type 3 Alternator conversion (my version)
Page: 1, 2, 3, 4  Next
Endangered Species
Endangered Species is offline
PostPosted: Fri Jul 02, 2010 9:33 am    Post subject: type 3 Alternator conversion (my version) Reply with quote
Thought I would share my version of an alternator coversion...I had a 75 amp bosch alternator laying around, so that's what I went with...I looked up and read every post on this conversion and decided to go with mounting it backwards as seen in many posts...but after test fitting it with the spacer that would be needed to clear the tin and still line up square with the belt and lower pulley (even after cutting the lip off the alternator) it was still going to be to tall to close the enginge cover...So I decided to mount it forward, and here is how I did it....
Max Welton
Max Welton is offline
PostPosted: Fri Jul 02, 2010 10:14 am    Post subject: Reply with quote
How about a picture? Interested in how you arranged for a flow of air through the unit for cooling.
Max
1967 Type-3 Fastback
Endangered Species
PostPosted: Fri Jul 02, 2010 10:33 am    Post subject: Reply with quote
trying to figure out how to post pics on this thing
RyanRodman
RyanRodman is offline
PostPosted: Fri Jul 02, 2010 10:38 am    Post subject: Reply with quote
How to post pictures:
http://www.thesamba.com/vw/forum/viewtopic.php?t=6
Endangered Species
PostPosted: Fri Jul 02, 2010 10:39 am    Post subject: Reply with quote
first had to remove exhaust, boot, and tin...
http://www.hubgarage.com/mygarage/vehicles/23917/photos/3147616
http://www.hubgarage.com/mygarage/vehicles/23917/photos/3147620
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Jul 02, 2010 10:46 am    Post subject: Reply with quote
You should Preview your Posts/pictures before you Submit them.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Russ Wolfe
Russ Wolfe is offline
PostPosted: Fri Jul 02, 2010 11:16 am    Post subject: Reply with quote
I fixed your URL's, but you have to be a member to see the photos.
Just post the pictures in The Samba gallery.
Gary: OK. Ima poop.
Endangered Species
PostPosted: Fri Jul 02, 2010 12:05 pm    Post subject: Reply with quote
first remove the generator, exhaust, boot, and tin...
Endangered Species
PostPosted: Fri Jul 02, 2010 12:14 pm    Post subject: Reply with quote
Next I put the Alternator into the generator saddle and strapped it in to see what I would need to do to make it fit...
then I marked the fan housing were it would need to be modified...don't worry I used an already damaged housing for this mod...
[/img]
Endangered Species
PostPosted: Fri Jul 02, 2010 12:23 pm    Post subject: Reply with quote
I cut this section out with a jig saw useing a metal blade...(little pointer when cutting or sanding soft pot metals or aluminum get yourself a candle and run the blade or sand paper through it regularly while you work and it will keep the blade or sand paper from gumming up)
Endangered Species
PostPosted: Fri Jul 02, 2010 12:33 pm    Post subject: Reply with quote
The cut left an opening that I needed to build some tin for so as to retain the engines cooling...
here is the rough tin which I later cleaned up and reworked
Endangered Species
PostPosted: Fri Jul 02, 2010 12:46 pm    Post subject: Reply with quote
I also needed to relocate the studs for the alternator strap...if you have ever tried to weld on fan shroweds you know it almost impossible, so what I did was to cut the existing studs flush and use them to weld the new brakets to...I drilled holes in the new brackets directly above the flush cut studs for welding...then I welded new studs...1/2" further out and 1" further back on both sides...
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Fri Jul 02, 2010 12:53 pm    Post subject: Reply with quote
It's already a LOT of work but just shows there's more than one way to do it. Keep going!
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
Endangered Species
PostPosted: Fri Jul 02, 2010 12:56 pm    Post subject: Reply with quote
As you can see I took extra care in making sure everything was square and lined up, and by using the rear half of the cradle the pully location size and belt length remain stock...
Endangered Species
PostPosted: Fri Jul 02, 2010 1:02 pm    Post subject: Reply with quote
I had to modify the hold down stap a little with a little hammer stretching
Endangered Species
PostPosted: Fri Jul 02, 2010 1:16 pm    Post subject: Reply with quote
here is finished product...it has been working great and I driver her daily...it beats the car dying when ever I turn the lights, wipers, and hit the brakes... Laughing
Endangered Species
PostPosted: Fri Jul 02, 2010 1:24 pm    Post subject: Reply with quote
if you decide to do it this way it is a bit of work...it took me about 3hrs or so...now that i know what needs to be done It could probably be done in 1.5 - 2 hrs...
Endangered Species
PostPosted: Fri Jul 02, 2010 2:04 pm    Post subject: Reply with quote
thanks for the help with posting pics guys....
Russ Wolfe
PostPosted: Fri Jul 02, 2010 2:56 pm    Post subject: Reply with quote
Why didn't you just put the small end of the alternator in the saddle, and let the big end hang over the back.
That is the way several other people have done it.
An alternator does not care which way it spins.
Gary: OK. Ima poop.
Endangered Species
PostPosted: Fri Jul 02, 2010 4:07 pm    Post subject: Reply with quote
that is what I was going to do but when I got it in there the engine lid wasn't able to shut and I would have had cut the cooling tins and get a longer belt because of spacing up the alt, not only do you have to space it up but also over because it hits the distributer, even after cutting the lip off the alt...in the long run, for me, this was easier and cleaner looking to do it how I did, and I tried the other way first...I had it all in and spaced and the engine lid wouldn't come close to closing and the alt was pretty much against the distributer...I'm not knocking the other way, it is obviously a successful proven way of doing it...My hats off to those who have done it and posted it, it it wasn't for them I might not of even thought of trying it...so a big thanks to all of those that came before
Last edited by Endangered Species on Fri Jul 02, 2010 4:30 pm; edited 1 time in total
Page 1 of 4
