quantummechanic Samba Member
Joined: August 16, 2010 Posts: 72 Location: MB, Canada
Posted: Mon Aug 16, 2010 8:03 pm Post subject: Couldn't hold off any longer - My Build - update pics |
Some teasers of the new project...
Last edited by quantummechanic on Fri Oct 01, 2010 3:48 pm; edited 2 times in total |
RCros Samba Member
Joined: September 27, 2006 Posts: 267 Location: Northern Cal.
Posted: Mon Aug 16, 2010 8:33 pm Post subject: |
That looks insane! I like it a lot!!!! |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4942 Location: Raleigh, North Carolina
Posted: Mon Aug 16, 2010 8:34 pm Post subject: |
Nice starting concept! This could work well... what are the plans for the suspension?
I could see Mazda Miata or 2nd/3rd generation RX7 suspension parts being put to good use here.
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5066 Location: Madisonville, La
Posted: Mon Aug 16, 2010 8:50 pm Post subject: |
My new hero!!!! WOW!!!! _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Deh Shark Samba Member
Joined: December 09, 2006 Posts: 706 Location: U.S. Virgin Islands
Posted: Mon Aug 16, 2010 9:18 pm Post subject: |
Nuff respect!! that is WICKED!!! _________________ AH TIYAD AH DAT DEH BAI!!!
Organize folks are just to lazy to look for stuff!!
55 3 fold Ragtop
Manx Dune buggy 2387cc |
Original Manx Samba Member
Joined: June 21, 2007 Posts: 389 Location: Sydney, Australia
Posted: Mon Aug 16, 2010 9:21 pm Post subject: |
YES YES YES - well done !!! _________________ Reversed gears for Subaru Transmissions
Fit a 5 speed to your rear engined car
www.subarugears.com |
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Mon Aug 16, 2010 10:20 pm Post subject: |
A Fiero front suspension would make an easy disk upgrade since you're doing some crazy stuff in the back...not sure if you ever gandered under the skirt of a Fiero but it sure looks like an easy candidate for a front suspension swap...any time at the JY I always take the time to absorb new info that could be promising for future projects.
YOU HAVE MY ATTENTION  |
1966dunebuggy Samba Member
Posted: Mon Aug 16, 2010 10:26 pm Post subject: |
That's exactly what I wanted to do! Unfortunately when I started I didn't have the ability to get it done plus getting it registered here would have been a major pain. Can't wait to see how it turns out! Which engine is it the 1.8 out of the Corolla or something with a little more juice? |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6768 Location: Northern California
Posted: Mon Aug 16, 2010 11:53 pm Post subject: |
Nice! Concur with the Miata front crossmember/suspension. |
Posted: Tue Aug 17, 2010 5:59 am Post subject: |
Some details...
I ordered a rear deck lid from Mrs. Meyers - Hide that engine.
The rear suspension is from a 300z/240sx with tubular arms and aluminum uprights - Its gonna be tight! But tons of room aft of the engine now.
The front...I have an all new VW narrowed, lowered, disc set up but I really want to try and do a Miata, but I cant find one in any yard around here. Thats why the front is still blank.
The engine is from a 2007 Toyota yaris. 1.5L, 110hp. If its not enough I will be building it with the option of a turbo later.
And...its an automatic  |
Posted: Tue Aug 17, 2010 6:17 am Post subject: |
For the front suspension I'd really like to go with the miata...
If anyone could help in locating one that would be great!!
Last edited by quantummechanic on Tue Aug 17, 2010 7:21 am; edited 1 time in total |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2285 Location: Jacksonville, FL
Posted: Tue Aug 17, 2010 6:21 am Post subject: |
My wife has a Toyota Matrix XRS with the 1800 version of that motor and a 6 speed trans. It makes 180hp at 8000 RPM. The cam timing changes at 6000 and it feels like a 75 shot of nitrous when it does.
You should have fun with that thing for sure! _________________ www.LoCashRacing.org
Lo' Cash Racing Team on Facebook
More brains than bucks...Believe it or not!!
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
Posted: Tue Aug 17, 2010 7:44 am Post subject: |
quantummechanic wrote: |
Some details...
110hp will be plenty unless you really want a handful...you'll still be able to rocket launch that thing with no problem...might even check some of the local automatic trans shops to see if maybe they can modify the valve body for some tighter shifts...even though it's an auto shift car the stock Yaris weighs around 2k so you have removed well over 1200lbs so it should be pretty preppy...a note on the Miata front suspension, if you visit the flying Miata web site you will find any parts you need used or new and race stuff...they even have a full tubular front suspension kit...this stuff is spendy but their parts are top quality and have a nice finish...the auto trans will definitely make for an easy install...I will follow with much interest! |
Posted: Tue Aug 17, 2010 8:27 am Post subject: |
Check out http://www.flyinmiata.com/index.php?deptid=5675&am...F1990-1997 -
Flyin' Miata makes a Chevy V8 swap kit for the Miata, but the interesting part is that they make a replacement tubularfront suspension crossmember that is about 10lbs lighter than the factory Miata piece... should give you some ideas for front suspension.
I'd still investigate the Miata rear upper/lower control arms for 'compactness' - http://www.quadesl.com/miata_alignment.html
Good luck!
Posted: Tue Aug 17, 2010 11:52 am Post subject: |
Great news...the last yard to check here in town was closed yesterday. I called today and they have a complete Miata...front suspension? How's a hundred bucks sound? - Sold!
Removed and ready for pickup (hopefully) by friday. |
wythac Samba Member
Posted: Tue Aug 17, 2010 12:04 pm Post subject: |
I am not in the know about how a Yaris uses a shifter, but I am going to guess that the different shifter positions are all in a line, which will allow you to use a cable actuated shifter, which would dramatically simplify changing gearshift positions. Very cool build idea. |
chris_parks Samba Member
Posted: Tue Aug 17, 2010 12:37 pm Post subject: |
My build jealousy just exceeded OSHA's safe limits.
The EPA is out to get me now.
I soooooo want details as you go.
I want to do this too... _________________ Just loving life. One buggy at a time. |
Posted: Tue Aug 17, 2010 1:10 pm Post subject: |
wythac wrote: |
You are quite right ...and an added bonus: more foot room and (of course) no clutch pedal. |
Posted: Tue Aug 17, 2010 1:30 pm Post subject: |
Man every time I log in I'm checking for updates on this build be sure to post up detailed pics of the subframe and undercarriage. Good choice on the auto trans to I was thinking trying to fab up a shift linkage for a manual trans would have been interesting...what are you going to do for a VSS for the auto trans? Digital speedo with output maybe? I swapped an 89 Corolla engine into my build now I kinda wish I woulda mid-mounted it like you did but at the time I didn't have the ability plus I wouldn't have been able to get it insured (stupid ICBC) ... Toyota's wiring is pretty simple to especially compared to Subi's. Stoked to see how this goes  |
gr8cobbler Samba Member
Joined: May 04, 2006 Posts: 916 Location: Midlife Crisis, Midwest
Posted: Tue Aug 17, 2010 3:32 pm Post subject: |
I'm posting to ensure I get updates. Ditto all the interest and desire to see under the body. Next generation for sure. _________________ Gary
Being a cheap old fart is just a front for my actual lack of money.  |
