amishman Samba Member
Joined: March 09, 2004 Posts: 3239 Location: California
Posted: Fri Aug 27, 2010 10:44 am Post subject: Please help identify this Thing Roll Cage Roll Bar |
Anyone know who made this VW Thing Roll Bar? Does it look pro made and sold back in the day or a home-made setup? I do notice it has notches cut just right so the soft-top still closes proper and all. Looks beefy. But, unsure of its origin other than it came with a very original 1973 VW Thing that is still stock all the way around including original mats and soft-top so previous original owner had it along the way.
Here are the pics.
Thanks, tj
_________________ tj (the Amishman)
Come visit my web site!
http://www.vwhippie.com |
Chad1376 Samba Member
Joined: January 29, 2005 Posts: 1435 Location: Henderson, Nevada
Posted: Fri Aug 27, 2010 10:54 am Post subject: |
I don't know about the origins of the cage, but those notches look like they would create a severe weak link in the tubing, in addition to allowing water to get inside the tubing and facilitate rust.
I'm no cage expert, but I would at least close of the holes left by the notching and add some additional reinforcing if this was to be used as anything beyond a "show" cage. _________________ My never ending 1302 Autocross Project:
http://www.shoptalkforums.com/viewtopic.php?f=51&a...02b8f83f22 |
Semper_Dad Samba Member
Posted: Fri Aug 27, 2010 11:24 am Post subject: |
Looks like a standard OEM rollbar with the front crossbar hacked. However, the OEM bar would NOT have needed to be hacked in order for the top to work. Definately need to fix the hack before using.
I believe there were at least two different variations of the OEM bar. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
Posted: Fri Aug 27, 2010 11:28 am Post subject: |
| Semper_Dad wrote: |
Looks like a standard OEM rollbar with the front crossbar hacked. Definately need to fix the hak before using.
I believe there were at least two different variations of the OEM bar. |
I myself have no plans on using it and prefer a roll cage-less Thing but wanted to just figure out if this was an VW OEM or some aftermarket. I looked at the archives here and it did kind of look like one I saw that said it was stock VW but the notches threw me off.
I am not sure if I will keep it and fix it up or sell it down the road.
I guess if is is OEM, that is very cool, other than a little fixing on those notches. Maybe they can close it off so it keeps water from getting it and re-enforces it some.
Maybe the original or some previous owner hacked into it so the hard-top would still mount or something?
tj _________________ tj (the Amishman)
Posted: Fri Aug 27, 2010 11:32 am Post subject: |
| Semper_Dad wrote: |
So, the OEM roll bar woudl allow both soft and hardtops to mount without issues I presume? I wonder why the heck they did this hack then? Odd.
Posted: Fri Aug 27, 2010 11:38 am Post subject: |
| amishman wrote: |
tj |
Might have been a 3rd party hardtop that required the hack. Some of them required you to remove all the outside tiedown loops AND the soft top frame pivot point as well. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Fri Aug 27, 2010 11:44 am Post subject: |
| Semper_Dad wrote: |
| amishman wrote: |
tj |
Might have been a 3rd party hardtop that required the hack. Some of them required you to remove all the outside tiedown loops AND the soft top frame pivot point as well. |
The weird thing is the hardtop that came with the Thing is OEM VW with the 5 ribs on top and no missing hoops. So, unless they acquired the correct hardtop later in life and originally had the 3rd party one 1st, did the hack, then acquired the OEM top.
I just checked the underside of the hardtop and on each side right around where maybe some top to rollbar rub could be, or softtop bars could be, they filed or slightly cut into the underside of the hardtop to make something fit.
I take it there is no stamp or marking on these oem rollbars that confirm 100% what they are?
tj
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Fri Aug 27, 2010 12:43 pm Post subject: |
What you have is NOT a VW roll bar.
The VW provided roll bar was a 6 point, sort of, the rear 2 legs "V" into one point in the rear.
Also the VW cage fits under both tops.
From the VW sales brochure
From the Samba photo gallery
Now... As I understand a lot of the dealers had local shops fab up cages, so this muddies the facts a bit with regard to "Dealer" roll bars.
I can also tell you that I have NEVER seen a four point roll bar that fit under the hard top. Well at least that wasn't obviously modified. _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
Posted: Fri Aug 27, 2010 3:43 pm Post subject: |
I know this argument has been done before but I believe there was at least 2 different "official" rollbars that were offered by dealers.
This one is the real official one with the official ZVW accessory part number ZVW 148 283. This picture comes off the install directions from VOA
. This is the one that Uber is talking about.
This other one is directly off the 1974 VOA brochure. It looks more like a 4 point and nothing like the "official" one. It could be an artist's rendition of one that never was produced. It doesn't look like the one you have either.
