becida Samba Member
Posted: Sun Aug 08, 2010 8:28 pm Post subject: Middle track & seat install in an '84 Westie |
I picked up a middle seat and tracks yesterday to put in my '84 Westfalia.
I searched the threads here and the archives of the Vanagon list to find some help, I found it.
I removed the metal edging.
I rolled the carpet back to kitchen, sitting rolled up on the floor did not give me enough room so I clamped it up out of the way.
There were several staples and two sided tape along the front.
On the floor I found a fitting sticking up through a hole in the flooring, no idea what its for.
Does anyone know?
This is the unk fitting up close
I went underneath and found the already installed nuts and the holes that went with them.
I used a long thin drill bit to drill up from the bottom for marking purpose. I only needed to mark the floor for cutting.
I sat the rails on the marked holes to see how it was all going to fit.
The cut lines ended up being 3.5" wide
I cut the floor with a circular saw, with a 3.5" wide cut I hit the metal floor so I had to set the blade cut to 'almost' thru the wood floor. I used a hand saw and a hammer & chisel to finish the cuts. The hand saw riding in the already cut groove did a good job.
The wood floor pieces came out with a snap at the far end when bent up.
The long rail slot was half a hole short in the first test fit.
I had to use the hammer & chisel to lengthen the track slot that half a hole, the chisel worked really well on the floor.
Then I mounted the tracks on the floor to make sure they fit, make sure the hardware had no problems & I would pick which holes got the bolts.
I ended up cleaning the threads on the bolts with a wire wheel.
With the tracks mounted on the floor I laid the carpet back down and marked on it where the bolts would go. I made holes in the carpet for the bolts then put it back out of the way.
I pulled the tracks, laid the carpet down and then put the tracks on top of it.
A touch more trimming was necessary to get all the bolts in.
I did a loose fit until they were all started then tightened them all up.
Now the tracks are sitting & bolted down on top of the carpet
Then I put the seat in. Works good!
I trimmed the edge metal to allow the seat to be swapped with out having to remove it.
Now we can carry 6 people at a time in the camper, can't get to the fridge without pulling the seat but that's ok.
With the seat out I can put another carpet down in back (my van came with one already) and the tracks are hidden. _________________ Rob
Traveling... |
Joined: November 09, 2002 Posts: 154 Location: Portland OR
Posted: Sun Aug 08, 2010 10:10 pm Post subject: |
I did mine the exact way and love it. I've tried to describe it in words on thesamba before, but a picture is worth a thousand words! I still need to cut and replace the metal edge, yours looks great! |
becida Samba Member
Posted: Sun Aug 08, 2010 10:28 pm Post subject: |
The pictures sure make it easier to explain how I did it. _________________ Rob
Traveling... |
RicoS Samba Member
Posted: Mon Aug 09, 2010 5:16 am Post subject: Re: Middle track & seat install in an '84 Westie |
becida wrote: |
With my first and one of my favorite Vanagons, an '84 sunroof, I quickly realized that being able to remove the center seat greatly increased its utility. The problem was that removing the middle seat was a pain-in-the-ass which involved removing the threshold trim and pulling up the carpeting without tearing it.
So, when I went to swap out that dreadful carpeting for rubber matting, I spun off the required number of standoffs (spacers) to install under the seat tracks at the attachment points. The standoffs lifted the tracks above the door threshold trim and the surface of the matting. Seat removal became a two minute task. Of course, humping around that lump once it was out was another matter.
I made the standoffs out of 6061 aluminum bar stock; if I recall correctly, they were about 1 3/4" in diameter and 1 1/4" in length.
Mounted on the standoffs, the tracks stood proud of the floor covering, but they were mounted securely without sandwiching the carpeting between the tracks and the floor. Also, the threshold trim remained in one piece.
In my experience, the two most useful modifications I ever did to a Vanagon were to replace the carpeting (front, middle and rear) with rubber matting and install rear-facing jumpseats.
Richie |
DeadSetMonkey Samba Member
Joined: April 15, 2010 Posts: 532 Location: Denver, CO
Posted: Mon Sep 29, 2014 12:08 pm Post subject: Middle Seat into a Westy. |
Will this same routine work with a 1990 middle seat like this:
Into a 1990 Westfalia.
Just need track hardware, like this:
Any need to remove the end arm rests? Or will the seat width clear the door and the cabinets?
