Autometer speedometer
earthquake
earthquake is offline
PostPosted: Sun Jun 01, 2008 12:17 pm    Post subject: Autometer speedometer Reply with quote
OK
I have a new Autometer mechanical speedometer that is for GM style drive, does any body know if I can hook it up to a VW speedometer cable drive? Thanks
Earthquake
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
BrockGrimes
BrockGrimes is offline
PostPosted: Sun Jun 01, 2008 12:49 pm    Post subject: Reply with quote
If you got it hook it up to the VW cable an see.
Probably run into calibration issues.
Selling the SB:
http://www.thesamba.com/vw/classifieds/detail.php?id=557335
Banzai KG
Banzai KG is offline
PostPosted: Sun Jun 01, 2008 1:00 pm    Post subject: Reply with quote
I still need to get a ratio adapter made for the Autometer speedo.
If you notice on my speedo...when I'm at 3400 rpms, it should be 65mph...but the speedo reads 58mph.
As for the speedometer cable...
The threads on the back of the Autometer speedo is 5/8"x18 thread.
I used the knurled thumbscrew (5/8" - 18 threads) from a early Chevy tranny to speedometer cable (wrecking/bone yard), reamed out the inner diameter of the knurled thumbscrew till it slips over the stock VW speedometer cable and screwed to the back of the Autometer speedo.
Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/
earthquake
PostPosted: Sun Jun 01, 2008 11:31 pm    Post subject: Reply with quote
Banzai KG
What size tires are you running on the front of your car? a smaller tire would show a faster speed right? I'm going to be using a 225/75/15 off road tire so it would be off even more I would think.
Earthquake
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
67jason
67jason is offline
PostPosted: Sun Jun 01, 2008 11:42 pm    Post subject: Reply with quote
earthquake wrote:
Banzai KG
Earthquake
he is running 145/15s on the front of his ghia.
67 bug x3
67 ghia
64 bug
Airkewld
Airkewld is offline
PostPosted: Thu Jul 16, 2009 3:44 pm    Post subject: Reply with quote
Jim can you email details on what you did, I am doing something very similar to you, I appreciate it. [email protected]
FAQ - https://airkewld.co/FAQ
View our Industry Leading Products - https://www.airkewld.com/Products-s/2322.htm
We made a iPhone Ringtone with a Classic VW Turbo Engine - https://airkewld.co/RingtoneTurbo
YouTube Channel - https://airkewld.co/SubSamba
paco62
paco62 is offline
PostPosted: Fri Jun 18, 2010 12:11 pm    Post subject: Reply with quote
So, aside from calibration issues, If I can get something to ensure a good connection between the stock speedo cable and the autometer guage, it should display speed, albeit incorrect speed. Is that right?
Dale M.
Dale M. is offline
PostPosted: Fri Jun 18, 2010 4:03 pm    Post subject: Reply with quote
Down on Monterey Peninsula?
Dale
Banzai KG
PostPosted: Fri Jun 18, 2010 11:51 pm    Post subject: Reply with quote
[quote="Dale M."]
Dale
Yep...was heading down to Monterey for the MPAS (Monterey Peninsula Aircooled Society) - http://www.mpasvw.com "Ring in the New Year Cruise" on that first weekend of January 2006.
Jim Kikuchi
paco62
paco62 is offline
PostPosted: Sat Jun 19, 2010 12:05 am    Post subject: Reply with quote
[quote="Banzai KG"]
Dale M. wrote:
Dale
So, If I were driving down to Monterey for the MPAS Cruise and was able to connect my sender to my new autometer mechanical speedometer, aside from calibration issues, If I can get something to ensure a good connection between the stock speedo cable and the autometer guage, it should display speed, albeit incorrect speed. Is that right? Laughing
Dale M.
Dale M. is offline
PostPosted: Sat Jun 19, 2010 8:51 am    Post subject: Reply with quote
[quote="Banzai KG"]
Dale M. wrote:
Dale
Yah... Recognized the area/sign..... Been by it 1000 times.... Used to live down there...
Will probably be back there June 27 for Autocross racing at Marina Airport...
Dale
earthquake
PostPosted: Sat Jun 19, 2010 11:45 am    Post subject: Reply with quote
I found a place that make a adapter that you can change the ratios to calibrate you speedo, but have not had time to check them out.
http://www.a1electric.com/speedometer.htm
Casey
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
1sick67
1sick67 is offline
PostPosted: Tue Jan 03, 2012 4:12 pm    Post subject: Reply with quote
I hooked mine up the same way as Banzai KG did with the thumbscrew off an old gm speedometer cable pre 75 or so 5/8-18 threads and it is about 5-7 mph off but it works nice. I researched a couple speedo shops which said they could make me one but it was real costy!
MURZI
MURZI is offline
PostPosted: Tue Jan 03, 2012 5:09 pm    Post subject: Reply with quote
3/8 flare plumbing nut works perfect. And with 165 tires it reads 17% slow.
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
