NAES Samba Member
Joined: September 10, 2003 Posts: 2183 Location: AREA-52 Southern Killafornia
Posted: Thu Sep 02, 2004 10:12 pm Post subject: Does your turn signal housing rotate on the column? |
Mine does and its a PIA. I've tried shaving the halves down in order to get a tighter fit but it still rotates when I engage the turn signal switch. Are there any tips that you all have?
TIA _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
Lind Samba Member
Joined: November 06, 2000 Posts: 10218 Location: idaho
Posted: Thu Sep 02, 2004 10:29 pm Post subject: |
do you have the little silver half round piece that goes in there? I usually wedge a small piece of metal in between the silver thingie and the column and that causes it to bind when you tighten it down. |
Friedpotatoes Addicted4life
Joined: April 04, 2003 Posts: 1215 Location: Fresno California
Posted: Thu Sep 02, 2004 10:31 pm Post subject: |
most comenly i have seen/used electrical tape or duct tape _________________ 56- Wolfsburg Single Cab
57- Oval Window Bug (Agave Green) |
volksaddict Samba Member
Posted: Fri Sep 03, 2004 4:21 am Post subject: |
1 of mine has duct tape. another has a bullet dent on the clamp side (the red single, Lind). 2 others have pieces of cardboard wedged in there to shim it up.
None of them slip or rotate  |
Sergeant D Samba Member
Joined: December 04, 2003 Posts: 176 Location: Tampa Bay
Posted: Fri Sep 03, 2004 6:57 am Post subject: |
Man I was all set to say take the two halves and sand a bit off of each!
That fixed mine and I was able to take the vintage 1968 piece of cardboard out and auction it on eBay!
Sorry it didn't work for you. Did you take enough metal off? Screws tight and not stripped?
Want to bid on my old piece of cardboard?
Good Luck... _________________ Sgt D
"...Cause Sgt. D is coming, and You're on his list..." |
type2guy Samba Member
Joined: April 11, 2002 Posts: 53 Location: Water Valley, TX
Posted: Fri Sep 03, 2004 12:10 pm Post subject: |
One of the best things to have lying around is an old bicycle innertube. I always have them around for different uses. This is a good example.
Cut a section to wrap around the column where the switch mounts. Tighten the switch on there good and it won't move anymore. Cheap and easy.
If you don't have any old tubes, go to bicylcle shop and ask for a few they've replaced. They've always got 'em in the trash can for free. |
swervyjoe Samba Member
Joined: February 07, 2004 Posts: 968 Location: denver, co
Posted: Fri Sep 03, 2004 4:46 pm Post subject: |
Sergeant D wrote: |
Want to bid on my old piece of cardboard? |
whats it up to? i'm interested. :mrgreen:
i was eyeing the duct tape to do mine, but it looks too wide. i'll try e-tape or cardboard (NOS, of course). |
vwjosh6070 Driveway Camper
Joined: August 24, 2003 Posts: 2802 Location: not camping...
Posted: Fri Sep 03, 2004 5:31 pm Post subject: |
i have e-tape on mine. it doesnt move, and its cammo!!! i will try the cardboard when the tape gets crappy. _________________ josh, AKA "the infamous josh"
1973 Transporter "Floyd"
****Wheres my old bus?! 1967 Montgomery Ward Camper****
KI4MXO |
rizzag Now Wut?