I'm about to remove the interior... and figure installing the middle bench and rear passenger jump while I am at it might make sense - to increase overall passenger utility... can get 5 or 6 belted passengers, vs 4... when needed. _________________ ----------------------------------------------------
'90 Syncro Westy 2.5Subi Turbo, BFGs 215/75/15 Rheins |
Posted: Mon Sep 29, 2014 12:18 pm Post subject: Re: Middle track & seat install in an '84 Westie |
[quote="RicoS"]
becida wrote: |
Richie |
Did the bar stock, under the tracks, make the tracks proud enough to make an obvious bump if you took out the middle seat and then put one solid bit of carpet in over the entire interior?
I'm imagining the scenario where, when I do not have the middle seat in, I'll lay a single piece of rubber mat over the interior. I'd like the mat to sit flat, when the middle seat is out? sort of resmebling the stock westy floor with the tracks "hidden." _________________ ----------------------------------------------------
becida Samba Member
Posted: Mon Sep 29, 2014 12:48 pm Post subject: |
As I recall (I sold the van) the seat went in fine but you had to slide it out to open the refrigerator.
When I put a carpet over the tracks (seat taken out) I had a dip into the track area. _________________ Rob
Traveling... |
the joker Samba Member
Posted: Mon Sep 29, 2014 1:37 pm Post subject: |
Try to find the factory covers that fit on the tracks when the seats out |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1649 Location: Between Here and There
Posted: Fri Dec 19, 2014 4:50 pm Post subject: |
Getting ready to do this mod. I have the bench lined up but would also like to add a single seat at times...Anyone have a line on a single center jump seat? Preferably with head rest... _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16510 Location: Brookeville, MD
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Sat Dec 20, 2014 7:50 am Post subject: |
tarandusVDub wrote: |
Getting ready to do this mod. I have the bench lined up but would also like to add a single seat at times...Anyone have a line on a single center jump seat? Preferably with head rest... |
Ironic, I just scored a single seat yesterday. I havent heard anyone mention sealant on the bolts holding down the tracks. When i removed the tracks in my van the was some sort of butyl sealant on the threads. Not sure if it was stock but i assumed it was. Later i put bolts in the holes as a temporary plug til the tracks go back. Ones without sealant weeped water around them from below. |
Aerosport Samba Member
Posted: Sat Dec 20, 2014 12:58 pm Post subject: Middle seat |
I have the middle seat and tracks to do this mod to my '87' Westy but am lacking the bolts and brackets that hold down the tracks. If anyone has these laying around I would happily purchase them. Thanks _________________ Stan L
'87 Westy GL - "Stanagon", 2wd WBX 4 speed
15" Rhein alloys, GW 1.5" lift springs & Fox shocks |
Posted: Sat Dec 20, 2014 4:05 pm Post subject: |
Has anyone tried to fit a Eurovan middle seat in a Westy? Assume its a whole different kettle of fish, but I know the front seats are interchangeable... _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
ditdater Samba Member
Posted: Sat Jul 23, 2016 7:59 am Post subject: Re: Middle track & seat install in an '84 Westie |
hey , im new to site , don't have a vw van , but a 65 chevy flat nose . lloking to poss find and buy a vanagon middle bench seat to save room and (take my new grandson in it w/ babyseat ). and would anybody know if It bottom of frame would be real basic to install in a flat floor ? maybe use the strips shown , or basically drill holes in floor for bolts and use extra metal braceing / big washers to the nuts under floor . also does it sit 2 people comfortably ? thanks dudes , danny in ky 502 432 3684 and May God Bless |
nemobuscaptain Samba Member
Posted: Tue Jul 26, 2016 4:36 pm Post subject: Re: Middle track & seat install in an '84 Westie |
actually , just picked up a mid 80s ,I think vanagon middle bench w ea end arm rest and a middle arm rest . might be thinking of finding the rest of the hardware /w the bottom track to see if that might work in mine . is the rest of mounting h/ware hard to come by . thanks for info
dan 502 432 3684 |
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Fri Oct 27, 2017 5:22 pm Post subject: Re: Middle Seat into a Westy. |
DeadSetMonkey wrote: |
Will this same routine work with a 1990 middle seat ...into a 1990 Westfalia.
Any need to remove the end arm rests? Or will the seat width clear the door and the cabinets?... |
I also put in the middle tracks, and no you'll have to remove one of the arm rests- presumably will be the one against the 'frig. Allows about an inch at the other side, to the slider.
The BIG advantage is that you can slide the seat out, turn it around, and slide it back in, facing rearward. Makes sort of a 'club car' space: Bringing 4 boy scouts home from scout camp, I put it in that way, with the table swung out between. They played cards all the way home, a couple of hours. For camping, I just leave it at home, as I have not camped with 5 or more, but could with a tent, or tenting under an awning. |
