how to add passenger side mirror to type 1
cheyenne10
cheyenne10 is offline
PostPosted: Wed Sep 01, 2004 10:22 pm    Post subject: how to add passenger side mirror to type 1 Reply with quote
I would like to add a stock style mirror to my right door. (it doens't have stock mount threads/hole) what are my options?
thanks.
[email protected]
ScrapJunkie
(O\U|U/O)
ScrapJunkie is offline
PostPosted: Wed Sep 01, 2004 10:23 pm    Post subject: Reply with quote
what year is your car? different years mounted differently
(O\U|U/O) Top Vw (o\UU/o)
DrDarby
DrDarby is offline
PostPosted: Thu Sep 02, 2004 6:16 am    Post subject: Reply with quote
On a -67 car you have to replace the upper ninge pin with one that has the mirror mount. On 68+ cars the proper procedure required disassembling the door, welding in the mirror mount, touching up the paint etc. What I always do is use a Karmann Ghia sedan mirror mount. It screws ONTO the surface of the door with two sheet metal screws and has a chrome cap to cover, then use a 68-79 Beetle Convertible right outside mirror. It screws right into the ghia mount. When all done it looks stock and not half assed.
Midwest Autosavers, Inc. Crystal Lake, IL
USMCbug
Samba Yoda
USMCbug is offline
PostPosted: Thu Sep 02, 2004 6:23 am    Post subject: Reply with quote
Ive heard that on 68+ bugs you can drill out the large hole that the mirror screws into in the exact same spot thats on the drivers side and there will already be a threaded plate there to mount the mirror in. Its simply covered up on the passenger side. This could be a myth though as I have never put this theory to the test.
72 Super Beetle
73 Standard Beetle
79 Baywindow Bus
65 Split Window Bus
79 Baywindow Bus
71 Super Beetle (current)
"When war does come, my advice is to draw the sword and throw away the
scabbard."
- General Thomas "Stonewall" Jackson
3Bugs
3Bugs is offline
PostPosted: Thu Sep 02, 2004 8:29 am    Post subject: Reply with quote
You may be correct. I got a door for my 72 out of a bone yard and it had the passenger side mirror location already in the door. Didn’t look like a cut and weld job. According the good people at Wolfsburg West, VW never offered stock mirrors until 1968 and until then there was no correct factory mirror. If that is true then I would suspect that VW doors on both sides would have the mirror mount.
3Bugs
Well, actually a 67 Bug, 72 Super, 61 Ghia and a 2004 Beetle Vert (sorry)
79SuperVert
79SuperVert is offline
PostPosted: Thu Sep 02, 2004 9:40 am    Post subject: Reply with quote
Especially considering that VW sold both RH and LH drive cars, it would make sense to have both sides prepped to accept a mirror.
Juan
Juan is offline
PostPosted: Thu Sep 02, 2004 9:58 am    Post subject: Reply with quote
And be careful and nice to both the mirror and the car. You can fuck up the paint and/or scratch the mirror quite easily... If you're an ass like me anyway... Very Happy
buggirl
buggirl is offline
PostPosted: Thu Sep 02, 2004 2:28 pm    Post subject: Reply with quote
We're also doing this right-side mirror on a '65. What's the trick to getting the hinge pins out without paying a garage with special tools?
luis
luis is offline
PostPosted: Thu Sep 02, 2004 8:13 pm    Post subject: soak it Reply with quote
Soak the pin that is still inserted into the door hinge (remember the threaded top was cut off at some point) with wd-40 or liquid wrench. Keep spraying down into it for days at a time and let it soak in. Then use a metal chisel and pound it out with a heavy hammer. This however does not always work. If you have access to an air compressor a air chissel will remove it in a pinch. If your not careful you might mess up your paint if you try to pound it out yourself. If you have cherry paint just pay the shop, it can't be more than 20 minutes at the most to remove this with an air tool that will not damage your paint. If your lucky it will remove easy by pounding, but if its the original its been there a long time and not likley to remove easily.