Joined: April 19, 2001 Posts: 3125 Location: Keizer, OR
Posted: Fri Sep 03, 2004 5:33 pm Post subject: |
ok everyone here is the tip of all tips for this. the tape/cardboard works ok for a little while till the switch rubs through them. if you want a good repair that will last, take a soda/beer car and cut a strip out of it, wrap it around and put a little piece of tape to hold it, put your switch back on and bam.... no more movement and it will never wear back down. some may need two strips. _________________ flossin, tossin, dippin, and trippin |
Posted: Fri Sep 03, 2004 5:35 pm Post subject: |
rizzag wrote: |
ok everyone here is the tip of all tips for this. the tape/cardboard works ok for a little while till the switch rubs through them. if you want a good repair that will last, take a soda/beer car and cut a strip out of it, wrap it around and put a little piece of tape to hold it, put your switch back on and bam.... no more movement and it will never wear back down. some may need two strips. |
i'm on it. sounds easy enough. thanks |
Bugman Jeff Samba Member
Joined: May 20, 2004 Posts: 636 Location: Evansville, WI
Posted: Fri Sep 03, 2004 8:23 pm Post subject: |
And here I thought I was the only one with this probled. Thanks for making me feel like part of the group gang
-Jeff _________________ Restorer of Porsche Speedster 80486  |
del Samba Member
Posted: Fri Sep 03, 2004 8:45 pm Post subject: |
Friedpotatoes wrote: |
most comenly i have seen/used electrical tape or duct tape |
mine has electrical tape. it works great in the morning or night, but during the day when it warms up it moves around. I'm going to try the innertube or the aluminum can trick mentioned in a couple posts.  |
Kaput Samba Member
Joined: December 12, 2002 Posts: 859 Location: Lakewood, CO
Posted: Fri Sep 03, 2004 9:01 pm Post subject: |
I shimmed mine with alluminum can. dosent move but dosent cancel right. Cancels the turn randomly.
Hijack: are those cancel tabs supposed to be straight out? Mine are a bit crooked and dont cancel right, especially with a right hand turn. if I bend it straight will it work better?? whats the best way to fix it without breaking the switch? |
AndrewM Samba Member
Joined: February 18, 2002 Posts: 496 Location: Charlotte, NC
Posted: Fri Sep 03, 2004 10:04 pm Post subject: |
Every single bus i've owned has had that problem. I once used a radiator hose clamp up snug against the bottom of the signal housing to fix the problem. It looked like shit but it worked. Would a little dab of locktite work on something like this? |
BryanM Samba Member
Joined: June 14, 2002 Posts: 4212 Location: Concord/Charlotte NC
Posted: Fri Sep 03, 2004 10:48 pm Post subject: |
a dab of liquid nails _________________ -Bryan
Motorwagen LLC
Concord NC |
rustybus Shasta Snow Trip Newt
Joined: November 24, 2002 Posts: 919 Location: Arizona
Posted: Mon Sep 06, 2004 7:05 am Post subject: |
If you look close at the place where the silver half circle thing fits into the housing you will usually see that it has worn the edges of the housing where it sits. I have put a very small piece of wire over the worn spot on both sides before putting the silver half circle in and it works like new. The problem with tape here in the heat is it gets sticky and squishy and acts like lubricate for the switch to turn. Using the method above makes sure you have maximum metal to metal surface area, similar to when the switch was new. _________________ Richard
www.rustybus.com www.shastasnowtrip.com |
debunked Samba Member
Posted: Tue Sep 07, 2004 1:32 pm Post subject: |
a small strip of aluminum foil folded a few times has fixed mine and it hasn't moved since. |
Ian Samba Moderator
Posted: Tue Sep 07, 2004 8:27 pm Post subject: |
I have electrical tape on mine. Doesn't work well. Going to try to aluminum can idea. Thanks Rizzag! _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 & KEN CRIMMINS 1957-2024 |
Split Decision Samba Member
Joined: August 25, 2003 Posts: 675 Location: Katy, Texas
Posted: Wed Sep 08, 2004 5:26 am Post subject: |
Mine has been driving me nuts, too. I'm gonna give the inner tube a try. _________________ In 1966 Volkswagen pinched my loaf.
67 Deluxe
On year seven of the "I'll get it done next week" engine rebuild.
74superTN wrote: |
Just seems these days that unless you are dragging your engine on the ground and have crazy negative camber, people seem like you're doing it all wrong. |
elaine Samba Member
Joined: September 05, 2003 Posts: 35 Location: San Anselmo, CA
Posted: Wed Sep 08, 2004 1:06 pm Post subject: |
I also thought I was the only one who had this problem!! A good fix akin to the inner tube thing is one of those big rubberbands that you get off asparagus in the grocery store. No adhesive, no cutting of beer can. I can't say it'll last a lifetime but what the heck, I like asparagus anyway. _________________ Elaine |
