Jack Frisch Samba Member
Joined: August 12, 2003 Posts: 766 Location: Northhampton, MA
Posted: Wed Sep 15, 2004 11:57 pm Post subject: What removes old adhesive BUT not paint.. |
I need to remove the adhesive from the "tunnel" area in the center of the inside floors
old glue and tar board residue.
What can I use that wont remove any or too much of the original black paint under it?
Laquer thinner? (I've used that while Land Rover mechanic to remove exterior trim that was double taped on the body..wit no loss of paint) _________________ 1958 Beetle orig. 6 volt 36 hp engine, body & pan, Black w/red/off white inter., Orig. VW wood roof rack and orig. rear luggage rack.
1967 13 Window Walk-thru Deluxe Bus, stock 1500 engine, Titan Red/Grey, Platinum Mesh interior, orig. & stock
1966 GT350H Shelby Orig. low mileage car |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79647 Location: Sneaking up behind you
Posted: Thu Sep 16, 2004 4:40 am Post subject: |
3M Adhesive remover.
It works like a charm. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
SouthernYankee Samba Member
Joined: September 22, 2003 Posts: 437 Location: Rock Hill, South Carolina
Posted: Thu Sep 16, 2004 5:03 am Post subject: |
Heat gun may help with the tar board.
Out of curiosity, why worry so much about keeping the paint? _________________ Email changed to [email protected] |
Posted: Thu Sep 16, 2004 10:26 am Post subject: |
I was having a discussion with Peter Cook of the VWC earlier this week about such aspects as this in regards to concours judging at car shows and overal preservation for the hobby
I'm interested in keeping the paint because if I can clean it up it will not have to be repainted, and i the end it will be a nice "original" detail if I can make it look nice.
Yes its going to be under a rug and or mat, but I can pul lit back for "inspection" if needed at a show or if selling it.
Same thing under the rear seat. I am going to clean up the heater boxes but keep there original paint.
Yes, again its a silyl detail but with a little extra work I can add "value" to the car and not have to repaint anything.
ANYTIME you can "save" something that original to a car or any antique it saves its history and adds to its value.
In the case of these cars too many are not totally original any more. Thats lost history.
Check out the '59 thats for sale here, a green one for 2 grand...his website abotu the car shows photos with cool aspects that are original. _________________ 1958 Beetle orig. 6 volt 36 hp engine, body & pan, Black w/red/off white inter., Orig. VW wood roof rack and orig. rear luggage rack.
vdubrida70 Samba Member
Joined: March 20, 2004 Posts: 391 Location: Whittier, CA
Posted: Thu Sep 16, 2004 10:42 am Post subject: |
GOOF OFF will take most anything off except paint |
Delaware Dave Samba Member
Joined: August 29, 2003 Posts: 359 Location: Delaware, USA
Posted: Thu Sep 16, 2004 2:32 pm Post subject: |
Glenn beat me to it. I was going to suggest 3M adhesive remover also. It comes in a pretty good size can, and works great. Goof-Off might work well, but I never see it in a size that would make it worthwhile. _________________ \X/ Delaware Dave
'71 Standard Beetle Project
'69 Type 3 fastback (sold), '65 Standard Beetle (sold),
'05 Passat 1.8 Turbo, '97 Jetta Tdi (sold) |
k29349@yahoo Samba Member
Joined: May 10, 2003 Posts: 652 Location: Inman, S.C.
Posted: Thu Sep 16, 2004 2:44 pm Post subject: |
Someone used some kind of contact cement to glue carpet and the headliner in my oval. I have learned that nothing will take this stuff off except aircraft paint remover. I have tried acetone, laquer thinner,M.E.K, 3M adhesive remover, and a big wire brush on a big angle grinder with little or no results. _________________ 57 oval
60 single cab (not the one in the avatar) |
camerod Volksfab
Joined: October 01, 2002 Posts: 606 Location: washington state
Posted: Thu Sep 16, 2004 3:15 pm Post subject: |
I have used kerosene for this exact procedure works great!, also, the eastwood company sells "undercoating remeover" but I have not yet tried it! _________________ DON'T SHIT WHERE YOU EAT! |
schwartzbugg Samba Member
Posted: Thu Sep 16, 2004 5:41 pm Post subject: |
Lighter fluid works, but is really dangerous. _________________ BDAZBUG- 1967 VW |
Posted: Thu Sep 16, 2004 5:48 pm Post subject: |
schwartzbugg wrote: |
Lighter fluid works, but is really dangerous. |
ahahahaha so now i have an excuse to play with lighter fluid at work |