Clearly there may have been several versions of "dealer install" rollbar setups. The design of the rollbar the OP posted is the most common (non-Thing Shop) i've seen. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Fri Aug 27, 2010 3:51 pm Post subject: |
| There were 2 types of roll bars. On the right side of the US most were the 4 point as your bar and on the west coast were mostly the 5 point as in the Acc pamplet shown, and in other Acc pamplets you will find the 4 point. It is believed that VWoA sold the 5 point that would break down for shipping ease. The 4 point bar you have would work with the folding top, but not the VWoA hardtop. I can see that the notch is cut were the hardtop has a rib as to clear. |
kubelmann Samba Member
Posted: Fri Aug 27, 2010 4:00 pm Post subject: |
I currently have three 4 point Thing roll cages.
Cage #1 came installed on Herr Kubelmann when purchased from the PO who was the second owner. The first owner bought the car new from Heubergers VW in Colorado Springs where he worked as a mechanic. It came with a hardtop and soft top and the 4 point roll cage was built by an off-road company in Tempe Arizona. I know this because when I pulled off the foam cover of the large diameter tube the tube had a sticker from the off-road company. Both a soft top and hard top fit easily under this 4 point cage.
Cage #2 came installed on KubelPanzer when purchased as 4th owner; Car was sold new in Texas then sold to a couple in Eastern CO and then was a barn find by the folks I bought it from. It has the same roll cage shown on this thread minus the chunks of missing metal. This car came with a soft top that fit fine. Later I got another hard top for the car (that fit fine over the 4 pt. cage) This hard top was traded for other VW stuff and now under the knife has Herr Kubelmann's hardtop (which fits over the roll cage just fine.)
Cage #3 Also a 4 point but constructed of smaller diameter tubing than the other 4 pt. roll cages. The reason I have it is that it would not fit under the hardtop that used to be on KubelPanzer. Thus this cage became part of the trade for the hard top. Included in the trade was a Bundeswehr OD green soft top that also fits under Kubelmann's 4 pt roll cage.
My Dad bought a used 1973 Thing from a VW dealer in 1974 and it had a 6 pt roll cage and a soft top that cleared each other just fine. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10327 Location: Prime Meridian, ID
Posted: Fri Aug 27, 2010 5:46 pm Post subject: |
My cage is identical to the one discussed- stock as installed at dealer in '74. Mine, however, lacks the notch-outs made to support a 2X4 bike mount! Nobody with any tubing sense would notch the tubes in that manner- even a nutjob clearancing for a poorly-fit top.
Try the 2x4 test- my hunch is drops right in- look at the underside for evidence of muffler U-bolt Appalachian mounting hardware. _________________
| EverettB wrote: |
FU#5 |
Posted: Fri Aug 27, 2010 6:26 pm Post subject: |
| That is funny. Years ago a guy I knew had enough 4 x 4s to make a bike rack for his 73 honda civic. He bragged about how he built it for free. We joked about how the rack probably weighed more than the car. |
sdwalter Samba Member
Posted: Sat Aug 28, 2010 5:29 am Post subject: |
| I have the same rollbar without the notches. I'm sure it was produced, not homemade, but the notches scare me too! |
volksaddict Samba Member
Posted: Sat Aug 28, 2010 6:11 am Post subject: |
| My 73 has the first one too, unhacked. It came on a very orig 23k mi car that has the front push bar too. Maybe there were 3 styles of original. |
yellow73kubel Samba Member
Joined: August 17, 2008 Posts: 789 Location: Columbia, SC
Posted: Sat Aug 28, 2010 7:23 am Post subject: |
Strangely enough.. Amishman's is exactly the same as my cage, one short leg and all (except the notches ). My Thing traveled from Oregon to North Carolina, but I don't know where it started before that. Did anyone else's cage come with holes in the front to rear tubes for seatbelt mounting?
Since it is wide open, would you mind measuring the wall thickness on that tube? I'm just curious to see what it is. |
///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Sat Aug 28, 2010 8:25 am Post subject: |
| Semper_Dad wrote: |
I have one similar to this, though I think the rear bar angles were changed a bit from rendition to production if it's a VW product.
Posted: Sat Aug 28, 2010 10:43 am Post subject: |
| yellow73kubel wrote: |
3/16" thick where my notches are.
carterzest Samba Member
Joined: January 22, 2008 Posts: 3841 Location: Eagle, ID/Sun Valley, ID
Posted: Sat Aug 28, 2010 3:39 pm Post subject: |
| Ron Domeck wrote: |
TJ, mine is the same without notches as well and my VWoA hardtop does not fit over the bar, however, one of the PO's of mine who was really tall, added about an inch to the roll bar to make more headroom. I was just going to cut it down and fit the VWoA hardtop but then I got the SCab bug and have since almost successfully sold the 181 I think they pick it up this coming week I have some pics of my roll bar in my photo gallery if it helps and could take some measurements for you?
Jeffrey _________________ Happiness=Portland, Oregon in the rearview mirror! |
laughatgravity Samba Member
Joined: September 19, 2009 Posts: 95 Location: Philly burbs
