FritoBandito Samba Member
Joined: May 30, 2010 Posts: 4 Location: Full-Time Motorhomer
Posted: Sun May 30, 2010 4:24 pm Post subject: 1969 Type 3 Fuel Injection |
Hey Y'all.
New to Samba but referred to this site by a person on the West Coast.
I'm the one and only owner of a 1969 VW Type 3 Squareback, EFI, standard 4-speed tranny, 84,512 miles, 1600cc engine.
The car was always garaged and was a daily driver (in Wisconsin) from October 1969 to 1986. As expected (winter salty roads) some rust appeared. At that time, I bought 4 new/used steel fenders, prepped and painted them the original color. Also repainted all other "removable" parts ... doors, hood, hatch, etc. off of the body and the body was repainted. After reassembly, it was only a summer driver ... May to October. Due to the sale of our home and having a stroke, the car was moved to a dry barn, put on jack stands and sat there until May 1, 2010.
Getting it ready to sell, I wanted it to be "run-able". So I did several things: Four new 165/R15 radials, new battery, had the injectors cleaned and tested for ohms and spray pattern. Before trying to start the car, I wanted to know if the fuel pump was delivering pressure to the fuel ring. It didn't! After unhooking the hi-pressure fuel line at the "T" before the No.1 and No. 2 injectors, running the pump, it only delivers about 2 to 4 ounces of fuel after 10 or 12, 1-second "pumps". When the fuel pump runs, fuel should be pouring out of the hose like water thru a garden hose. Shouldn't it?
Question: Can the Fuel Pump be rebuilt?
I assume there's an obstruction (rust or scale) in one or more of several components: tank, fuel line to filter, filter, fuel line to pump, pump, fuel line to steel lines thru the tunnel, or the fuel line to the "T".
The car was stored (albeit 9 years) with a full tank of fuel with Sta-Bil Gas Stabilizer. Could that have evaporated and left varnish or gunk?
Any suggestions on how to proceed?
FritoBandito |
rosevillain Samba Member
Joined: December 28, 2005 Posts: 1341 Location: roseville, ca
Posted: Sun May 30, 2010 5:36 pm Post subject: |
| The nipple on the gas tank that the fuel pump attaches to is removable, and behind it is a mesh filter (screen). Clean the in the tank screen, and replace the inline filter. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36377 Location: Conejo Valley, CA
Posted: Sun May 30, 2010 5:59 pm Post subject: |
| Jim Adney can rebuild pumps. He also sells a kit you need, whether you realize it or not. Check the fuel filler area of the right front fender, and find your leaky, rotted overflow and vent lines. He ahs a kit to repair those. With that open, driving will throw up dirt and water into your fuel system, and it will settle at the lowest point-- your fuel pump. Might be what ruined yours in the first place. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Sun May 30, 2010 7:11 pm Post subject: |
Try soaking your pump in diesel fuel overnight, then with it still submerged in diesel hook it to a battery and run it forwards, then reverse polarity and run it backwards.
If worst comes to worst, you can just plug the fuel return hose that comes off the pump and run a fuel- injected Bus/ Vanagon pump inline. _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
| Just my hands. And a little lube. No tools. |
Those who can- do.
Those who can't? Subaru. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25186 Location: Central Iowa
Posted: Sun May 30, 2010 9:37 pm Post subject: |
Or, the 85 Ford Ranger pump that some of us have been running for years. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sun May 30, 2010 10:17 pm Post subject: |
| Russ Wolfe wrote: |
| Or, the 85 Ford Ranger pump that some of us have been running for years. |
I just like to keep it German (or at least Czech...) Some day, someone, somewhere, is going to need a fuel pump for an actual '85 Ford Ranger. And, when he finds out they're NLA, he's probably going to start stealing pumps off of Type 3s. We have you to thank for this. See how you are?  _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
Those who can- do.
Posted: Mon May 31, 2010 10:24 am Post subject: |
Thanks to all who replied.
rosevillian -- If my memory is correct, the fuel from the tank goes thru a fuel line to the fuel filter before it enters the fuel pump, doesn't it?
KTPhil -- Being new to Samba, I don't know who Jim Adney is. Member? I know I have to replace the rubber grommet that fits around the fuel filler, in the right-front fender but I didn't realize that the rotted overflow and vent line MAY BE the source of debris, too. I don't know if the fuel pump is ruined. It just doesn't seem to produce the volume of fuel to the fuel ring. Good suggestions, however. I'll check it out.
Tram -- I read your "run the fuel pump in diesel fuel" account. If other sources of blockage don't solve the problem, I may resort to that procedure. Can you run pressurized fuel to the ring WITHOUT having a return fuel line?