3Bugs
3Bugs is offline
PostPosted: Thu Sep 02, 2004 11:46 pm    Post subject: Re: soak it Reply with quote
Luis,
Is the air tool you mention that the shops are using any different than the an a air hammer? I would like to acquire one for my own use if they are. The air hammer and chisel approach is about 40% effective at getting them darn things out and almost 80% effective at messing up the paint.
Thanks,
3Bugs
luis
luis is offline
PostPosted: Fri Sep 03, 2004 6:01 pm    Post subject: air chisel Reply with quote
its an air chisel not an air hammer. In my case it came right out in about 5 seconds, but remember I soaked it for about a week. Air chisel pics:
http://www.thebugshop.org/images/site/airchisl.jpg
Actually, the tool itself is sometimes referred to as an "Impact Hammer" as you can use many non-chisel attachments in it.
Luis
Michaudracing
Michaudracing is offline
PostPosted: Fri Sep 03, 2004 7:39 pm    Post subject: Reply with quote
Eastwood sells a hinge pin remover that looks like a c-clamp, for about $25. Haven't tried it on VW hinge pins, though.
cheyenne10
PostPosted: Tue Sep 07, 2004 10:09 pm    Post subject: curious right side threads Reply with quote
It would be great if mount was hidden behind door skin. Any more input on this or history?
my65vert
my65vert is offline
PostPosted: Wed Sep 08, 2004 4:38 am    Post subject: Reply with quote
I want to put a pass side mirror on my vert but I'm very afraid it would mess up my paint getting the pin out. The shop would have to be liable for my paint before I would let them do it.
OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment.
Miguel Arroyo
Miguel Arroyo is offline
PostPosted: Thu Sep 09, 2004 10:06 am    Post subject: Right Hand Mirror Reply with quote
I have a 1970 sedan w/o the sunroof. Prior to painting it my shop cut a hole on the pasanger door and welded in a nut to mach the threads on an reproduction of the right hand mirror. It works great and in heavy traffic as in Miami, Florida it has saved me from getting into an accident.
Hope this helps.
PJMS
PJMS is offline
PostPosted: Thu Sep 09, 2004 2:27 pm    Post subject: Re: curious right side threads Reply with quote
Unfortunately, there is no hidden nut. Doors without the hole will only have the inner plate (with hole) to which the nut would have been welded. However, VW used to have special procedure to fit the right hand door mirror by cutting the hole and using a special nut. I found this quite a difficult process and preferred to use a late model steering wheel nut, which I would tack weld to the retaining plate after filing two slots to accommodate the welds. Obviously, great care is necessary with the paint work.
As a point of interest, since 95% of Bug production was LHD, the right hand doors had no mirror fittings as standard. But with RHD vehicles, they came with a blanking plate on the left door mirror mount, making it very simple to fit passenger door mirrors on these cars.
cheyenne10
PostPosted: Sat Sep 11, 2004 10:58 pm    Post subject: thanks for advise so far Reply with quote
I was hoping it would be easier I guess. I had a street car many yrs ago with the 5 panel panoramic mirror inside. Had to remove visors to do it but driving all the time in big city traffic it saved my bacon many times. That might be cheap alternative. I've just grown older and fonder of stock apperances.
[email protected]
tfrancisj@mindspring.com is offline
PostPosted: Sun Sep 12, 2004 10:14 am    Post subject: Reply with quote
when using the air chisel, don't you chisel up instead of down? tom
DrDarby
DrDarby is offline
PostPosted: Mon Sep 13, 2004 6:22 am    Post subject: Reply with quote
I checked 10 - 12 68 - 77 doors I have stored and all have the reinforcement plate with the hole but none had the nut. Other than risking screwing up you paint by welding use a Karmann Ghia sedan mirror mount. It screws ONTO the surface of the door with two sheet metal screws and has a chrome cap to cover, then use a 68-79 Beetle Convertible right outside mirror. It screws right into the ghia mount. When all done it looks stock and not half assed. I have installed maybe 20 of these over the last 30 years for customers. It is all done using VW parts and looks perfectly stock.
[email protected]
schmelz3@netzero.net is offline
PostPosted: Mon Sep 13, 2004 7:27 am    Post subject: Reply with quote
The hinge pin removal tool from Eastwood won't work. Because of the shape of the door you can't get the tool lined up straight .
