: Wed May 26, 2010 4:27 am    Post subject: Reply with quote
Paul
With my '87 GL, on stock brakes I always wondered why folks complained about Vanagons having bad brakes. I though, "They've obviously never driven Series II Land Rover." LOL One panic stop later and I understood. The van stopped be well enough and safely enough, but the fade with the solid front discs was wretched.
Getting into the '83 with the VC kit, I'm instilled with much more confidence...much better performance even in mundane stopping situations and no fade.
'83 1.6TD
DX 5 Speed
"Whistler"
Zero419
Zero419 is offline
PostPosted: Wed May 26, 2010 4:36 am    Post subject: Reply with quote
I thought fade was caused my water in the fluid. hot brakes+water=steam/brake fade.
No?
1987 Westy Auto Bostig 2.0 Ztec
RGS Paul
RGS Paul is offline
PostPosted: Wed May 26, 2010 6:06 am    Post subject: Reply with quote
I generally associate fade with multiple braking applications that heat up the caliper and rotor and boil the brake fluid. This is accelerated by old fluid that has a lot of water in it. On a single panic stop I think that pad material and the condition of your rotors is more important. I'm using the Metal Master pads (I think) on good replacement Brembo rotors with the stainless flex lines. Seems to work pretty well. The one thing I've learned is that adjustment of the rear drums is MANDATORY every time you rotate the tires, which for me is about every oil change since I have a Syncro and want to preserve the VC.
I'm considering going to the Van Cafe big brake kit at some point since it does give you a vented rotor which will reduce unsprung weight. I'll probably build my own kit though using a Wilwood caliper and a Audi rotor, might let me lighten things up a little more and have 2 piston monoblock calipers instead of the stupid floating calipers that manufactures love. We'll see… A new engine is the next big project so the brakes are on hold for the future since they suit me fine.
Paul
insyncro
Banned
insyncro is offline
PostPosted: Wed May 26, 2010 6:13 am    Post subject: Reply with quote
Paul,
I have mocked up Willwood double and quad piston calipers with 312mm Audi A8 rotors.
It will work nicely.
A adapter is needed and a spacer between the hub and rotor.
This is the same way I mount the G60 dual piston calipers.
16" wheels will be necessary.
I have had Girling 54s and the SA brakes in my past.
They are only slightly better than stock, IMO.
For a few hundred more you can have really good brakes.
tozovr
tozovr is offline
PostPosted: Wed May 26, 2010 6:31 am    Post subject: Reply with quote
No?
The stock rotors are non vented and smaller so they heat up much more and don't disperse that heat and that can boil fluid in the calipers. Perfectly new fluid can boil.
'83 1.6TD
DX 5 Speed
"Whistler"
presslab
presslab is offline
PostPosted: Wed May 26, 2010 7:08 am    Post subject: Reply with quote
When I had stock brakes they worked well. The power wasn't great, but standing on the pedal would cause them to lock up. I had some issues with fade when towing motorcycles but I upgraded to Porterfield composite pads/shoes and that was not an issue so much. I still had fade on long steep descents, though.
I upgraded to Audi 5000 front brakes and the improvement in power was enormous. They feel better than your everyday car, firm pedal and easy enough to lock up. But all that power was added to the front and the rear are still stock. The fade was not markedly improved over stock, because the front brakes are now doing more work than the rear because of their greater power.
So unfortunately the Audi 5000 brakes have the wrong leverage ratio which screws up the brake bias. Overall it's still an improvement over stock though. Maybe the SA brakes aren't like this? I think they are though, because aren't the SA rear brakes larger as well?
I guess I need rear disc now. Laughing
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
insyncro
Banned
insyncro is offline
PostPosted: Wed May 26, 2010 7:50 am    Post subject: Reply with quote
I purchased drilled stock sized rotors from David Marshall many moons ago.
They helped a bit with stopping power and have lasted the longest of any stock sized rotor i have used.
I think GW sells drilled or slotted PowerStop Rotors for 2wd and syncro vans.
After upping the rotor size and using calipers with more than one piston,
stock is not an option any longer
Brad4
Brad4 is offline
PostPosted: Wed May 26, 2010 8:36 am    Post subject: Reply with quote
I put the SA brakes on my automatic van a few years back. What a differance they make. No more smoking brakes in the Rockies. Dont worry about parts becoming NLA as pads for a Mercur XR4TI can be used. Rotors are still available from several Vanagon suppliers and the calipers should last more than 20 years like the factory ones did. All the upgrade kits blow away the factory brakes. You wont be sorry!
91 Vanaru westy
07 GTI Fahrenheit
14 GSR Beetle
66 single cab
64 Herbie Beetle
Beygon
Beygon is offline
PostPosted: Wed May 26, 2010 8:42 am    Post subject: Reply with quote
I bought the kit from Van Cafe for my 89 and am happy with it, I don't road race it but it seems to stop just fine. It seemed like there were a few things with that kit the others didn't have.
tozovr
tozovr is offline
PostPosted: Wed May 26, 2010 9:00 am    Post subject: Reply with quote
The cool thing about the SA brakes is, well, you can then say you have the South African Brakes Smile
I like saying I have a South African grill Smile
'83 1.6TD
DX 5 Speed
"Whistler"
j_dirge
j_dirge is offline
PostPosted: Wed May 26, 2010 9:13 am    Post subject: Reply with quote
No?
No.
Fade occurs when the disc heats to the point that the pad no londer grabs but just kind of glazes over.
No water/mositure is necessary.
It is downright frightening to experience.. And I did.. with my father and my son in the van going down a steep mountain grade where there was no run out. No place to go but over or into.
The OE brakes have worked OK for me in most "normal" driving conditions.. so long as you leave some room.
And for me its not about trying to race around a track or do wheel stands
In my opinon there is ONE reason to upgrade the Vanagon brakes and that is to upgrade to VENTED disks to minimize fade from heat..
..but I honestly can't see spending the kind of money that GW wants on brakes that may not be serviceable in the near future.
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