Russ Wolfe -- An '85 Ford Ranger Fuel Pump? That's a new idea (to me)! Does that actually work? How much of a job is it to physically make the substitution? Mounting bracket? Or is it a direct bolt-on component?
Thanks again, guys.
FritoBandito |
Posted: Mon May 31, 2010 10:49 am Post subject: |
You cannot pressurize the fuel loop without a return. That invention did not come about until 1993.
What Tram was referring to, was that the Vanagon pump is only a 2 fitting pump. In, and out. So is the Ranger pump.
The original T-3 pump is a 3 fitting pump. In, out, and return to tank, or bypass.
What I like about the Ranger pump, is that it has the same size fuel fittings. The Vanagon, or FI bug pumps have a 10mm inlet, and has to be adapted to. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18054 Location: Eugene, OR
Posted: Mon May 31, 2010 11:09 am Post subject: |
If you hook up a cheap water pressure gauge from Home Depot to the fuel T you should get 30 lbs pressure. _________________ 69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
voeltzwagen Samba Member
Joined: June 15, 2009 Posts: 173 Location: Minneapolis
Posted: Sat Jun 05, 2010 10:02 am Post subject: |
No, that is the one that goes in the tank, and is just a lift pump.
This is more what you want.
http://www.oreillyauto.com/site/c/detail/ATN0/E844...;ppt=C0128 _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sat Jun 05, 2010 10:29 am Post subject: |
thanks russ _________________ 1973 Squareback, AT, A/C, FI |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23584 Location: Kimball, Mi
volkswagen4life Samba Member
Joined: July 31, 2010 Posts: 136 Location: Walla Walla, Wa
Posted: Sat Jan 01, 2011 10:58 am Post subject: |
| Tram wrote: |
If worst comes to worst, you can just plug the fuel return hose that comes off the pump and run a fuel- injected Bus/ Vanagon pump inline. |
How do you do that just put a bolt in the end of the hose? wouldn't that cause fuel to build up in it? _________________ 78' Type 2 "little buggie"
74' Type 1
70' Type 3 square |
Posted: Sat Jan 01, 2011 11:49 am Post subject: |
The return fitting on a T-3 pump, is like a pressure relief. It goes into a "T" in the return line coming back from the engine.
When using another pump that does not have that fitting, you eliminate the T and only the engine return has to go back to the tank. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
66DustyBug Samba Member
Joined: June 27, 2012 Posts: 54 Location: Hedgesville WV
Posted: Sat May 03, 2025 3:50 am Post subject: Re: 1969 Type 3 Fuel Injection |
Hi,
I am brining a 1969 fastback back to life from a long hibernation since 1988. The links above for the 85 ranger fuel pumps no longer seem to work, so does anyone have an actual part number that might be used as a keyword for a search. So far everything that I can find, seem to be universal pumps, which is fine, but I am trying to find the one with the correct sized fittings like mentioned above. Thanks. _________________ 66 Sunroof Bug(Sandy)
12 Beetle commuter car(Mater)
98 New Beetle Baja
69 Type 3 Fastback
70 Baja Bug |
Posted: Sat May 03, 2025 12:01 pm Post subject: Re: 1969 Type 3 Fuel Injection |
| 66DustyBug wrote: |
Hi,
I am brining a 1969 fastback back to life from a long hibernation since 1988. The links above for the 85 ranger fuel pumps no longer seem to work, so does anyone have an actual part number that might be used as a keyword for a search. So far everything that I can find, seem to be universal pumps, which is fine, but I am trying to find the one with the correct sized fittings like mentioned above. Thanks. |
The pump in question is for the 85-90 Ford Ranger frame rail pump. Airtex number E2000, from Autozone, or E20160 or E16020 (can't remember which) from O'Reilly's. If you do a search in the type 4 forum, Ray has a long list of pumps that also work, as those cars use the same (basically) FI system that the type 3 uses. I've used both pumps, and they work good as a replacement for the 300+ dollar Bosch pump.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Scotty D Samba Member
Joined: February 08, 2020 Posts: 312 Location: Claremont CA
Posted: Sat May 03, 2025 12:32 pm Post subject: Re: 1969 Type 3 Fuel Injection |
As Bob mentioned above, the pump you’re looking for is the Ranger’s secondary in-line pump attached to the frame rail, not to be confused with the primary pump inside the fuel tank.
I grabbed this generic version recently.
KTPhil  Samba Member
Posted: Mon May 05, 2025 9:35 am Post subject: Re: 1969 Type 3 Fuel Injection |
Wow, I'd have a lot of fun with 650HP in a VW!
 _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
